1976 Ski Tique
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=6480
Printed Date: January-30-2025 at 3:45pm
Topic: 1976 Ski Tique
Posted By: swifty
Subject: 1976 Ski Tique
Date Posted: April-27-2007 at 6:26pm
Does anybody know what oil should be ran in a 76 302? And i noticed that when out cruising on the lake there is always a slight humming noise with the hull. Is this normal?
Date Posted: April-27-2007 at 6:43pm
I run 10w40 in mine.
There are always harmonics in any boat but you may want to check your drive line to make sure it's aligned, the shaft is straight, the strut bearing is good and the prop is ok
Posted By: nuttyskier2002
Date Posted: April-27-2007 at 10:17pm
When does the humming occur? At what RPM? Is it more like a churning sound or a buzzing sound? Do you have excessive engine vibration?
Former boats:
88 Ski Centurion Tru Trac II
59 Chris Craft Capri (woody)
Posted By: acpskitique
Date Posted: April-28-2007 at 8:44am
Swifty,
I've got a '76 tique as well, and I have the same vibration issues. I'm in the process of checking my shaft alignment and prop. Do a search on "transmission alignment" and there's a good thread started by Eric Lavine with pics on how to do it.
I would go with 10W40. These motors were recommended to run on 40W by PCM, however that was when multi-grade oils were not very good quality. Now it helps to have the oil a little thinner on start up, and that's what the 10w quality does. I put regular valvoline in mine. Don't go full synthetic unless you've recently rebuilt the motor.
http://www.correctcraftfan.com/diaries/details.asp?ID=1896&sort=&pagenum=3&yrstart=1976&yrend=1980 - '76 Ski Tique 302PCM
Posted By: swifty
Date Posted: April-30-2007 at 12:03pm
The humming is any time past 10-15 mph. It is just a humm. If you put your hand on the side you can feel it but nothing to severe. Just wondering if i should worry about this.
Posted By: swifty
Date Posted: April-30-2007 at 12:04pm
Its a buzzing sound.
Date Posted: April-30-2007 at 12:07pm
Never hurts to check the alignment. I even think Eric has said it's not a bad idea to check it every year after it's been in the water for a couple days.
Posted By: rudderdad
Date Posted: May-02-2007 at 11:19pm
Have had this before from a poorly glassed wood piece under the gunwale, behind the shifter. The looser it gets, the louder it gets.
rudderdad
