Rudder Rattle
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=9427
Printed Date: November-15-2024 at 9:48pm
Topic: Rudder Rattle
Posted By: Greg_SA
Subject: Rudder Rattle
Date Posted: January-15-2008 at 7:44am
Hi,
I have a 1989 SN2001. When I turn the steering to full-lock and put the boat into gear, I get a rattle, which I assume is the rudder. It only occurs near full-lock when I turn to pick up a rider. At less sharp turns, it doesn't rattle.
I checked the rudder and there is quite a bit of play in all directions (side to side and back to front).
What hold the rudder in place besides the "stuffing box"? Are there any other seals on the rudder that might be worn? Or is it the shaft itself?
Thanks,
Greg
Date Posted: January-15-2008 at 7:52am
Greg, Try taking a couple turns on the packing gland nut. The stuffing box is what holds the rudder. You may consider replacing the packing but usually just tightening will do it. If you do repack, standard waxed flax (not the high performance teflon packing) works fine. There are no seals or bushings. Check for play in the helm too.
Posted By: Greg_SA
Date Posted: January-15-2008 at 10:06am
Okay, I try tighten it up a bit...
I hope that helps, because the packing gland is at the too of the rudder shaft, and there is play between the shaft and hole at the bottom of the boat.
Surely the rudder shaft can't be worn?
Posted By: eric lavine
Date Posted: January-15-2008 at 10:28am
match book...
i think the rudder shaft goes into a port that has pretty tight clearances, this is on larger boats that i have replaced in the past. i would think it would be the same on these, i replaced one this summer in which the rudder snapped off and i only ordered a rudder and it wouldnt go up through the rudder port because that took a shot too. i ended up ordering a port also and from memory its a pretty close, no side to side fit, the shaft also could be worn
Date Posted: January-15-2008 at 10:37am
Greg, Eric is correct that in extreme cases you need a new rudder and port. It is a brass to brass wear point and would need a lot of use to become unuasable. I say extream because even on the pre war boats I've worked on it has never been a issue.
Posted By: Barracuda
Date Posted: January-15-2008 at 11:17am
Do you mean that the packing nut cannot be tightened any further? If that's the case, then Pete's right on- replace the packing.
Does it leak?
Former:
http://www.correctcraftfan.com/diaries/details.asp?ID=759" rel="nofollow - '86 Nautique
http://www.correctcraftfan.com/diaries/details.asp?ID=507" rel="nofollow - '65 Barracuda
Posted By: Greg_SA
Date Posted: January-15-2008 at 11:30am
I haven't checked if it leaks. Next time I'm out, I'll have a look and tighten it up... If it still leaks, I'll replace the packing.
Anyone know what size packing rope it will use?
Date Posted: January-15-2008 at 11:43am
Greg, It should be 1/4".
Date Posted: January-15-2008 at 12:04pm
Actually, that could be anyones guess. CC seemed to switch between 3/16" and 1/4" randomly. My '90 took 3/16" in both the driveshaft and rudder.
Date Posted: January-15-2008 at 2:20pm
make sure that rattle isnt a loose prop also, the rudder may be loose but it may not rattle under load
Posted By: Greg_SA
Date Posted: January-16-2008 at 4:26am
Thanks Eric... I have checked - the prop isn't loose.
