86 SN rebuild |
Post Reply | Page <1234 11> |
BuffaloBFN
Pete, the biax adds mega strength compared to cloth or matt. I wouldn't pass on it and used more than 1 layer in some places. Something else I think has been left out of these discussions recently is a green lay-up vs. a cured lay-up.
Ranger
Senior Member Joined: August-23-2010 Location: San Diego Status: Offline Points: 151 |
I thought that if you were using epoxy, you wouldn't necessarily need to use mat. Epoxy supposedly has enough strength without it.
I would like to bed my stringers in at least 1 3oz strip of mat. Maybe 2. Then take the 2, 4 and 6 inch cloth and tab the stringer to the hull, using opposite 45% angles for each. Then, wrap the entire stringer with a 3 oz mat and cloth. Once each stringer is finished, use mat and roven in the bilge, between each stringer and outboard of the secondary stringer up the side of the hull. (Hopefully this makes sense) I'm assuming that I can use biax in place of the mat. What do you think? As far as green versus cured, I would certainly like to complete the entire layup before it cures, but I don't think I can move that fast. I'm going to call a couple of distributor’s tomorrow, but what am I missing? Jeff |
BuffaloBFN
I'm on an unfamiliar computer or I'd link it. Check US Composites description of #1708 biax. Biax and matt are way different.
As for green, I wanted to bring it up mostly. For my project, I planned to do the lay-ups for 1 main for example before it cured so that each 'element' would be 'one'. |
Jeff,
I don't feel you missed much and your plan sounds good except the 3oz. is on the light side. The biax is worth considering but I've never seen any decent comparison figures on it. I am glad Greg mentioned the green layup. It's preferred for max strength and if you have all the glass precut lay up does go fast. If it does set up on you, all you need to watch out for is the amine blush but it comes off with a light soapy water. Whatever glass you do you use, make sure it's "E" glass. |
Ranger
I just read the U.S Composite web site a bit on Mat versus Biax. They do have mat for epoxy, but the majority of them are for vinylester or polyester products. The 1708 biax will eliminate the mat.
So, I could use the 2, 4, and 6 inch strips of e-glas to tab them in. Use the biax and cloth over the entire stringer. What would you use to bed the fir to the hull. West systems says use a mixture of their products, but I think I would feel better with something like mat or maybe biax between the fir and the hull. Then I guess I would use the biax and then roven in the bildge. Thoughts? |
If the stringers are scribed well to the hull, not much is needed. Some have used a strip of mat but I feel thickened epoxy (with cabosil) is just as good and sure is easier. Lay a bead down and set the stringers in place. You'll be filleting the bottom edge with it anyway so you can actually fill the minor gaps at the same time. Get some of the empty caulking tubes, make a batch of cabosil/epoxy and force it into the gaps. Then go over it with a squeegee with the radius cut into the corner. |
BuffaloBFN
Pete, the proof for biax is holding it in your hand. The 1708 has a matt back and the roving on '2 axes'. I think biax is a modern improvement on roving.
Again, the green thing is picking a part and finishing it...and yes with pre-cut pieces. We have no choice on starting from the dry hull, but planning I think is the key. |
I agree with Pete on bedding the stringers instead of using mat. I don’t think you can scribe them perfect enough to not have gaps larger than the mat can fill.
I laid a bed of epoxy thickened with cabosil and milled fiber for extra strength (like your laying brick) Gently set the stringer in place and let the weight of the stringer squeeze out the excess (give it a tap or two if need be) like edge gluing boards you don’t want to squeeze all the adhesive out. I also put a layer of mat on the stringers before installing them. As for lay-up it’s I found it was pretty hard to do the whole layup at one time you only have about 20min. of pot life and that time goes fast while you’re trying to adjust everything as you go. It’s better to take your time and do a little sanding between coats if need be. And don’t forget to coat everything with CPES before you epoxy it. |
Ranger
Thanks guys, I appreciate the info. I'm going to call a few distributors tomorrow and see what they have to say. You are probably right when you say that I can't scribe the stringer in tight enough. If I use thicken epoxy with cabosil, I'll have to be careful about too much weight on the stringer. I don't want to squeeze everything out of the bed.
I'm also going to use all 2X fir, even on the secondaries. I haven't laid it out yet, but I am going to change the cradle bolts to be through the stringer with nuts. No lags, if I can help it. I will double up the secondary in front of the exhaust and run it all the way to the front of the cradle. Since I am using 3/4 ply for the floor, it will also serve as the edge to the doghouse. Thanks again for the help. Jeff |
Limiting the mixed batch size of resin to what is needed in 20 minuits really helps. Keep in mind it may "kick" in 20 but is still "green" for hours. Make sure you buy the metering pumps along with the resin/hardener. If in doubt about the hardener speed, favor a slow hardener. YES, don't forget the CPES!! |
Ranger
Thanks,
Yes, I am going to use the CPES and I will order the mixing pumps as well. |
behindpropeller
Ranger-
While you are doing the rebuild please consider replacing the shift system with a morse MV-2 which has a safety lockout. The MV-1 which is original on your boat does not have a lockout. Tim |
The Biax saves a lot on labor.. but isnt cheap and sucks down resin which is of course money and weight... But a completely reasonable way to go... but perhaps a little overkill for me if you are using good fir stringers..
