Start up idle
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=670
Printed Date: April-12-2025 at 7:45pm
Topic: Start up idle
Posted By: goligmj
Subject: Start up idle
Date Posted: July-26-2004 at 4:16pm
I have 1988 SN and when I go to start it, I pump the accelerator once and the boat fires right up, however once the boat has started it runs at a really low RPM (about 300 rpm with the shift lever in neutral) once it gets warm it runs right about 570 RPM which I think is considered spec for that boat in gear.
any thoughts of why it idle's so low cold? Id this normal?
Mike
Posted By: David F
Date Posted: July-26-2004 at 7:56pm
You need to adjust your electric choke. If:
1. your carb has a fast idle speed adjustment screw then increase the fast idle speed by turning the screw "in" or clockwise. You should first verify that the choke flap is just closing completely when the accelerator is "depressed".
2. If no fast idle screw, then adjust the choke slightly to the "richer" setting (clockwise, I think). After you do this, make sure the choke opens fully when the engine has reached normal operating temperature.
