Where do you get your gaskets
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=6252
Printed Date: November-30-2024 at 7:53pm
Topic: Where do you get your gaskets
Posted By: phatsat67
Subject: Where do you get your gaskets
Date Posted: April-09-2007 at 2:26pm
Ive been checkin around for full rebuild kits and they are hard to come by and expencive. All the gaskets should be the same as a car other than the front crank seal and the rear main seal because of the reverse rotation. The reverse rotation gaskets are also hard to find. I was just curious what everyone does for gaskets.
Date Posted: April-09-2007 at 2:42pm
I sourced some of my gaskets (water pump, etc) from Summit. The rest I went with quality PCM stuff from SkiDIM. Dont skimp on gaskets- if you get automotive types, at least make sure you get Fel-Pro.
SkiDIM would also be a good source for the reverse rotation stuff. I think Alan (81Nautique) went through the process of identifying the proper front and rear crank seals very recently.
Date Posted: April-09-2007 at 6:23pm
Sweet I think im just going to order a bottom end kit for the rear and front seal and use the rest automotive because the freakin top end kid is like 120 bucks where I could get all the same gaskets that dont say "marine" for half that.
Posted By: Tim D
Date Posted: April-09-2007 at 6:50pm
Fel-Pro for intake, heads etc. What year is your boat? If it has a two piece rear seal, the marine is the same as the auto, just a big difference in price. With the two piece deign, the crank has the wick lines. One piece, the seal has the wick lines.
Tim D
Date Posted: April-09-2007 at 11:06pm
It has a one piece so I will need a reverse rotation seal. Its an 86
Posted By: leo0648
Date Posted: April-10-2007 at 12:36am
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=010&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=200080332234&rd=1,1
There is a reverse rotation engine kit on ebay for $380. He has another kit with a reverse rotation marine cam for another $100. I think that is the kit im gonna buy when I do rebuild my 351. Also, he said you can opt for fel-pro for like $10 more.
Date Posted: April-10-2007 at 12:36pm
Thanks i saw that on there the other day.
