Spark Plug Torque
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=8806
Printed Date: January-18-2025 at 7:02pm
Topic: Spark Plug Torque
Posted By: Randy_in_Ohio
Subject: Spark Plug Torque
Date Posted: October-25-2007 at 11:39pm
I've searched and can not find the answer to this simple question:
What should my spark plugs be torqued to?
http://www.correctcraftfan.com/diaries/details.asp?ID=1602&yrstart=1991&yrend=1995" rel="nofollow - 1993 Sport Nautique
Posted By: 87BFN owner
Date Posted: October-26-2007 at 12:12am
I think it's a matter of personal prefference. I thread them in by hand and then put a socket on it. I would bet I never tighten it more then a quarter turn with the socket.
Posted By: M3Fan
Date Posted: October-26-2007 at 12:18am
I basically just snug it up after screwing it in by hand to seat the plug. Hardly a quarter turn. It's a "feel" thing. I'm always liberal with the anti-seize as well.
Edit: After looking at my response, I realize I tee'd it up for HW and CQ on this one.
2016 SN 200 OB 5.3L DI
https://forum.fifteenoff.com
Date Posted: October-26-2007 at 12:44am
I rarely have to tighten it a quarter turn unless I didn't get it tight enough by hand. I didn't mean to imply you had to tighten it a quarter turn after putting it in by hand.
Date Posted: October-26-2007 at 1:52am
Thanks, I'll just snug them up. I know when I did the ones in my old truck they had a recommended torque, but that had an aluminum block which is probably more to stripping.
Joel, HW is going to be all over that one.
Posted By: Hollywood
Date Posted: October-26-2007 at 12:14pm
Originally posted by M3Fan M3Fan wrote:
I basically just screw a liberal well.
I thought your wife was a conservative ? Blabbing about your mistress online is a bad idea! Either way, it has nothing to do with Boat Maintenance. I am glad to hear you are doing it well however.
Posted By: boat dr
Date Posted: October-26-2007 at 12:35pm
Motors manual #41 1978 printing for years 1973/1978 says; 429/460= 15 to 20 lb. ft
                 302/351=10 to 15 lb. ft.
Good question though,always heard when in doubt,Tighten it till it strips and back off a 1/4 turn...........
boat dr
Posted By: quinner
Date Posted: October-26-2007 at 12:50pm
I basically just screw it in my hand, it's Hardly the size of a quarter. It's a "feel" thing. I'm always liberal with the anti-seize as well.
No more spanky my wanky, donger need food!
http://www.correctcraftfan.com/diaries/details.asp?ID=1143" rel="nofollow - Mi Bowt
Date Posted: October-27-2007 at 1:23pm
So, if I have a 351 Ford from 1993 I should be able to tighten them down to ~15 lb. ft. and feel good about it?
Thanks
Date Posted: October-27-2007 at 5:00pm
My dumb A** just went out to the garage to torque these down to 15 ft. lb. and cracked one of the plugs. i think it was because I had an extension on my toque wrench... Anyway, is it OK to just replace this one plug or should I replace all of them. I just replaced all of them last year and they still look good.
At least I didn't drop the straw from the fogging oil down the cylinder this year
Date Posted: October-27-2007 at 5:24pm
BTW,
I have Autolite 764 plugs installed, is this the right / good plug for my engine. This is what the previous owner installed. I'm looking in the PCM manual I downloaded and it mentions other model Autolite plugs, got me wondering... it mentions a 14mm and an 18mm ??
Date Posted: October-27-2007 at 7:06pm
Randy, which heads are on your motor? If theyre the standard E7 heads, you want Autolite 24's. If theyre the GT40 heads, then the 764's are perfect. Im not even sure if the wrong one would screw in.
You can tell which heads you have by the number of bars on the end- E7's have 2, while GT40's have 3.
Date Posted: October-27-2007 at 10:15pm
I think I have the GT40 heads. It has "GT" on the head and also has the three bars on the heads.
I'm guess I'm just going to pick up the one Autolite 764 to replace the one I broke.
Date Posted: October-28-2007 at 12:43pm
I went ahead and got eight of the 764's, since they were only $1.50 each I figured I would just change them all.
