What is that sound?
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=656
Printed Date: April-12-2025 at 7:54pm
Topic: What is that sound?
Posted By: Swatkinz
Subject: What is that sound?
Date Posted: July-22-2004 at 8:48pm
Alright, I've been in several nautiques throughout the years and more often than not, there is a mysterious howl or groan that occurs when turning the boat. Has anyone else heard this and does anyone know what this sound is? Cavitation maybe?
------------- Steve 2011 Sport/Air 200 Excalibur 343 2017 Boatmate Tandem Axle Trailer
Former Malibu owner (07, 09)
Posted By: Rick
Date Posted: July-23-2004 at 2:02pm
Cavtation and also vibration caused by the force of the turn trying to push the prop shaft and strut to one side out of alignment.
------------- http://www.correctcraftfan.com/diaries/details.asp?ID=250&yrstart=1996&yrend=2000%20" rel="nofollow - 2000 Ski
Posted By: Swatkinz
Date Posted: July-23-2004 at 7:42pm
is this normal for inboards? Are others of you hearing the same in your Nautiques?
Posted By: ravinmad
Date Posted: July-24-2004 at 9:48pm
It is typical for inboards if you push the envelope in cluding my antiques. It is cavitation, where the pressure of the water is decresed and air comes out. Air will destroy your prop with explosions on the blades. The prop design (RH or LH) makes a difference in the turn.
------------- The best boats of the century
Posted By: 64 Skier
Date Posted: July-26-2004 at 1:14am
Turning through the water sideloads a prop, twists the boat and then throw in the cavitation and you get a little sound. Even if the shaft is perfectly aligned in the water, boats heave, pitch and yaw all of which create some misalignment.
I think it's normal. CC's handle it well.
------------- 64 Skier
66" HO VTX and 67" HO Triumph
http://www.correctcraftfan.com/diaries/details.asp?ID=1071&sort=&pagenum=3&yrstart=1971&yrend=1975 - 71CC
