trailer brakes
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=954
Printed Date: April-18-2025 at 9:31pm
Topic: trailer brakes
Posted By: hyper1685
Subject: trailer brakes
Date Posted: October-26-2004 at 8:36pm
i have an 86 SN 2001 with a factory trailer. where can i get trailer brakes for it? can i get trailer brakes for it? also, where can i get new bearings for the axles?
thanks,
chris
Posted By: Rick
Date Posted: October-26-2004 at 10:34pm
I like UFP for brakes www.ufpnet.com The seals and bearings can be obtained from any parts store. Take one wheel off clean the 2 bearings and 1 seal with solvent and take them to the store. They should bne able to cross reference the p[art numbers on the bearings and seal.
------------- http://www.correctcraftfan.com/diaries/details.asp?ID=250&yrstart=1996&yrend=2000%20" rel="nofollow - 2000 Ski
Posted By: IrishFooter
Date Posted: October-27-2004 at 12:48pm
Check your yellow pages for a bearing distributor in your area. I have a bearing distributor around here byt the name of Eire bearings that gets parts for me a lot cheaper.
------------- 1979 Ski Nautique
Posted By: mrese
Date Posted: October-27-2004 at 3:21pm
Atwood Mobile Products put the surge brakes on my 89 CC trailer. I like the posi-lube system that came on the stock wheel hubs. It makes it so easy to lubricate the wheel bearings and also does an excellent job of sealing the bearings againt water and dirt intrusion. They have a website you can look at.
Date Posted: October-27-2004 at 10:02pm
Can i install the brakes myself? all of the brakes i have seen are universal; do how do i know what to get? electric, surge or hydrolic?
Thanks,
Chris
Posted By: David F
Date Posted: October-28-2004 at 1:22pm
All brakes are hydraulic. The hydraulic system is either activated electrically or via trailer surge. Electrically activated brakes require specialized systems or wiring in the tow vehicle whereas surge brakes do not. Hence surge brakes are more widely used/common.
It all depends on how handy you are with tools whether or not you can install the brakes yourself. Only you can answer that question, special tools may or may not required. Welding may be required.
Posted By: Bill336
Date Posted: October-28-2004 at 1:42pm
Just an FYI - My last trailer had electric brakes. They apply brake force with a magnet in the assembly that is controlled with a brake controller in the truck (usually wired into the brake lights.) There were no hydraulic components in it at all. This doesn't apply to electric over hydraulic.
Posted By: gjsullivan
Date Posted: November-12-2004 at 4:39am
try
http://www.championtrailers.com/
Great site, good stuff, great self help instructions and tech support.
You may want to look at disk brakes.
Glenn
