DIY surfboard |
Post Reply | Page 12> |
Author | ||
Mark Mel
Gold Member Joined: September-16-2005 Location: United States Status: Offline Points: 583 |
Posted: June-28-2012 at 2:36pm |
Nope not a graphic designer but have played one designing logos and t-shirts for all of the bands I have been in.
skutsch
Grand Poobah Joined: June-19-2008 Location: Racine, WI Status: Offline Points: 2874 |
Ha, and upon further review, I missed the subtle-ness of the overall shape of the brand (surfboard) all pulled together with the darker center board and edge boards both on the brand and deployed on the actual product - That is one of the best brand marks I have seen in a long time. Are you by chance a graphic designer - really well thought out. Its almost as impressive as the board itself! |
Mark Mel
Thanks, I'll take better pics when I fix the issues that I'm not happy about.
skutsch
Wow, That is absolutely beautiful. Great branding design as well, I love the "MM" shaped waves. AWESOME!
Jllogan
Platinum Member Joined: May-18-2011 Location: canton, OH Status: Offline Points: 1728 |
awesome
Mark Mel
Well it's glassed and glossed with the epoxy resin.
Had some trouble in the gloss coat with fish eyes, did the bottom twice, first time had fish eyes, scraped the uncured resin off. Sanded that and recoated, fish eyes again. Did the deck came out better but still some fish eyes. Going to leave it for now since I'm going to be in the Cape this weekend and I want to get it into the water. In a couple of weeks when I have time, I'm going to sand off the gloss coat and recoat with spar varnish. I've seen wooden boards done with the spar varnish and they look nice. Here's some pics. Intentionally crappy pics to hide the irregularities in the finish. The mark on the bottom by the tail near the finbox is a brand that says Handcrafted By My Name. I forgot I had it. My wife had the branding iron made when I was making furniture. I'd show a close up but the finish is lots of fish eyes there. The pink in the fin plugs is play dough that I haven't dug out yet. |
dwcar
Platinum Member Joined: February-11-2007 Location: Houston Texas Status: Offline Points: 1103 |
that is cool Mark!
83Ski
Jllogan
I am also a musician, and Im a bit of a gear nut and do some basics, mostly along the lines of the electronics routes, built a few small amps and some stompboxes. I would love to build a guitar but I think I lack the woodworking skills to make something I would like. Also Im pretty so I would be worried I would spend alot of time and money and not like it. |
Mark Mel
No kit it's all DIY. I designed it in a program called Aku shaper and someone created a plug-in for it that will take that shape and export the frame template to .pdf fullsize that you can use to cut out your frame.
Thanks, I am a musician and I have built tons of things, speakers, lyrics box, do my own guitar setups and repair but I have never built a guitar from scratch. It's on my list of things to build. |
Jllogan
wow ya, put some strings on it and play it! Excellent wood working, maybe your next project could be an acoustic guitar, I may to commission one.
jbear
I am so impressed by the work some of you guys do...
just beautiful Mel...don't forget the finished product pictures. john |
"Loud pipes save lives"
FINS
Senior Member Joined: August-04-2007 Location: United States Status: Offline Points: 170 |
Very nice work. I have been looking at making one for quite some time and just never got around to it. Did you use a frame kit, patterns, or just wing it yourself?
C-Bass
Platinum Member Joined: November-18-2008 Location: Columbus, IN Status: Offline Points: 1248 |
Awesome work. That will be functional piece of artwork when you're done.
Mark Mel
Well, I'm certainly no expert, I wouldn't even consider myself a real surfer, but most modern boards are foam. The kids that do all the cutbacks and spins like a very light and thin board like a potato chip. Not many surf wood here.
