Changing impeller on small outboard
Forum Name: Off Topic
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=7046
Printed Date: December-23-2024 at 11:50am
Topic: Changing impeller on small outboard
Posted By: Riley
Subject: Changing impeller on small outboard
Date Posted: June-11-2007 at 4:56pm
Anyone know how to do this? I have a 1987 9.9 hp Johnson. I've had it since new, and never changed the impeller. I know how to drop the lower unit, and access the impeller, but the tricky part is disconnecting the shifting rod. Can anyone instruct me on this?
Posted By: eric lavine
Date Posted: June-12-2007 at 7:17am
Im doing the same one right now and it is a pita, I unbolted the lower unit and you have to remove the shift rod at the top, I was instructing one of my guys how to dis-assemble and of coarse i will have to re-assemble because his brain will go soggy. the impeller is in the bottem and the biggest problem you'll have is the shifter rod
Posted By: Riley
Date Posted: June-12-2007 at 8:47am
According to a schematic, it appears that the shifting rod goes into a bracket at the top, and that there are 2 bolts to loosen. How do you get to those?
Posted By: boat dr
Date Posted: June-12-2007 at 9:08am
riley you picked a good one to learn on....you remove the shifter rod under the water intake on the side of the L/unit.There is a barrel nut w/nylon sleeve...........318-386-2825 boat dr
------------- boat dr
Posted By: Riley
Date Posted: June-12-2007 at 9:22am
Thanks boat dr. I will call you when I have the boat in front of me, and I am working on it, if I can't figure it out. I have to order the impeller. I can get the impeller for $15, or a water pump kit for $42 from Crowley Marine. Is the kit neccesary? The impeller has never been changed.
Posted By: boat dr
Date Posted: June-12-2007 at 11:09am
riley, order the assy.
That way you get all the parts and gaskets.Not a hard job, just one of the games that The Other Motor Company played.[OMC}
You can see I am not partial to Black or Silver ;Merc/Yamaha...........boat dr
Date Posted: June-12-2007 at 12:46pm
I ordered the whole kit for the reason of what the BD said, if i skimp on parts it always ends up costing me twice as what it would have originally
