PCM351 Cutlass Bearing ?
Category: Buy and Sell
Forum Name: Boat Parts Wanted
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=9827
Printed Date: November-19-2024 at 6:06pm
Topic: PCM351 Cutlass Bearing ?
Posted By: GarethC
Subject: PCM351 Cutlass Bearing ?
Date Posted: March-10-2008 at 10:52am
Hi Guys - the marina have informed me that I need a Cutlass Bearing that has a 1" internal diameter but is 6" long...
Does anyone know what this is or where I would get one? They have tried UK based places but apparently they are usually 4" long so it is an unusual shape.
Any help very much appreciated, as this part is holding up getting our boat back ready for spring.
Cheers
Gareth
------------- http://www.correctcraftfan.com/diaries/details.asp?ID=2197
Posted By: M3Fan
Date Posted: March-10-2008 at 3:12pm
If I'm not mistaken you should be able to substitute two smaller bearings instead.
------------- 2000 SN GT40 w/99 Graphics/Gel 2016 SN 200 OB 5.3L DI https://forum.fifteenoff.com
Posted By: 1969cc
Date Posted: March-10-2008 at 4:18pm
Gareth
Check the link below. They list a 1" X 6" strut bushing.
http://www.pacificmarine.net/metallic.htm - http://www.pacificmarine.net/metallic.htm
------------- If you see light at the end of the tunnel you might be looking the wrong way
http://correctcraftfan.com/diaries/details.asp?ID=3674 - 69 Mustang
Posted By: GarethC
Date Posted: May-07-2008 at 1:55pm
Hi there
Thanks for that post 1969cc I got the one I needed. But know the marina say my prop shaft is bent so I need one of those, they also say I need a new front end cutlass bearing for where the shaft meets the hull. Do you know if this would be the same size as the one I have already purchased?
Cheers
Gareth
Date Posted: May-07-2008 at 3:04pm
GarethC wrote:
Hi there
Cheers
Gareth |
???? They must mean the packing in the stuffing box. There isn't another cutlass bearing. If it is the stuffing, I'd recommend the Goxtex. It is almost dripless.
Posted By: GarethC
Date Posted: May-08-2008 at 9:00pm
Thanks 8122 yeh I guess they must mean the packing stuff, they have also told me they have found a place in scotland that will custom make a prop shaft for me?! Do you think that sounds sensible (they have the bent one to go by) or should I just buy one from skidim.com or likewise.
I take it the 88 prop is the same as the 89 or does the different gearbox make a difference?
Cheers
Gareth
Date Posted: May-08-2008 at 10:25pm
GarethC wrote:
I take it the 88 prop is the same as the 89 or does the different gearbox make a difference? |
Gareth, theres quite a difference. The stock prop for an '88 (1:1) is a 13x13, where the stock prop for a '89 (1.23:1) is a 14x16.