I try to work with the tapes as much as possible as they are a relatively efficient way to work both in terms of time and epoxy per strength added. Throwing another layer of tape in a particular area is something that can be done easily and without sinificant overruns in the budget.. each layer of biax is felt in the wallet. In terms of Mat I disagree with Pete's comment on the 3oz being too light... 3oz would be a massively oversized mat for general use. Mat is measured in weight per sq foot not the wieght per square yard used in the cloths. 1.5 oz mat laminates more than twice as thick as 18oz woven roving... and is the highest density mat I would try to work with epoxy. Stitched Epoxy mat still appears to unobtainium for the time being so you would need to use regular mat.. the supply houses are all saying 1.5 oz mat works acceptably with expoy and I have heard reports back from the boys around here that is the case but 3.0 oz would be pushing it. Besides 3oz is going to laminate over a tenth of an inch thick... overkill for many of the uses. Call me old fashioned but with the fir I would be tapes, cloth, and 1.5 oz mat where I was looking to add thickness for durability, like on an impact surface... and I like mill fibers and epoxy for bedding and filleting however there are many acceptable ways to skin that cat as well. |
Correction!! Sorry as I missed it was mat! I thought it was cloth! |
Keeganino
I would bed in thickened epoxy. I used aerosil and put a bunch of weight on top while it cures. Then came back and made a nice big fillet.
My advice on laying up the tape is to do each section all at once. I used the 2", 4", and 8" tape layup followed by 12" biaxial. At first I tried to go all the way around the whole stringer with 2" then came back after that set up and layed the 4 and so on. As I got better at it I found that it lays up way better if you do one section at a time and lay up all the tapes at once- wet on wet. I got less air bubbles this way and it moved much faster. You cant lay a strip of tape longer than you can spread your arms so do one arm's length at a time. Pre cut all the tape lay it out on a piece of ply with the cheapest disposable plastic drop cloth you can find on top, wet it all out on the plastic and then lay it down and roll out the bubbles. If I did another rebuild I might skip all the tape and just use biaxial. It makes all the other glass material seem mickey mouse. Once wrapped in biax the stringers became granite solid. |
1973 Skier |
Keeganino
I cant say enough about how good the biax is. My friend who built offshore race boats for 25 years said that when they were not using kevlar they used biaxial and that was it.
1973 Skier |
Waterdog
Ranger,
Take your time fitting the stringers to the hull. Use resin thickened with mil fiber to bed them in. Not fumed silica, cab o sil is nice in gel coat or in a fillet that needs to be astetic(sp) pleasing but isn't as strong as mil fiber. If you put glass cloth on the bottom of the stringer it's just another bond to fail in the future. CPES treated fur + resin,mil fiber + hull AND you can't put to much weight on it to squeeze it all out. Optimum bond line thickness .005mil (in) I can in a 100psi autoclave but not at home. |
Ranger
I just spoke to U.S. Composites and here is what he suggested.
First, use Fasco 110 Epoxy Glue to bed the stringers. Then use the 2, 4 and 6 inch E-Glass tape for the stringer to hull joint. Then use 2 layers of 6 oz cloth over the top of each stringer. Tie all of it together with a layer of biax in the bilge and between each stringer. Since I have gel coat cracks that will need to be addressed, he recommended that I run roven up the sides under the gunnels. He also said that I should use the 635 epoxy with medium hardener. What do you think of the Fasco product? |
That's exactly how I did mine except with a layer of 1.5oz mat applied first before installation. I also went a little heavier on the cloth I went with the 7-1/2oz. I didn't go all the way to the gunnel's but I did go 10-12" or so up the sides. I feel that's one of the most important areas as it ties the floor to the walls for support. The glue looks very interesting I'll have to try some. Andy, I tried just the milled but found it tended to run and sag no matter how thick I mixed it. Cabosil helped make the paste more manageable and mold-able. |
Keeganino
I have not heard of anybody using fasco. I would stick to either milled fiber or cab-aer-o-sil. It is not easy to fair at all and is not recommended where fairing is needed. While it is true milled fiber is the strongest, fumed silica is a lot stronger than talc or microballoons which are used where fairing is needed and adequate for this application, and as pointed out makes great fillets.
