Strange Sound |
jbear
Posted: June-12-2006 at 9:17pm |
JEFF: You are sounding to close to the jbear's PX for noise reduction.
BTW: Why would anyone want their boat quieter anyhow??? john |
"Loud pipes save lives"
JEFF KOSTIS
TO FIX PROBLEM: Just idle it in gear while kicked back and enjoying a cold one! Noise GONE!! Jeff.. |
CC Fan
Newbie Joined: May-17-2006 Location: United States Status: Offline Points: 10 |
My 78 Tique does the same thing. Seems to only do it turning right..
Roger |
1978 Ski Tique
Nautique2001
Grand Poobah Joined: June-14-2004 Location: Massachusetts Status: Offline Points: 2832 |
Thanks again! One less worry. Is there a way to quiet that noise a little?
Ken |
NAUTI84
Senior Member Joined: June-10-2004 Location: United States Status: Offline Points: 485 |
Hey Ken,
If I remember right (been so long since I used my boat) mine does the same. I think you actually hear it turning in one direction and not the other. I thought I had been told it had to do with the prop rotation. Anyhow, I know it feels good to know it's normal! |
brandons
Newbie Joined: April-03-2006 Location: United States Status: Offline Points: 8 |
My 79 Nautique makes the same noise when im turning real hard at a moderate speed. My buddy's 81 makes the same noise. It sounds like the power steering pump in my old Ford truck when you turn it.
1979 Ski Nautique
The Lake
My 69 makes similar type noises going through semi hard turns.
Nautique2001
Thanks, guys. It's certainly a noise you don't hear everyday. I just wanted to be certain that it wasn't some sort of defect.
Ken |
Hollywood
I'm a fan of the fin growling
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Online Points: 21138 |
Actually, it comes only from the fins. You'll notice that all the Nautiques with the shark shaped fins do it. Our '88 did and so does my '90. Our '92 didnt since they changed to a squarer fin design in '91, I believe.
surroundsound64
Senior Member Joined: June-22-2005 Location: United States Status: Offline Points: 151 |
It's noise from the fins and rudder and prop. Perfectly normal.
1981 Ski Nautique
2000 SAN Looking for a 2000-2006 SAN |
Nautique2001
Yes, it does change pitch as you turn. I don't think I'm hurting anything. It must be water noise or something. I just wanted to make sure it wasn't just happening to me.
Ken |
2_Nautiques
Senior Member Joined: March-22-2006 Location: United States Status: Offline Points: 251 |
Does the sound change in pitch as you slow through the turn? Mines does this occasionally. I believe it comes from the rudder. doesn't sound like anything is broken, more like wind noise except it is underwater.
Nautique2001
For you 2001 model hull owners, do you guys hear a weird "wurring" sound when you cut the wheel hard at lower speeds? It doesn't come from the engine or transmission from what I can tell. It almost sounds like an animal moaning or a stomach growling. I hope I don't sound crazy, but I'm trying to figure out what that sound is. It's at about 8-10 MPH with the wheel cut hard. My 1980 never made that noise.
Ken |
