swimming pool filter
Forum Name: Off Topic
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=7170
Printed Date: January-14-2025 at 5:07am
Topic: swimming pool filter
Posted By: p/allen
Subject: swimming pool filter
Date Posted: June-20-2007 at 7:32pm
I have an above ground 13,000 gal. pool. With a doughboy sand filter . My problem is that while I'm vacuming the pool , all of the algea is coming right back in through the inlet hose into the pool . I had 100lbs. of sand in which 50 was new last year and 50 this year .
please help if you can . The family of 6 will apreciate it very much .
thanks.
Pat
http://i175.photobucket.com/albums/w146/72ccfan/100_5977-1.jpg - My 72 Skier
Rock River
Dixon,ILL.
Posted By: 77stang
Date Posted: June-20-2007 at 11:45pm
we just had a 20k inground put in two years ago. here's a pool website thats very helpful
http://poolcenter.idealbb.net/idealbb/default.asp
its a lot like this site - lots of people to advise you.
good luck
http://correctcraftfan.com/diaries/details.asp?ID=1360&yrstart=1971&yrend=1975 - '77 Mustang 17
Posted By: Root
Date Posted: June-20-2007 at 11:49pm
Hey Pat, maybe I can help but its been about 20 years since I had a 24' above ground pool.
Algea is a mess, you have to shock it with chemicals and kill it and it will all fall to the bottom. Then like you stated you have to vacume it off the bottom.
I guess I musta had a doughboy sand filter also and it would be jetting green algea right into the pool also.
But their is a powder that you add to the skimmer and it makes a cake ontop of the sand and traps the algea while vacuming but the pressure of vacuming drops off and you have to backwash and start all over again and that is a pain.
or you can set the valve to vacume the algea to the ditch, but you will have to keep a hose with runnin water in the pool to keep up with the water you are taking out cause you will lose your vacume, and then add more chemicals to balance the water out that you are puttin in. but you will vacume out way faster than you can put in, another pain.
What I did was buy a DA {cartrige} filter and install it in line on the outside of the pool between the skimmer and the sand filter leaving it in there permanant and it would pickup all the algea without spitting it back into the pool,
then shut everything off and pull the cartrige filter out and wash it off insert it back and your good to go...... Then under normal use that cartrige filter will keep that pool crystal clear.
hope this helps
Root
RootRacing
Posted By: 81nautique
Date Posted: June-21-2007 at 7:07am
Pat,
I use a DE filter and the DE earth is much finer than a sand filter so nothing can pass through and back into the pool. I think Root is on the right track with a cartridge, I'd call the local pool guy and see what they say. Vacuuming to waste will work but you'll empty the pool before it's clean
There's also a chemical that will kill the algea so it falls to the bottom and can be vacuumed pretty quickly, good luck, pools are a hassle but once you figure them out you can't live without it.
Posted By: Root
Date Posted: June-21-2007 at 8:00am
Pat,     Alan is right, it was called a DE
was close on the name for how long ago it was. Theirs probably better filters out by now but that cartrige filter solved the problem
Root
RootRacing
Posted By: p/allen
Date Posted: June-21-2007 at 5:34pm
Thanks guys . I will be checking on some cartrige filters. I did look on that pool sight, and they gave me some ideas to check first . Hopefully I can figure this out soon ,so I can get back to working on the boat ,which isnt going so good right now .
Pat
Rock River
Dixon,ILL.
Posted By: jbear
Date Posted: June-21-2007 at 9:40pm
A pool? For what....warming up the boat for oil-changes? Had an above the ground 20 years ago...nothing but trouble. Finally some neighborhood kids helped me out by filling it full of BB holes to drain it. Good ridance.
john
"Loud pipes save lives"
Posted By: p/allen
Date Posted: June-23-2007 at 2:30am
These cartridge filters , are they a smaller item or is it the whole large unit?
Do you guys have a link or some pics?
Pat
Rock River
Dixon,ILL.
