center mount ski pylon
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=9424
Printed Date: September-27-2024 at 8:28pm
Topic: center mount ski pylon
Posted By: clarkebar
Subject: center mount ski pylon
Date Posted: January-14-2008 at 4:30pm
I am going through the process of stringer replacement on my 62 Classic and I would like add a center mount ski pole but not sure how it mounts to the stringers. Does anyone have any pictures? Do I need a specific type of ski pole for this boat?
Thanks for your help
Eric
Date Posted: January-14-2008 at 5:27pm
Eric, The pylon would mount to the keel and then to the fiberglass deck section between the cockpits. There is just a hole in the floor. There are several Classics in the diaries. I'll see if I can link you to a picture showing one. If you are at the stringer stage, don't worry at this time. Are you doing a original restoration?
http://www.correctcraftfan.com/diaries/searchresults.asp?yrstart=&yrend=&model=classic&state=&Forsale=&pricestart=&priceend=&sortBy=&Submit=Search+Diaries - diaries Classics
This ring and finger I fabricated from stainless duplicating the original as close as possible. You may end up having to go that route.
Date Posted: January-14-2008 at 8:38pm
Brian,
Thanks for the pic's. I am not doing an original resto because I am missing about all the hardware and I have only 1 half a winshield. I emailed a member who had one broken a while back. I was hoping he would still have the half I needed. If not Taylor Made will do. I really would love to have a picture of how the pylon mounts to the keel. All the pictures I see just show it going through the center section. Thanks
Date Posted: January-14-2008 at 9:33pm
Eric, On your 62, I feel the arrangement is a 1" dia. main pylon shaft that goes into a short section of 1" pipe with a flange that is glassed to the keel. A cross drilled hole in both for a bolt to hold both together.
Posted By: jbear
Date Posted: January-14-2008 at 10:55pm
Who in heck is Brian Pete? I am so confused.
john
Date Posted: January-15-2008 at 7:09am
John, I've been called worse!! I think we all have!! At least Eric hasn't refered to me as a "Q tip" - yet. He probably hasn't seen a picture of me and doesn't know!
