504 Chris Craft RH
Forum Name: Off Topic
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=8925
Printed Date: December-25-2024 at 9:34am
Topic: 504 Chris Craft RH
Posted By: p/allen
Subject: 504 Chris Craft RH
Date Posted: November-07-2007 at 1:35am
Does anyone know what the diameter and pitch is of a Chris Craft 504 rh prop?
Pat
http://i175.photobucket.com/albums/w146/72ccfan/100_5977-1.jpg - My 72 Skier
Rock River
Dixon,ILL.
Date Posted: November-07-2007 at 9:26am
Pat, I'm checking and have sent a email to a friend who may know the answer. He sometimes doesn't look at his email and I know this week he is out of town but I will see him at our chapter fall dinner on Sunday. Chris had this wonderfull marketing idea ($$$) to put their own numbers on purchased parts so you needed to buy the part from them. Over the years resourcefull people have figured out and crossed the numbers over to the OEM so I know the answer is out there. Do you have this prop? I know you were looking at buying a prop but had to get a new pair of Red Wing work boots instead!!
I just had to go and buy a new pair myself only to find that Red Wing too has cut back. The good old American tradition no longer makes the A or AA width I need! I had to go with a B width for the next 8 years. Half of their shoes are also now made overseas. It is very sad. I bought the ones made in the good old USA!
Date Posted: November-07-2007 at 11:36am
Pat, Here's the answer. Sounds like you may want to consider a new prop.
"A #504 was a standard mfd by Michigan Wheel, but for Chris Craft had a special # stamped in the hub, was a type T-33, 12 X 12 right hand rotation 1" shaft. It was superceded later by Chris Craft to a #634, which was a type T-36 11.5 X 12 RH 1". The T-33 is an old Equipoise design, very similar to the modern Dyna-jet. The T-36 had slightly larger blade surface and was only sold to Chris Craft.
Among others, these screws were used on the 18' Continental w. 95HP K engine & 19' Holiday w 95 HP K.
Since these props are so old, the #504 was 30's or 40's, most have been shaved down over the years. If he is going to replace it, he should measure the radius to see what he has."
Posted By: p/allen
Date Posted: November-07-2007 at 8:10pm
Thanks for the answer Pete . I was looking at one , cheep , it maybe a good spare .
Pat
Rock River
Dixon,ILL.
