Transmission Noise
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=8771
Printed Date: January-18-2025 at 7:27pm
Topic: Transmission Noise
Posted By: Edmund
Subject: Transmission Noise
Date Posted: October-22-2007 at 2:36pm
I have a 1998 SNOB (GT-40, PCM 1.23:1) that has a whistling/whirring sound between 2,000 and 3,100 RPM. It is loudest around 2,600 RPM. I took off the flame arrester, ran it, and the sound was still there. When I press in the button at the base of the throttle to disengage the transmission and rev the engine up to 2,600 RPM the sound is not present.   While cruising, I lifted the cover and listened back near the transmission, and the sound does seem to be the transmission. Is there a fix such as a different type or weight of transmission fluid? Or any other fix? The sound is not new and is not loud enough to be aggravating, but I wish it was not there.
I have read all the related discussion threads I could find here and elsewhere, and even posted this thread over at PN a while back. But a potential transmission remedy was not mentioned. What do you think? Any suggestions?
Thanks, Ed
Date Posted: October-22-2007 at 4:26pm
Edmund, have you ridden in other Nautiques with the 1.23? It sounds normal to me- the reduction tranny whines. This is a video of your same boat with the Python motor (big block, no mufflers). The transmission would be more pronounced with a quieter motor like the GT40:
http://www.youtube.com/watch?v=MAO0iIiRgk8 - Python whine
Posted By: Edmund
Date Posted: October-22-2007 at 5:13pm
TRBenj,
My ski partner has a 2000 196 with the GT-40 and has no transmission noise. [I am guessing he has the 1.23:1, but I have never looked.] The whine from the video in your link sounds similar to mine, and, as you stated, the whine is more pronounced in my boat with the GT-40. Have you heard of any way to lower/eliminate the whining sound?
Ed
Date Posted: October-22-2007 at 5:23pm
The only thing I can think of is to better insulate the motor box. My dad's 196 is quieter than mine, but still whines. Every 1.23 boat Ive been in whines to some degree.
Posted By: M3Fan
Date Posted: October-22-2007 at 6:29pm
I have the insulation kit from the 2003+ boats on my doghouse, which helps with the noise (you can't even tell if the blower is on) but the whine is still there.
2016 SN 200 OB 5.3L DI
https://forum.fifteenoff.com
Posted By: Edmund
Date Posted: October-22-2007 at 6:48pm
M3Fan,
From your post, I gather that the insulation kit quietens the whine at least a little. Correct?
If so, where can I buy the kit? From a Correct Craft dealer?
Thanks,
Ed
Posted By: M3Fan
Date Posted: October-22-2007 at 7:02pm
Mine was purchased and installed by the dealer to the tune of just under 300.00. The kit alone was over 200.00 according to the invoice but this was back in 2003 so I'd give them a ring and see what it goes for. I'd imagine it quiets the whine a bit, as well as everything else. I haven't done a head-to-head comparo but I'm guessing it helps.
Date Posted: October-22-2007 at 7:28pm
Joel, would a '98 have the same motor box as your '00? I know the '97 was different (carry over from '96).
Theres nothing special about the CC kit. They just cut the foam to match the size of the panels. Overtons sells a kit that would work. McMaster also sells sound proof foam that would work. Personally, I was going to have the inside of my motorbox Line-X'd. Its supposed to work great for sound suppression.
Posted By: M3Fan
Date Posted: October-22-2007 at 7:42pm
I think the 98 is the first year for this design of the motorbox. The 97 had the carry-over clamshell from the 95 siggie and the 96 SN's which has clearance for the InvertaFlo if needed.
I'm sure there's nothing special about the foam. It tells me that the original owner spared no expense with maintenance though, which is nice know.
Posted By: Edmund
Date Posted: October-22-2007 at 7:45pm
Great ideas. I will look around for some sound suppression material I can cut and fit. Might even check into the Line-X liner too.
Thanks guys.
Ed
Posted By: eric lavine
Date Posted: October-22-2007 at 9:36pm
There is a 3 gear planetary with spur gears on them (straight cut gears) same identical noise you get when you put your older standard shift car in reverse and back up fast, they also have spur gears and they have a tedency to whine, Ive swapped very low hour planetaries with the whinig planetaries and the noise was less , the true cure would be helical cut gears in the planets. in forward on the pcm the gears on the reverse planet do turn and with no load are louder than with a load. once again poor design jmo....spur gears havnt been used in 30 years except for in the pcm
Date Posted: October-23-2007 at 7:13am
Cheap!
