1955 CC Hurricane Restoration |
Post Reply | Page <1 3233343536 50> |
Oh great, now I'm not going to make it!! |
62 wood
looks ok for me... will check with the "event coordinator" to confirm.
PLBC
Gold Member Joined: January-25-2006 Location: United States Status: Offline Points: 568 |
Should be able to make it.
M3Fan
We'll be out of town. Crap.
81nautique
Grand Poobah Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5775 |
Here's where I'm at with the fairing. The flash from the camera shows I have a little ways to go yet but it's looking pretty good. I'll need to get all the bungs in before I go any further but I think that will be a summer project.
The shape up at the bow came in real nice. Lots of hand long board work there. Nothing too exciting there but that sequence involved about 16 hours, just keep grinding along. Also block sanded the bottom for the final coat of paint, plan to apply that this weekend. Bottom planks finally trimmed and first transom plank installed. Now for the flipping, we're going to give it a shot Saturday April 2 around 11:00 am so if anyone wants to come by and lend a hand it would be greatly appreciated. We should be done by noon and we'll put some burgers on the grill after. Only thing that could change that is rain so we'll confirm as we get closer. |
81nautique
When Steve stopped by I was well into 40 grit long boarding one side. I ended up getting both sides faired in with a 60 grit soft backed disc, I had to go out and buy a cheapo Harbor Freight grinder because my Milwauke was just too darn heavy to handle accurately. So I got both sides ground fair and then turned to the long board at 40grit. One side is complete and I'm going to try to hit the other at night this week.
I don't think sanding through the grits will be that hard just time consuming but the 40 grit long boarding is brutal. This is the stage where the boat gets it's shape and if you screw this up you're going to live with it so it's slow going and really works the arms. I had every intentiojn of fairing the second side Sunday but I lost my ambition and the shoulders said I should do something else so I filled any holes below the waterline with famowood and started cutting bungs for the topsides. No pictures this week and I'm out of town next weekend so that's about it for a while. The goal right now is to finish long boarding one side, then sand and repaint the bottom one more coat. After that I'd like it to sit for a couple of weeks for the paint to harden and we'll set a date for the flipping party. Probably mid April. |
62 wood
GOOD IDEA PETE!
Steve,
What were you doing over there? Seeing if Alan would want to finish the Higgins when he's done with the Hurricane? You'd better get moving on that boat!! I'd like to see it in the water while I'm still alive!! |
62 wood
I had the pleasure of stopping by Alans this morning to check out the Hurricane. When I got to the house, Alan was busy fairing the hull. He was wearing a short-sleeved t-shirt and sweating his b#tt off.... with the overhead garage door open! No it wasnt sunny and warm, It was overcast, wind was blowing and spitting snow flurries..
This guy is DEDICATED! I could not believe how great it is looking! Pictures do NOT do his work justice!! Keep up the good work! |
storm34
Sounds like it's going to be great. I should have been specific, I was referring the the green on the flooring.
81nautique
Current thinking is a white boot stripe but then yes as you said, green bottom, white boot strip, stained side, yellow deck and details. The floor will be green battleship linoleum like the drawing and the seats will be a light brown/tan, not exactly sure there yet. I wanted to get away from the traditional red bottom or bronze racing bottom. The trailer will be sand blasted and painted green to match the bottom with yellow details/pinstriping. Chris, I love the green skins in an old boat but with the green floor I think it will be too much, I do have a piece of original seat material and it's a tan color. Lunch is over back to the garage. Fitting the last planks today then starting on the transom and some more sanding. |
FINS
Senior Member Joined: August-04-2007 Location: United States Status: Offline Points: 170 |
How does the green bottom play into the whole scheme? Are you going to transition from green, to a yellow water line, to stained hull sides, and back to yellow in places?
As always, Alan, the work looks great! |
I can't wait to hear what it sounds like too!
67nautique312
Gold Member Joined: June-23-2004 Location: United States Status: Offline Points: 883 |
I am more into a fiberglass restoration...(only because i wouldn't be so good at the wood work)..but if i was ever to do a wooden CC it would have to be one that looks like yours Alan!!! It's so Bad ASS!!!
Can't wait too see it in person!!!(and take a ride in it with ya) WOW |
67 Riviera 68 barracuda 1971 Ski Nautique Promo 86 Silver Nautique 1995 Ski Nautique |
81nautique
Yes I do but it's pretty beat up. I talked to Mike the cutwater guy yesterday and he suggested beating the old one back to shape and fit it to the new stem then we'll use it for a pattern. Al, yes it is a bit pricey, before I go ahead I'm going to look at other options since I have plenty of time yet. |
62 wood
Alan, Do you have the original cutwater for a pattern?
DrCC
That's what I get for "assuming"
I assumed it was mahogany ply. |
storm34
...just keep the interior GREEN!
DrCC
Pete, "by the artist drawing"
DrCC
And, If you don't like what Mike says about the Cutwater, there are others that do it.
I'd be willing to bet that you could fab it yourself, maybe even better. Then find someone that could braze it together without wrinkling. Either way, that's going to be one pricey little piece of hardware. I love fiberglass |
Al, It's yellow paint and not "blond" brightwork. |
81nautique
Al (drcc) Here are a few older photos before I dug into the boat. The "yellow" areas are painted, there actually is a chrome trim piece that separates the paint from the stain.
Here's the best shot I have of the yellow color, you can see the colored areas on the deck are just plywood. I'm going to use easypoxy polyurethane paint and plan to wetsand and buff to a nice smooth gloss. At this point I am about 90% sure it will be a light yellow, not quite as bright as the rendering but not an off white either. As always thanks for your input. |
DrCC
If by saying yellow, you mean a bleached, blonde or natural stained finish.
Then yes, I totally agree that by the artist drawing, that was the original intention. However, the problem in doing so, would be the making of a sharp, clean, crisp transition line on the hull sides without a seam or scribe line to stop the stain from bleeding into one another. This may have been the reason for the chrome trim detail in the drawing. My "pickling" thought comes from the black 'n' white photos. Just a way to retain the original white, while still being able to see the woodgrain thru the white. Pickling is usually done on Ash with shellac. So it would be a whole different process on mahogany ply. Anyway, wasn't recommending, just thinking out loud. |
skinaut
Senior Member Joined: September-10-2008 Location: United States Status: Offline Points: 209 |
beautiful work as usual, the yellow looks great. But I would lean towards original also.
I'm sure Al didn't realize the painted deck sections are ply and the reason he mentioned pickling. However the planked hull sides were solid color paint as well. What gets me, is he would recommend something not original!!
Donald80SN
Grand Poobah Joined: January-12-2009 Location: Denver, NC Status: Offline Points: 3893 |
1 vote for yellow
81nautique
I know you've seen a few of these yourself so that's quite a compliment. The light colored areas are just painted plywood, the catalog page shows a light yellow but the paint on my boat was an off white. I really haven't decided what I'm going to do there yet. The yellow was an artist's rendering but may have never been actually used. I do like the yellow though, I will probably decide once I see the boat stained. Thanks for the link on the cutwater, I'll give him a call tommorrow.[ |
DrCC
Looks like it may have been paint.
I think an off-white "pickled" finish would look really nice. Same visual effect from a distance, but up close you could still see the grain. JMO |
DrCC
Looking absolutely great, 81
I know it's a tad early, but now I'm curious about your plans for the light colored sections. |
DrCC