Date Posted: June-23-2007 at 10:19am
Pat,
I'm not too sure about the cartidges Root is refering to. I think it depemds on what type of filter you have, Not sure if they make a cartridge for a sand filter or not. I would get the make and model number off your filter and call someone like http://www.intheswim.com/ - In The Swim . They may have some suggestions.
I have a DE (Diatomacious Earth) Filter not a sand fitler and the DE is very fine like flour. Nothing gets by it and keeps the pool drinking water clear all summer.
Also if your trying to suck out green algea then you should kill it first. Ask them for an Algae destroyer and they'll need to know what type of filter you use and wether the pools filled with tap or well water. Kill it first then vacuum.
Your end solution may be to just vacuum to waste instead of back to the pool, so start filling that sucker to the top.
Jbears right, pools can be a pain but once you get it figured out there's nothing better than dippin with momma after the kids go to bed.
Posted By: mdvalant
Date Posted: November-05-2010 at 8:44pm
Olivia is from Bellevue too!!! how cool...wait...shoot.
Wonder if she skis...?
http://www.correctcraftfan.com/diaries/details.asp?ID=5009 - '90 Ski (sold)
http://www.correctcraftfan.com/diaries/details.asp?ID=5479 - '00 Sport
Mississippi River - Bellevue, IA
Posted By: 67425ks
Date Posted: November-06-2010 at 8:14pm
http://i1119.photobucket.com/albums/k623/christyjoel/81410267.jpg
one day this summer while the mercury was hovering around the 100 mark my son wanted to go swimming. no problem, pull out the dump trailer, seal the tailgate with great stuff and throw the garden hose over the side. wait 3 hours and you have a white trash mobile swimming pool.
Posted By: 67425ks
Date Posted: November-06-2010 at 8:17pm
okay, i am an idiot and dont know how to post pics. i guess you will just have to take my word for it that we have a white trash pool
Date Posted: November-06-2010 at 10:36pm
White trash pool:
Posted By: sweet77
Date Posted: April-09-2011 at 1:31am
White trash pool:
Not Nice pbrain that could be someones family members
http://www.correctcraftfan.com/diaries/details.asp?ID=5528&sort=&pagenum=1" rel="nofollow - 76 Nautique
"If you do what you always did,You'll get what you always got!"
"An empty wagon makes t
Posted By: sweet77
Date Posted: April-09-2011 at 1:32am
how old is that pic check out the "old school" "super soaker"
Posted By: adamt
Date Posted: April-09-2011 at 3:36am
Remind me again why I'm reading a four year old post?!?!!
-Adam
1973 Skier
Date Posted: April-09-2011 at 10:00pm
White trash pool:
If you read the thread carefully, you will see I was simply helping Joel out who had a problem posting the picture.
BTW, there has been some previous discussions regarding calling me "pbrain"
Posted By: sweet77
Date Posted: April-09-2011 at 10:18pm
No disrespect here sir just the first thing i think of when i see your screen name
Posted By: p/allen
Date Posted: April-10-2011 at 1:07am
I did solve this problem with some pool filter cleaner.
Pat
Rock River
Dixon,ILL.
Posted By: Gary S
Date Posted: April-10-2011 at 1:54am
I guess it all where your from,I always think of Minnesota
Date Posted: April-10-2011 at 10:32am
Gary,
It has come up though the years where I'm asked if there's any connection with the town. The answer is no and it's spelled with a "e" and not a "a".
Halston,
I understand and you're cool. I guess I shouldn't be as sensitive but the last time it happened, it was a intentional slam with someone going after me.
Posted By: sweet77
Date Posted: April-10-2011 at 1:06pm
Posted By: Alden8100
Date Posted: February-08-2013 at 2:18pm
Owning a swimming pool is one thing but maintaining it is a totally different ball game.Unless you have an automatic pool cleaner, you need to manually vacuum your pool.Use a manual brush and pool vacuum on all areas of the walls and floor at least once a week.
I also have installed recently above ground pool situating it in my garage.I read out interesting and informative ideas.This will be helpful for me.Thanks everyone...
http://www.thepoolfactory.com/swimming-pools/above-ground-pools" rel="nofollow - Above Ground Pool
