Im An Idiot! Mold and Mildew On Seats
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=6804
Printed Date: January-17-2025 at 8:45pm
Topic: Im An Idiot! Mold and Mildew On Seats
Posted By: joed
Subject: Im An Idiot! Mold and Mildew On Seats
Date Posted: May-24-2007 at 5:38am
Hi Gang,
Well... once again I'm learning the hard way!
When I put my boat to rest for the winter, I did not provide for air circulation. The new upholstery my wife and I made last year is FULL of mold and mildew.
What is the best way to clean it up? I've asked around and I get many different answers... so I thought I'd pose the question here to the true boat experts.
Any help guys?
Joe
Posted By: prossnem
Date Posted: May-24-2007 at 7:55am
I get a mildew remover from west marine or other marina most places have it. They work pretty good just follow the directions.
Posted By: ripster92
Date Posted: May-24-2007 at 8:17am
Magic Eraser worked for me, with exception of a couple real bad spots. It's probably not something you want to use all the time, because it may rub some of the pigment and protectant off also. But, for a once over, it worked great. Use a conditioner afterwards though...
Steve
------------- 1992 SN Black w/ Yellow
Date Posted: May-24-2007 at 9:32am
Steve |
I havent done this myself, but Ive heard this approach before. Definitely use 303 liberally after getting them clean.
Posted By: Ride_Klein
Date Posted: May-24-2007 at 10:23am
I've used the magic erasers and they work very well. The first time I used them on our boat I had just gotten done cleaning all the vinyl with vinyl cleaner and had one stubborn spot so I used the magic eraser. The spot I cleaned was so much cleaner I went back and cleaned all the vinyl with the magic eraser.
Keep in mind the magic eraser is good at what it does because it is mildly abrasive. I do not believe they are a cleaning product that can be used frequently without risk of damaging the vinyl. I use them once a year in the spring and then I give the seats a couple of good coats with the 303.
Remember that your seats need sunscreen just like your skin. I've used the 303 for years with very good results. Before we put up for the day I'll give everything a light coating of the 303 to keep it looking good.
Posted By: backfoot100
Date Posted: May-24-2007 at 11:43am
What the hell is a magic eraser? Never heard of it. Where do you get them from?
I have to agree with the 303 though. Good stuff.
Eddie
Posted By: jon4pres
Date Posted: May-24-2007 at 11:50am
Mr. Clean Magic Erasers. Get them at walmart with the cleaning supplies. No one knows what they are because they are Magic.
------------- http://correctcraftfan.com/diaries/details.asp?ID=1801&yrstart=1976&yrend=1980 - 82 2001
jon4pres@gmail.com
Fort Scott Kansas
Date Posted: May-24-2007 at 11:51am
Mr. Clean Magic Eraser is a household cleaning product. You can get them at most grocery stores or mega store.
Posted By: Poster112
Date Posted: May-24-2007 at 1:26pm
I've gotta ask the other question: What is 303?
------------- I'd rather have a bottle-in-front-of-me than a frontal-lobotomy. http://correctcraftfan.com/diaries/details.asp?ID=3182&sort=&pagenum=1&yrstart=1925&yrend=2009" rel="nofollow -
1985 Ski
1984 SW
Date Posted: May-24-2007 at 1:36pm
303 Protectant is a spray on wipe off cleaner/dressing, UV inhibitor/blocker, moisturizer, etc. Put it on about anything including vinyl, plastic and rubber. I've even used it on the hull of the boat. You can get it from about any boat dealer or marina or from Overtons and Barts.
Eddie
Posted By: 1998Nautique
Date Posted: May-24-2007 at 1:44pm
I used just plain soap and warm water and it worked great on my interior.
Posted By: boat dr
Date Posted: May-24-2007 at 1:52pm
303 is just that a protectant and UV blocker,full of nasty SILICONE.
Have used it on the top deck of my '64 for several years, makes the old gel look new.....these are the good features .
Bad side of 303 it took 3 hrs. of scrubbing with DAWN dish detergent to remove.Major fish-eye and bleed when test pattern of primer was sprayed.
Every good drug has side effects, so be careful when and where you use the stuff..............boat dr
------------- boat dr
Posted By: Randy_in_Ohio
Date Posted: May-24-2007 at 5:18pm
I have used the Starbright mold and mildew cleaner to remove mold. It works pretty good if scrubbed real good with a stiff brush.
Scrubbing Bubbles bathroom cleaner (the foam stuff in the green aerosol can) works excellent for cleaning vinyl. used with a stiff brush it really get the dirt out but doesn't work as well on the mold as the starbrite.
My .02 - use the starbrite mold and mildew cleaner first to remove the stains. it helps if you let it soak in for a couple minutes... then follow with the scrubbing bubbles and finally with a good heavy application of 303. This is what I did with mine and it turned out fantastic!
The PO told me he would use Murphy's oil soap to keep the vinyl clean...
------------- http://www.correctcraftfan.com/diaries/details.asp?ID=1602&yrstart=1991&yrend=1995" rel="nofollow - 1993 Sport Nautique
Posted By: joed
Date Posted: May-24-2007 at 6:54pm
Once again... you guys come thru with FLYING colors! Thank you. I'll probably start with a general cleaning with soap and warm water, followed by a cleaning with a vinyl (mold/mildew) cleaner, magic eraser for stubborn spots... then follow up with 303.
Does West Marine sell 303?
Thanks guys!
Joe
Posted By: JAG459
Date Posted: May-24-2007 at 7:54pm
West Marine sells 303 in spray bottles or by the gallon.
Date Posted: May-24-2007 at 8:10pm
Joe, Try the Scrubbing Bubbles instead of the soap and water. Spray it on and use a brush to scrub it in and then wipe it off. It really works good and you can pick up a big can for only a couple bucks. The stuff works great.
be careful with the magic eraser, I used one on a small black mark on the motor box. it took it right off, but I could see that if you used it too aggressively it could leave a sort of scuff mark.
Posted By: joed
Date Posted: May-25-2007 at 5:58am
Thanks Randy,
Will do. And let me state for the record...
I'm not a TOTAL idiot... I did place all the seat cushions in my house, so they are fine. The problem is just on the Driver's seat, seat backs, and combing(sp?)pads. My wife and I are prepping the boat today for a weekend maiden voyage.
Have a great holiday weekend gang! And don't forget to post those pics of all the lovely boats... err... I'm mean girls in bikini's, you see this weekend. ;o)
Joe
Posted By: 85Nautique
Date Posted: May-25-2007 at 9:06am
soap and water works OK but I had a small problem i used a spray bottle with part beach and the rest water I would try half a cup of beach anf the rest water and spray the effect areas
and use a strong brush or wheel brush
good luck
Posted By: Darrel
Date Posted: May-25-2007 at 2:28pm
The Magic Erasers are a high grade commercial melamine foam. Less expensive store branded should be the same and cheaper to buy. Or you can get full 4X8 sheets at industrial supply co. They are pretty amazing on everything...like others have reported they are abrasive. Good luck
Posted By: joed
Date Posted: May-25-2007 at 8:39pm
Well guys...
The upholstery came out beautiful!
I used the scrubbing bubbles with a stiff brush. Followed by warm soap/water mixture. Then rinsed throughly. For stubborn spots... the magic eraser worked well. Then protected with 303.
Thanks for all the help.
One big problem though... the boat won't start. NO SPARK! I'm suspecting blown coil. I'll go thru the test procedure tomorrow morning and post if I need help.
Have a great weekend.
Joe