Date Posted: October-23-2007 at 10:12am
cheap to manufacture, expensive to rebuild, its pretty bad when you have to insulate an engine box to disguise noise
Date Posted: October-23-2007 at 10:17am
come to think of it, i wonder if they were any quieter when the were running the heavier 20w?
Date Posted: October-23-2007 at 1:09pm
I didnt notice any difference when I made the switch to ATF. Then again, I can barely hear the whine at all now- the exhaust drowns everything out!
Posted By: Edmund
Date Posted: October-23-2007 at 6:45pm
Eric,
Would it hurt anything to try a different transmission fluid like the 20w you mentioned? If I can try, what brand/type of fluid?
Thanks,
Ed
Date Posted: October-23-2007 at 6:48pm
no, stick with the ATF, valvoline ar high quality brand, no synthetic's,
Date Posted: October-23-2007 at 6:50pm
Originally posted by Edmund Edmund wrote:
Eric,
Thanks,
Ed
It probably wouldnt hurt much, but its not recommended. I switched to ATF from the 20w this spring at the recommendation of Eric and PCM. You wouldnt notice a difference in sound anyways. Id go ahead and insulate the motorbox- that will reduce all cockpit noise. Other than that, just get used to the whine- all Nautiques with the 1.23 have it.
Posted By: 87BFN owner
Date Posted: October-23-2007 at 7:20pm
Or get a louder exhaust..
Date Posted: October-23-2007 at 7:26pm
the only thing that would quiet up a pcm is 90w gear oil, this is a joke dont try it
Posted By: M3Fan
Date Posted: October-23-2007 at 7:28pm
I'll take transmission whine over the clunky operation and tremendous reverse gear whine of the trannies that they stick in the Bu's and MC's any day. I've driven dozens of modern ski boats and no trans shifts as smoothly as the PCM trans.
Posted By: quinner
Date Posted: October-23-2007 at 7:40pm
I am thinking Edmund must be a single guy with no kids, otherwise he would be used to the sound of whining!
My dog house is insulated like Joel's, I can't say I have ever noticed any whining from my tranny either, that or I am just used to it.
http://www.correctcraftfan.com/diaries/details.asp?ID=1143" rel="nofollow - Mi Bowt
Date Posted: October-23-2007 at 7:57pm
You must be used to it. Either that or youre deaf from listening to too much Kid Rock.
Posted By: Edmund
Date Posted: October-23-2007 at 9:31pm
I guess I just can't put up with the whining like I used to since my kids are now 24 and 21. Getting cranky in my old age.
I do appreciate all of the feedback guys. I will try some insulation first.
Ed
Date Posted: October-23-2007 at 10:01pm
remember, my point of view is from rebuilding them, they are a good reliable transmission if cared for. i wouldnt pass up on the purchase of a boat if it had a PCM in it.
Posted By: Riley
Date Posted: October-23-2007 at 10:51pm
Even a velvet drive?
Date Posted: October-24-2007 at 10:23am
on the zf450 and 630 there are no planet's, no whine at all, 1 main clutch pack with reverse and forward on each side, then to gearing to the out put. niether side is considered forward because you can spin them full power for the direction you choose, if you want to put a left hand prop on the boat you can, just change the linkage, if you want a right hand engine you also can, of course you wouldnt do that, but these trannies are the reason why you no longer see right hand engines
Posted By: Riley
Date Posted: October-24-2007 at 11:35am
Eric, I'm still working on getting that Dearbomatic out of the boat. I have given up on removing the tranny from the bell housing and am now removing the bell housing and tranny from the engine. I have all the bolts out except for one bunged up one. Hopefully I will be successful soon. One problem, yesterday when I was removing the two bolts on the very bottom, I kept getting a little water on my hand when it rubbed up against the bottom of the tranny. There is no moisture in the boat, so I'm a little worried that there could be a crack in the tranny casing. I had pumped about 40 oz of water out of the tranny.
Date Posted: October-24-2007 at 11:49am
It could be just a bad front seal (or rear) on the tranny but Eric will be able to fix that. You'll be in good hands!! Even if there is a crack, the good olt TIG welder does wonders.
Posted By: Riley
Date Posted: October-24-2007 at 12:02pm
Pete, your idea of putting a 4x4 between the trusses of the garage and using a come along works great. It lifts the engine easily.
I have backed out the lag bolts out almost 2 inches, but they are still in the blocks. When I'm done for the winter, should I tighten them up, or is it ok to leaved them out?
Date Posted: October-24-2007 at 12:39pm
Bruce, You can leave them backed out as it really won't make any difference. When you reinstall and go to aligning it, you will find that you'll need them loose anyway.
Glad to hear that the lifting went well.
