Warning for Boat Nurse
Forum Name: Off Topic
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=9689
Printed Date: December-26-2024 at 8:11am
Topic: Warning for Boat Nurse
Posted By: Behl
Subject: Warning for Boat Nurse
Date Posted: February-21-2008 at 9:00pm
INSTALLING A HUSBAND
Dear Tech Support,
Last year I upgraded from Boyfriend 5.0 to Husband 1.0 and noticed a distinct slow down in overall system performance -- particularly in the flower and jewelry applications, which operated flawlessly under Boyfriend 5.0.
In addition, Husband 1.0 uninstalled many other valuable programs, such as Romance 9.5 and Personal Attention 6.5 and then installed undesirable prog rams such as NFL 5.0, NBA 3.0, and Golf Clubs 4.1.
Conversation 8.0 no longer runs, and Housecleaning 2.6 simply crashes the system. I've tried running Nagging 5.3 to fix these problems, but to no avail.
What can I do?
Signed, Desperate
Dear Desperate:
First keep in mind, Boyfriend 5.0 is an Entertainment Package, while Husband 1.0 is an Operating System. Please enter the command: 'I Thought You Loved Me.exe' and try to download Tears 6.2 and don't forget to install the Guilt 3.0 update.
If that application works as designed, Husband 1.0 should then automatically run the applications Jewelry 2.0 and Flowers 3.5.
But remember, over use of the above application can cause Husband 1.0 to default to Grumpy Silence 2.5, Happy Hour 7.0 or Beer 6.1. Beer 6.1 is a very bad program that will download the Snoring Loudly Beta.
Whatever you do, DO NOT install Mother-in-law 1.0 (it runs a virus in the background that will eventually seize control of all your system resources).
Also, do not attempt to reinstall the Boyfriend 5.0 program. These are unsupported applications and will crash Husband 1.0.
In summary, Husband 1.0 is a great program, but it does have limited memory and cannot learn new applications quickly. You might consider buying additional software to improve memory and performance. We recommend Food 3.0 and Hot Lingerie 7.7.
Good Luck, Tech Support
Steve in Indy
http://correctcraftfan.com/diaries/details.asp?ID=1702&sort=&pagenum=1&yrstart=1976&yrend=1980" rel="nofollow - Redone 1977 Ski Tique
