  New Posts New Posts RSS Feed - Timing
Timing
xtremeshotz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote xtremeshotz Quote  Post ReplyReply Direct Link To This Post Topic: Timing
    Posted: July-25-2011 at 1:46am
Thanks for all the advice, got it running good now!!!!!!!
xtrmeshotz
boat dr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boat dr Quote  Post ReplyReply Direct Link To This Post Posted: July-25-2011 at 1:09am
Only the inner hub is keyed, followed by a rubber bushing with the outer rotor pressed over this sandwich. And yes they will slip....
Keeganino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keeganino Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2011 at 9:08pm
Doesnt the balancer have a keyway to keep it from slipping?
1973 Skier
surroundsound64 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote surroundsound64 Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2011 at 4:32pm
Just power time the thing. It's a fine line but you're looking to keep it from pinging at high rpm while still running at idle. Also, back firing is a bad thing. Probably looking 9-12 degrees BTC, if your balancer hasn't slipped any.
1981 Ski Nautique
2000 SAN
Looking for a 2000-2006 SAN
Luchog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luchog Quote  Post ReplyReply Direct Link To This Post Posted: July-23-2011 at 1:08pm
Hi, what's the condition of the engine?
Post Options Post Options   Thanks (0) Thanks(0)   Quote xtremeshotz Quote  Post ReplyReply Direct Link To This Post Posted: July-23-2011 at 1:10am
What should my timing be set at on 1986 SkiNautique 2001 with Ford 351 and electronic ignition?
xtrmeshotz
