bad stringer 1985 SN
Category: Buy and Sell
Forum Name: Boat Parts For Sale
Forum Discription: Parts for sale only
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=5586
Printed Date: November-22-2024 at 4:12pm
Topic: bad stringer 1985 SN
Posted By: sterlingmermaid
Subject: bad stringer 1985 SN
Date Posted: January-23-2007 at 2:24pm
I just purchased a 1985 SN and it looks like the stringers need replacing. Can anyone tell me the best way to attack this problem? Best way to open the floor It seems to be only in the front of the boat. I was reading about Seacast. Does anyone know if it works well? Can you replace only the front half of the stingers or do they have to be totally removed????? Any help will be appreciated
tk
Posted By: Hollywood
Date Posted: January-23-2007 at 2:33pm
These ought to get you started. Try some further searching if necessary.
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=5409&KW=stringer - Wood Replacement Stringers
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=5211&KW=pourable - Pourable Stringers
Posted By: SkiBum
Date Posted: January-23-2007 at 5:50pm
This air powered saw was a great tool for cutting away the floor, cutting loose stringers, and general cutting inside the boat. It can be purchased at auto parts stores. You'll need extra blades.
You only have to replace as little or as much as you want but I a$$ure you that if the floor is breached in front the damage extends all the way down to the transom. Once the water works its way into the boat it eventually saturates into the foam from the bottom up.
If you wanted to do a partial repair of only the front you might want to do something like this:
Cut out the gla$$ from the front of the engine compartment to the bulkhead leaving about 1/2" along the sides of the hull. Underneath that gla$$ you are going to have several 1"x3" pine slats that are STAPLED onto the stringers.
Remove the gla$$ and wood in that area keeping it as intact as possible to be used as a pattern.
Remove the foam in that area leaving a good line where you stop.
Then if your stringers are not falling apart rotten you can use rot doctor to repair the wood. Even better remove a section 4" deep for the length of the damaged area. You can laminate or graft a new piece of stringer onto that spot.
The secondaries are probably very bad. You can graft new pieces in the repair area in a simalar manner depending on how badly they are damaged.
Replace the foam.
Install a 1/2" plywood floor covered in gla$$ and resin.
Regla$$ the floor to the hull.
Still a ton of work. Will provide a good repair of that area. BUT still leaves behind soaked foam and rotting stringers.
Bill
http://www.freewebs.com/billsboatworks - http://www.freewebs.com/billsboatworks
www.freewebs.com/billsboatworks 1987 SN Rebuild Project
Posted By: SkiBum
Date Posted: January-23-2007 at 7:16pm
This is the area for which I described the repair. You probably have similar damage on your own boat. If you repaired only this area you would have a good repair.
As far as SEA CAST goes I don't think there is much difference in price between using it or wood due to the cost of all the gla$$ and epoxy. So cost is not really a factor.
If you get serious about starting this project and you want more pics or have more questions you can email me.
mailto:william.w.schneider@us.army.mil - Bill
Bill
Date Posted: January-23-2007 at 7:51pm
Thanks for the info My 1x3s were so bad they are mud. Is there a pattern on line I can go by? Or would you just plywood from front to back then gla$$ over it?
tk
Posted By: SkiBum
Date Posted: January-23-2007 at 8:33pm
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=4002 - Partial Floor and Stringer Repair
This link is to a string where TRBenj did a really good job of fixing his boat. He just did a partial repair as well. You might get some good info.
I don't know of any patterns. I was fortunate enough that I could cut out the floor in large pieces. For that front piece I cut the gla$$ around where the 1x3's were installed and used what was left as a pattern. (when you turn the gla$$ floor upside down you can see the imprint of where the boards end for tracing)I have a replacement piece of 1/2" plywood laminated with expoxy resin and 10oz gla$$ ready to go into my boat. I could make a pattern and mail it to you if you have no other recourse.
As far as using plywood for the entire floor - that was my origional plan until I learned the floor is stand alone on top of foam. Still I made the piece under the bow out of 3 ply floor underlayment laminate (very thin, light weight plywood designed to go under tiled floors). For a partial repair that would work just fine. Except, the area where the 1x3's were located must be at least 1/2" thick because there is no foam beneath it.
Did you already cut out part of your floor?
Bill
Date Posted: January-24-2007 at 6:45am
Yes I did cut most of the floor. I started cutting small pieces trying to avoid a large job. I will also be looking for a new drive train if any one has one for sale
tk
Posted By: jb_dallas
Date Posted: January-25-2007 at 5:50pm
All of this talk about floor rot makes me wonder what mine looks like underneath. There isnt any soft spots, but I know I had a leaky pitot tube that was allowing some water in before I bought the boat. I have since replaced the pitot and sealed it. I am thinking about drilling a 1/2" hole through the side of the bilge, so I dont have to tear up my carpet. I can marinetex over it when Im done. What do you all think?
JB
Posted By: SkiBum
Date Posted: January-25-2007 at 8:40pm
What are you proping for when you drill? If you are expecting water to come running out like a faucet that is not likely to happen. I learned that most of the wet foam on my boat was at the very bottom - gravity. You certainly won't destroy your boat making a hole. It can be repaired - marine tex may not be the best answer but would work. In the 2001's (model not year) the floor under the front seats is wood. You can bang the end of a screwdriver against it checking for soft spots. Then poke an ice breaker inside to confirm your suspicions. Same technique for checking stringers for rot.
There may be other symptoms: Unusually large wakes; vibration; obvious breaches between the hull or floor and stringers; screws that are loose and wont tighten.
Bill