I agree with the medium cure 635. You can always add less hardener for a slower cure time, but if the temp is below 70 you need that hardener or else you will be waiting forever for it to cure. When I got my 10 gallon kit of 635 it came with 3 and a third gallons of hardener. I never touched the small third bottle because it was getting hot here so I was using less hardener. Digital scales are great for mixing small batches. When I was bedding the stringers and making the fillets I mixed a few 40oz batches which is a PITA using the 1 oz pumps and the scales I had did not read that high. FOr those I used cheap pitchers from the dollar store that were graduated. The biggest favor you can do for yourself when you get into the glass work is buy a small paint mixer for your drill. It is impossible to mix thickener into a 40 oz batch fast enough by hand. Its hard enough in a 9 oz batch! I also used the eglass tape but I used 2, 4, and 8 instead of 6. I would eliminate the 6 oz cloth from the layup they recommended and just use the 12" biaxial. A layer on each side and then one over the top, and I put 2 layers over the top from the pylon back to 6 inches past the tranny mounts. Bulletproof! There are many different ways to skin this cat and most of them are going to be better and stronger than original. Just sharing my experience. |
1973 Skier |
Keeganino
I used biaxial on the floor to hull joints. Since it was only 12" wide I bonded equally six on the floor and six up the walls. It made a huge difference in the rigidity of the hull, and if I had had enough resin left I might have gone all the way up the walls. Definitely a good idea to have a thick strong layup there I never used the milled fiber but the cabosil does a nice job getting the resin to a frosting like consistency. One thing I found was that thicker is better. Once it starts to kick it gets runnier than it is when you first incorporate it into the mixture. Especially on the bilge side of the stringer where it want to run downhill and there is nothing there to dam it up. ANother tip is that it kicks a lot faster when it is thickened and all together in the cup. Get it spread out fast and you will have longer to work with it. |
1973 Skier |
Ranger
I was thinking of using biax over the stringer as well, but U.S. Composites said it’s very difficult to work over the top of a stringer and back down. He said it can be done, but it's not user friendly. Did you have any issues with it going over the top of a stringer?
Jeff |
In this case, USC is right. I wrapped the tops of the mains in our BFN with biax. PITA and not user friendly- but it can be done. Im not sure I agree that 3 layers of cloth is a sufficient layup on the stringers though- especially the mains that support the engine. Personally, Id double that (2/2/4/4/8/8) and then add biax or mat up the sides, and wrap the top as well. |
Jeff,
Run a router with a round over bit (1/4" to 3/8" R) around the tops of all the wood. It makes it easier to glass over the tops. |
Ranger
Thanks TRBenj,
Double it? Wow I wouldn't have thought I needed that much. The tape isn't very thick, so I wouldn't think adding another layer is a problem. Something I should consider, thanks. I would really like the biax over the top, but if it isn't very user friendly, I'm not sure I want to mess with it. USC indicated that if you wait until the epoxy get's "sticky", then it's easier to work around corners. I just don't want it to go off, before I get it down tight. I could do the same with "epoxy" mat and cloth I suppose. But from what I understand, "epoxy" mat is getting hard to come by. Jeff |
Ranger
I was planning on using a router to round the edges. Does anyone else have any experience using biax over the tops of stringers? Is it worth the hassle?
Jeff |
You cant get epoxy mat anymore- at least not the good stuff USC used to sell. The good news is that I could barely tell the difference between that and the regular mat they offer. Wrapping mat around the top of the stringer wont be any easier (biax is a combo of cloth and mat)... Ive done both and its a PITA no matter what. It wont stick around the edges until the epoxy starts to tack up a little. By the time youre wrapping the tops of the stringers, you'll have the hang of it.
For the minimal extra amount of resin and time, doubling your schedule of cloth (at least on the primaries) is cheap insurance. Id rather overbuild than underbuild- but thats just me! I followed the 2/2/4/4/8/8/biax schedule on our BFN and plan to use it again in the future. Definitely do whatever you can to round the edges at the top. You'll appreciate them for the same reason fillets work nicely at the bottom. Glass does not like 90 degree corners, and the thicker the cloth (biax is thick!), the more that holds true. |
Ranger
Great Info, Thanks!
BuffaloBFN
I didn't find it to be such a hassle. If you do 1 stringer at a time while it's green, the previous layers hold the next on. Get the aluminum roller and corner roller.
As with most things, it starts with the prep. The better/smoother/flatter layers underneath help in the finished product/subsequent lay-ups. The round over is a must too. I started with a 1/4" bit and went to an 1/8". |
Keeganino
I routed the tops of my stringers everywhere they were to be wrapped as Pete mentions and I loved the biaxial. In a lot of ways I thought it was easier to deal with than the lighter cloth. As long as it was completely saturated with resin I was surprised at how easily it would make the radius and then stay put after laying it down. Here you can see the CPES finish, the fillet, and the raius on the edges Biaxialed over
This is the schedule I used as well sorry I forgot to mention that there are 2 layers of each cloth tape. I was just impressed by how strong the biaxial is over the cloth. I did my entire rebuild largely from Pete and Tim's suggestions They know their stuff! |
1973 Skier |
