engine wont start after it is warm
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=686
Printed Date: November-24-2024 at 10:30pm
Topic: engine wont start after it is warm
Posted By: Guests
Subject: engine wont start after it is warm
Date Posted: August-01-2004 at 2:50am
i have a 96' ski natique with the 5.8 gt-40 engine. i've been having problems with the engine starting after it is warm. sometimes it will start up if i give it some gas in nuetral and other times i have to wait five minutes before it will start. other times it wont start at all. i have tried changing the low pressure fuel pump but that didnt work.
Posted By: Jamie
Date Posted: August-02-2004 at 9:43am
Sounds like it could be vapor lock? Is there a vent to the gas tank on this boat? Have you tried opening your gas tank cap? Try this after it is warm - if you hear a 'whoosh' of air when you open it, it could be a contributing problem.
1968 SN 1548
Posted By: snidz
Date Posted: August-03-2004 at 11:51pm
I had the problem once and one of the contributing factors was that the battery did not have enough Cold cranking amps to really turn it over fast enough. You need a 675 or better CCA battery. Look on the skidim.com discussion board and you will see many with this problem and lots of good advice other than the battery.
Posted By: Guests
Date Posted: August-08-2004 at 8:14pm
I have the same problem with my '94. I need to put it in neutral and give it gas to start it. I also had to set the idle mixture screw high to keep it running. Now I get yelled at for going too fast in no wake zones. It shouldn't be like that. I even changed out the carb. Any ideas other than vapor lock or battery? they have been ruled out....
Posted By: WRoll
Date Posted: August-12-2004 at 5:25pm
I had the same problem and had to replace the computer.
