Whining Transmission
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=6755
Printed Date: November-15-2024 at 12:19am
Topic: Whining Transmission
Posted By: 89Nautique2001
Subject: Whining Transmission
Date Posted: May-20-2007 at 10:52pm
I have a 89 Ski Nautique & it has a real bad "whining" noise in the transmission. It only does it in forward gear. It is loud up to about 1/2 throttle & then gets better, but still makes the noise. Up to 1/2 throttle it is very distracting. Any ideas whet the problem may be? Thanks
------- They are only original once! ------
Posted By: Ski Texas
Date Posted: May-20-2007 at 11:52pm
same boat same year same problem
3/4 of the Planet is water
Spend 3/4 of you time on the water
Posted By: boat dr
Date Posted: May-21-2007 at 12:07am
Do you need a little cheese with that whine,ha ha.
Where is Eric when you need him, the tranny doctor will be seeing patients tommorrow call for an app............boat dr
Calling Dr. Eric,answer your beeper...........
boat dr
Posted By: eric lavine
Date Posted: May-21-2007 at 6:29am
Was the wife on the boat? anyways if your sure it wasnt the wife we need to know exactly what trans you have, PCM? or Borg Warner?
Eric
Boat doc, went to the islands up to the redneck hilton (campground)got back late sunday, first time ive been relaxed in a while
Posted By: bbrech1
Date Posted: May-21-2007 at 6:40am
I have an '89 and it doesn't seem to be any worse though the throttle, same noise no matter what RPM. There is a noticable whine compare to my uncle's '84 1:1 trans, but from what I've read it is pretty common with the early years for the 1.23:1 transmission.
Date Posted: May-21-2007 at 6:59am
your up early, they do have some early planeteries that whine, i have ran into this in the past with the 1.23's, your uncles 84 is probably a Borg Warner.
PCM's in forward will spin planetary gears causing the whining sound, I do have a ton of those planets from surplus trannies with low hours on them, you dont even want to go through PCM for that planet......it would be cheaper to buy a new trans.
The Borg Warners in forward do not spin plants because they are locked in the forward drum and spin with the forward drum, when you put them in reverse though you will here the planets creating the whine, the planet gears normally will turn 4 to 5 times engine speed and they are helical cut gears (at a angle)
the pcm's are repairable simply by swapping the planet
Date Posted: May-21-2007 at 12:46pm
Eric, my tranny is a PCM. The serial is 040 7672F. Can this be quieted down? Could you please e-mail me your phone #, I would like to talk to you about this. My e-mail is ssweber1@iowatelecom.net Thanks
Date Posted: May-21-2007 at 2:10pm
This sounds like a problem thats typical on the very early 1.23 transmissions. My uncle had the fix performed on his '90 when it was a year or 2 old. My boat also has the kit installed to quiet it down. You can see in this pic- its the 10" rubber hose sticking out of the top:
Posted By: M3Fan
Date Posted: May-21-2007 at 2:47pm
Tim, the PCM fix is to give the main valve body more volume to cure a very weird, loud buzzing/chattering noise caused soley by trans fluid under pressure in the valve body. Sounds like these guys are just talking about gear whine. The buzzing/chattering noise that the hose extension fixes sounds like an old rusty washtub on spin cycle, only at idle speed or idle out of gear. Once you power up, it's gone.
Edit- maybe it does cure the gear whine noise too, but I didn't notice any difference there. The idle chatter noise would just blow your mind that it could be caused by fluid.
2016 SN 200 OB 5.3L DI
https://forum.fifteenoff.com
Date Posted: May-21-2007 at 3:37pm
Gotcha- I forgot that you were the one who installed the kit. I didnt realize the noise was only at idle. Makes sense on the theory behind it- I figured it had something to do with decreased pressure with increased volume since the fix appears to consist solely of a 10" terminated hose!
Date Posted: May-22-2007 at 3:13pm
the hose acts like an accuumulator, in easier terms a hydraulic shock absorber, cheesy ass fix but it works, that cures the hydralic "buzzing" noise and the whine is i believe from the reverse planet, while running in nuetral or forward there is no load on the planetary gears and will whine,
Date Posted: May-27-2007 at 10:23pm
TRBeng, I got the hose from my dealer. Does it install where the sending unit is? What do you do with the sending unit?
Posted By: mjg100
Date Posted: May-28-2007 at 11:55am
Eric, I have a 1984 SN 2001 with Velvet Drive Borg Warner. After pulling a boarder when I slow down to make a left handed 180 I hear a whine. The boat has done this for years. Is this a problem?
Date Posted: May-28-2007 at 7:50pm
I installed the hose & can not tell any difference. How many years did they use these tranny's? What did they do to the newer ones to get them quieted down?
Date Posted: May-29-2007 at 7:01am
mjg, the trans will pull air on turns momentarily at the suction screen it is common for that noise to appear,
89, they started using them in 89, they have redesigned the valve to eliminate the noise, there are on thier 3rd designed valve. I never hear any complaints with the later transmissions. if it is a planet noise chances are they also made changes to the planets to quiet them.   89 you are probably experiencing a planetary noise not a valve noise. here is my number, i have late style valves and plants. 877-369-6693
Date Posted: May-29-2007 at 10:24am
89, listen to Eric- hes the expert. I have the fix installed on my boat, but M3Fan was the one who put it on.
mjg, I think the sound youre hearing is the tracking fins. They seem to whistle as you make a turn, especially when slowing down. Its the shark-fin shape that does it, as the newer ('91+) squared off fins dont make any noise.
Posted By: mjg100
Date Posted: June-03-2007 at 5:50pm
Thank you Eric.
Date Posted: June-03-2007 at 7:04pm
now i see the difference in the latest pcm 1.23 valve, they are using a larger regulator spring and counter boring the case larger to accept the spring, this should eliminate the buzzing noise completely.
