63 Classic windshield wings???
Category: Buy and Sell
Forum Name: Boat Parts Wanted
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=9925
Printed Date: September-16-2024 at 4:03pm
Topic: 63 Classic windshield wings???
Posted By: 63CCCOuch
Subject: 63 Classic windshield wings???
Date Posted: March-23-2008 at 3:21am
My boat has the chromed pot metal bracket with the pivot holes but no wings or blade inserts. It looks to me like the ones in the picture have been "dreamed" up like I am trying not to do without seeing an actual original pair. See attached pic (actually I am going to try to attach a picbut never did before)and my red lines indicating how one side has a straight line and the other has a slight curve as if they just scroll sawed a couple pieces of lexan and slotted out acorn nuts or some other "too small to be strong enough, but good enough for ebay" attachement point to the clear material at the pivot points. It seems to me there needs to be some small metal channels with a pivot stud that are fixed to actual tempered glass blades or wings. I am hoping to make the pivots and get the glass baked, but not without getting a hold of an actual set for actual measurements and properties. Did all 63 classics come with the brackets? I wonder how many models/years used the same setup? So many questions.......
------------- You guys are all wet!
Posted By: boat dr
Date Posted: March-24-2008 at 2:25am
63 give me a call I have the same set up on my '64 and we will talk wind wings................1-318-386-2825 billy
------------- boat dr
Date Posted: March-24-2008 at 7:47am
Ray, Though all the years that the wings were offered, to my knowledge they were all the same set up. I do know that they were not made by Taylor or any other winshield manufacturer. The pivot set up you describe is original and the weak point. One bump with a elbow and the parts are at the bottom of the lake! The actual wings are the easy part as they can be cut but any of the missing hardware needs to be fabricated up and most people don't have that capacity. Whatever you come up with (the channel sounds good) you should make several sets - I think people will be knocking on your door!!
Date Posted: March-26-2008 at 3:01am
I have installed protective tempered glass over classic tiffany type church windows where we took the previous attempt out of lexan which dulled and faded to a matte yellow and used it as a template. The resultant glass product is tough as nails (or broken into little 1/8" chunks in an instant) I have yet to see one break. I am only going by what happens when i send one of my fork trucks through a vehicle side window. Anyways, seems if we couple this type of glass with some kind of billet or ss channel siliconed to the glass we will be half way there. We still need to come up with some kind of friction clutch to hold it steady and allow it to "fold" under impact... I still have never seen a stock setup.