The longboarders, mostly older will surf a hollow wood board because they like the feel and the way they float. They are also coming back for the nostalgia factor. The weights can be very similar but a similar foam board will usually weigh less. Some don't find this a detriment in the water and prefer the way the hollow wood board floats and feels. Mine weighs 17 lbs right now without the glass - we'll have to see what the final weight is, I'm hoping under 20 lbs. Typical 9'0" foam longboard weights range from 15lbs for a lightwight to 25 - 30 lbs for a noserider. Taken from Paul Jensen's site - his boards were an inspiration for mine. "Imagine surfing waves on a board with a distinctive resonance in the water, similar to an acoustic guitar that has morphed into the perfect surfboard. The air core and tensioned wood skins of a hollow wood board allow for a unique energy transfer between the wave and the rider. The feeling of the wave is amplified on a hollow, it has a more alive feel. Once you’ve ridden a hollow wood board, foam boards feel dead… A hollow wooden board feels a little heavier on land than that a foam board, but due to the board having an air core, feels lighter once it is in the water. The weight advantage of hollow board has the benefit of more momentum when paddling, catches waves easily and rides smoother. Hollow wood boards also allow you to ride further on a wave than a lighter foam board. If you are into “busting airs” you are better served with as light a board as you can find and that isn’t a wooden hollow, but if you prefer to ride smooth and flow on a wave, a Jensen Hollow Wood Surfboard is the ultimate surfing pleasure…" |
peter1234
Grand Poobah Joined: February-03-2008 Location: United States Status: Offline Points: 2756 |
what are the comparisons of foam cored resin or epoxy coated v.s wood ? are the weights comparable? advantages disadvantages?
MI-nick
Gold Member Joined: January-12-2009 Location: Ypsilanti, MI Status: Offline Points: 809 |
awesome
As far as I can tell, I'm not quite sure...
Mark Mel
No foam here. All wood, new school shape, old school materials.
I was going to do a foam board but the shipping on blanks costs as much as the blank. |
kapla
foam or not foam?...lol
nice work there! |
<a href="">1992 ski nautique
Mark Mel
The rails are built up using 3 layers of 1/8" cork and then a layer of 1/8" plywood. I did this for 4 layers for a total of 2". Went with all cork on the outermost layer.
I was thinking of doing a gloss coat(s) of spar varnish. I don't get to surf that much so it won't be out in the sun much so I'm still thinking if I'm going to do the varnish. I won't be using polyester resin, it smells and hollow wood surfboard builders haven't had much luck with it at all. |
Be real careful and do check out just how good the UV inhibitors are. I've run into several Cedar strip canoe builders that have had poor results. The preventative fix is to give the epoxy 4 to 5 coats of the best spar varnish available. When you mention "poly", I take it you mean a polyester resin. Watch out for it as well since it's hygoscopic. |
BuffaloBFN
Beautiful! How did you say you did the edges?
Mark Mel
Yeah; The CE Epoxy has an optical brightener (bluish tint) and a UV inhibitor.
Dries crystal clear. All the surfboard builders are using it if they're not using Poly. |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21138 |
Mark, is that Resin Research epoxy something special with UV inhibitors? I know regular epoxy resin is not UV resistant. I cant see the pics, but it sounds like something you wouldnt want the epoxy to turn yellow or get murky over!
Mark Mel
Thanks, I am just doing clear over it. 2 layers of 4oz glass on the deck and 1 layer on the bottom, with Resin Research epoxy.
The cedar should really pop with with clear and the rails are cork layers alternated with ply. Those will look good with the clear on it too, I hope. |
Kristof
Grand Poobah Joined: October-08-2007 Location: Bree, Belgium Status: Offline Points: 3391 |
That looks simply awesome!!!
Pete's right... Just clear coat on it... Damn, that woodwork looks nice! |
That board sure looks fantastic. I hope you are going with a clear finish on it. It would be a shame to cover up that great woodwork.
Mark Mel
Nah I'm probably spending around $400 all in. Can't get a longboard for that price. Maybe $450 but that would a machine made mass produced pop out. A board like this would start at 4x that.
Plus I'd rather surf something I made. ;-) |
Wacko
Senior Member Joined: March-21-2009 Location: BC, Canada Status: Offline Points: 293 |
Wow that looks great!!! I got to think you can buy one for less than what you have into that?
SNobsessed
Looks too pretty to put in the water!
OverMyHead
Grand Poobah Joined: March-14-2008 Location: MN Status: Offline Points: 4861 |
Wow, way ambitious.
1987 Ski Nautique |
