OEM Alternator - 76 Mustang
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=6058
Printed Date: January-17-2025 at 6:39pm
Topic: OEM Alternator - 76 Mustang
Posted By: Lake Horse
Subject: OEM Alternator - 76 Mustang
Date Posted: March-19-2007 at 1:35pm
Does anyone have a recommendation for a replacement alternator for a 76 mustang. I've checked SKIDIM and Summit and I really need to know what I'm looking for!!????
------------- Lake Horse
http://correctcraftfan.com/diaries/details.asp?ID=1587&yrstart=1971&yrend=1975 - 76 Mustang
Date Posted: March-19-2007 at 1:38pm
Have you called SkiDIM? Vince or Richard will know.
Posted By: boat dr
Date Posted: March-19-2007 at 2:10pm
Lake Horse, I converted my Autolite W/external regulator to a one wire Delco Remy{GM},63 amp more than enough ,cleans up motor area too,uses only onr wire,battery lead................boat dr
------------- boat dr
Posted By: mackwrench
Date Posted: March-19-2007 at 2:30pm
Ditto what boat rx posted above
------------- NO LONGER A MEMBER
Date Posted: March-20-2007 at 7:31am
Boat Dr, Does that Delco work on a ford?
Posted By: boat dr
Date Posted: March-20-2007 at 7:46am
Lake, worked just fine on mine, E bay, boat parts has one . 100 amp one wire for 80.00 , it is on the first or second page or just do a search...........boat dr
Date Posted: March-20-2007 at 8:43am
thanks doc.
Date Posted: March-21-2007 at 7:34am
With the one wire setup will I still be able to use volt guage???
Posted By: nuttyskier2002
Date Posted: March-22-2007 at 1:39am
Lake Horse, the answer to your question is yes. You can use your voltage guage. As a matter of fact, you won't even have to change the wiring of your existing voltage guage. I will say though that for applications that require a long charging circuit (a long lead wire from alternator to battery) it is better to use a 3 wire type alternator. 3 wire alternators offer remote voltage sensing which compensates for voltage drops through the charging circuit wiring. Sorry for hyjacking this thread but electrical systems are my specialty.
------------- 95 Malibu Echelon w/Mercruiser 350 Magnum Skier
Former boats:
88 Ski Centurion Tru Trac II
59 Chris Craft Capri (woody)
Date Posted: March-22-2007 at 8:08am
Thanks nutty, I just wanted to check because the OEM Alternator was a 4 wire and I just couldn't see how I could get away with using a one wire setup. Thanks for the info.
Date Posted: March-22-2007 at 1:52pm
The voltage guage only needs 2 connections to work.... 1 positive and 1 negative. The positive side connects to the hot (ign) side of the ignition switch (hot when key is in run position) and the negative side connects to ground. Ground can be the neg side of the batt or it can be the engine block or it can be a ground bus (which is grounded to the engine block via a black wire). Many times the grounds (or neg) of all guages are daisy chained together with one common wire going back to the engine block.
The only connection that the one wire alternator needs is: one hot (red lead usually 10 or 12 gage) from the Batt (+) side of the alt to the heavy red Batt cable on your starter solenoid switch. Don't forget to put a circuit breaker in between.
Let me know if more help is needed. I can give you my number if you'd like to call for more information. Brian
Former boats:
Date Posted: March-22-2007 at 3:38pm
Thanks Brian, That's exactly what I needed to know. I just received the new alternator today and I will install it on Saturday. Hopefullly there should be no problem with the install. But if I do hit a snag I will send you a post on monday. Thanks again for all your help. I really appreciate it.
Matt
Date Posted: March-26-2007 at 2:54pm
Install went very well and very fast. Thanks to everyone for their help, especially Brian!!
Posted By: JEFF KOSTIS
Date Posted: March-26-2007 at 9:48pm
Hey Lakehorse did someone pull the factory ammeter and install a voltmeter in its place??
Jeff...
------------- MUSTANG COUNTRY
http://www.correctcraftfan.com/diaries/details.asp?ID=1074 - 1974 Mustang 17
http://www.correctcraftfan.com/diaries/details.asp?ID=1093 - 1976 Mustang 17
Date Posted: March-27-2007 at 10:33am
No, we were able to use the factory ammeter.
Posted By: boat dr
Date Posted: March-27-2007 at 10:57am
Lake Horse,I dont like a ammeter,the reason being all the voltage,amperage must travel that long path to and from that guage.If the guage goes bad ,no return path to battery.Also the danger of fire ,old wires,bad connection, high resistance.
one of the many reasons they are no longer used to monitor the charging system.Battery or volt meters do a much better job,with less chance a malfunction,fire......boat dr
Date Posted: March-27-2007 at 11:20am
Doc, Do you know of a OEM voltmeter for my boat?????
Posted By: boat dr
Date Posted: March-28-2007 at 12:15pm
Lake Horse,
Summit has a good selection of oem look alikes.Don't know what you have now ,but this may be a good time to upgrade .I went with a complete set of the Auto Meter,they were real close to oem .But if you replace them all only the purist will notice the upgrade...............boat dr
Date Posted: March-28-2007 at 1:10pm
Besides the gauges, is there anything else that I need to get for the upgrade?
Posted By: boat dr
Date Posted: March-28-2007 at 3:11pm
That should be all you need,If you will set tight for a couple of days, I will sell you mine,less than 6 months old.It is a 100 amp unit.
Removing timing cover,circulating pump,belt driven raw water pump,and going with a smaller size alternator.She is on a diet.
I will be using a crank driven raw water pump,want to move alt.lower on the engine.Space issues dictate a smaller size,Jap import perhaps.
Date Posted: March-28-2007 at 3:46pm
Sounds good to me just let me know when you're ready.
Matt
Date Posted: March-28-2007 at 7:27pm
Matt, I agree with Boat Dr. 100% about changing the ammeter out for a voltage gage. I was under the impression that you were already using one. That will free your wiring harness up of a lot of heavy wire and make your charging circuit more reliable. Good to hear you got your alternator working.
Former boats:
