prop asembly
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=5944
Printed Date: November-27-2024 at 7:37pm
Topic: prop asembly
Posted By: mckin007
Subject: prop asembly
Date Posted: March-08-2007 at 11:07pm
is there a washer between the castle nut and the prop? Any reccomendations to order parts online?
nautique girl
Posted By: SkiBum
Date Posted: March-09-2007 at 3:10pm
No washers. Some use a nut with a nylon ring that actually locks the nut onto the shaft. Some have the old castle nut that require a cotter pin to lock the nut in place. You can get parts at SKIDIM. Pretty good source.
Bill
http://www.freewebs.com/billsboatworks - http://www.freewebs.com/billsboatworks
www.freewebs.com/billsboatworks 1987 SN Rebuild Project
Posted By: 87BFN owner
Date Posted: March-09-2007 at 8:26pm
make sure you get a stainless steel cotter pin and a stanless steel key if your ordering these parts. As regular steel one will rust. Know some that had the prop fall off because they didn't use a stainless cotter.
