prop size
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=8527
Printed Date: September-29-2024 at 3:35pm
Topic: prop size
Posted By: 69barri
Subject: prop size
Date Posted: September-25-2007 at 3:47am
Hey i just bought a 1969 barricuda with the 318B engine. I think this is the 235 hp engine, but i am not sure. anyone know the correct prop size for this setup?? the reason is that the boat seems to take a while to plane out, and doesnt really stay on as much of a flat plane as i was expecting. any input would be appreciated
Posted By: Barracuda
Date Posted: September-25-2007 at 9:14am
Congrats and welcome to the club!
My '65 rode a little bow high- I think that's normal. The correct prop should help with overall performance.
I'll have to double check this, I'm pretty sure I had an OJ Legend 12 x 12 that worked really well on the ol 65.
------------- Former: http://www.correctcraftfan.com/diaries/details.asp?ID=759" rel="nofollow - '86 Nautique http://www.correctcraftfan.com/diaries/details.asp?ID=507" rel="nofollow - '65 Barracuda
Date Posted: September-25-2007 at 9:29am
69, Have a friend with the boat and a 318. He has a 12 x 13 Michigan on it. Do you have water soaked foam?? How are the stringers??
Posted By: 69barri
Date Posted: September-25-2007 at 12:40pm
i am not sure about the foam or the stringers, i just bought the boat three weeks ago and have not had a chance to tear into the floor or hull at all. the floor and hull seem to be sturdy, but i am not sure since these older boats often seem to have wet foam. the prop currently on it seems to be very small, like a 10 x 10 even, so it is obviously wrong.
Date Posted: September-25-2007 at 12:56pm
69barri wrote:
the prop currently on it seems to be very small, like a 10 x 10 even, so it is obviously wrong. |
Based on what? Did you pull the prop nut and read the dimensions on the hub? You wont necessarily be able to judge the size by its appearance. The 12x14 on my Tique looks miniature compared to the 12.5x15 on my '90.
Date Posted: September-25-2007 at 12:57pm
Is there a boot stripe (water line) on the boat? If it sits in the water low and you can see it with this boot stripe, then you have extra weight. Do get a proper size prop on it.
Delta (one of our sponsers) may have a used / reconditioned for it.
