1955 CC Hurricane Restoration |
Post Reply | Page <1 1617181920 50> |
81nautique
Grand Poobah Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5775 |
As always thanks for the compliments guys.
Well Finally got the topside planking finished, starting to look like a boat again and I really like looking at it right side up. This last row of planking was a challenge as the bow had some major flare and the tumblehome at the stern required some creative clamping to get the joints tight. Very happy with the results but those planks took 4 hours to install both sides. I then spent a little time repairing the top transom frame, once the 5200 cures I'll install the inner ply and start steam bending the transom planks. I'll need to make a run to the lumber yard for plank stock and deck plywood, I didn't think I'd be this far along and have run out of material. Time to hand pick the deck and transom Mahogany. |
I hate to see that the weekend is almost over,but looking at Alan's project and workmanship makes it easier. Well done Alan,looking good.
RainDog
Gents - the phrase 'pictures don't do it justice' couldn't be more appropriate as it pertains to Alan's Hurricane. I took a 2-1/2 hour drive for the 'flippin party' to see this beauty in person. Well, that and to see the gang and get a ear full of tube audio. But I digress...
Alan's craftsmanship must be seen to be appreciated. The build quality, exacting standards and innovative procedures he is using simply can not be fully captured with a camera. Thanks for documenting this build so thoroughly, Alan. It is just one more generous act you do for our community. In the same breath, it both inspires and scares the crap out of me to do a project of this magnitude. Let us know when the turnover party is. I'd drive down again just to hear the 331 fire off for the first time. |
kytom2
Gold Member Joined: July-25-2007 Location: Maysville Ky Status: Offline Points: 698 |
Sure has come along way since you brought it to Green Lake. My hats off to you for all you have accomplished.
81nautique
Well I had to dig down to page 7 to find this thread, I've been working but nothing ground breaking. With some help from Dana we got all the bungs glued in this weekend. That was quite a project because I actually had to remove every single plank screw and drill the counterbore deeper, then reinstall the screws. 1500 screws in the topsides so that kept me busy for a few weeks. Fairing in the topsides took more material off than I thought it would and the bungs weren't setting in deep enough. I went coservative with the screw depth because of the thin 3/8" planking and it bit me, live and learn but it's done.
Also got the bilge painted but it will need a second coat. Today I went up in the attic and set up beam consisting of 3-2x6 so I could hang my chainfall from it. Then set up 2 temporary columns for a little insurance. I've changed my plans for the summer and am going to work on mechanical issues while the deck is off. Just seems like the right time to do this while I have access. So the Hemi is going to get fired up in the next few weeks and the I'll drop it in for a test fit. Also hope to fit the exhaust again while the deck is off this should make things a little easier access wise. Then I'm going to turn my attention to the motor and strip all the accessories off and paint and detail it. Going to be a tight fit but I should have just enough height to lift the motor, slide the boat under and drop it in. |
uk1979
Alan, shall be looking forward to see the Hemi in the boat, that will be a real treat to see.
Lets have a go
81nautique
Finally got to starting the Hemi up today.
Had a few minor issues but some trouble shooting with the Boat Doc and it fired right up. Had to swap the coil out to a 12v unit but had no spark at the plugs. Pulled the cap and found the points were brand new but had a corroded film on them from sitting for so long. A quick hit with some emery cloth and it fired instantly. Sounds nice and tight, no blue smoke at all and no rattling. Did have a little trouble keeping the raw water pump primed so I had to put it directly on the hose. Sorry about video quality it was shot on a cell phone. may try to post something better later if I can get my video camera working You can't imagine how relieved I am to hear this thing run. About as cool as it gets for a gearhead. |
RJ
Senior Member Joined: July-21-2009 Location: Phoenix Status: Offline Points: 168 |
Thats way cool. I know we have all been waiting with quite anticipation to see her fire up!
I'm curious, did you start it up off a 12 volt battery as planed? What about the ballast resistor? Did you use one? Fantastic news ether way!! |
Wacko
Senior Member Joined: March-21-2009 Location: BC, Canada Status: Offline Points: 293 |
nothing like that to keep you motivated to keep with the project !!!
81nautique
I used 12v battery, solenoid and a unresisted coil(autozone on a sunday!!! not many options). No resistor straight 12 to the coil, probably wouldn't last veru long but it didn't get hot for the 10 minutes I ran it. The 12v battery cranked it over nice and strong. I need to talk to you about converting the generator over to 12v as I really think thats the way I want to go. |
hasbeenskier
Sweet!
bj |
hasbeenskier
skutsch
Very cool! Sounds good too!
Oh, come on! That's not the "original" talk I like to hear. Plus, unless you have turned it over on a 6 volt, you don't have a comparison do you??!! Yes, it can be done and many do it. However, a healthy 6 volt system does work and did for many years. You just need twice the size battery cables and a decent battery. We can talk. 6 volt gauges will work on 12 with only a slight indicating difference. Since you want to send them in for the big $$$ restoration, you may want to talk to them about it. It involves coil rewinding adding the $$$$ FWIW, yesterday I pulled the 6 volt battery out of the Atom just to check it as well as clean up the terminals in prep for GL. 6 Volt battery are tough. This one is 5 years old, I winterized the Atom last fall, never touched the battery or charged it, stored outside all winter and it checked out at 6.7 volts - that's about a 99% charge for a 6 volt! |
81nautique
I need to be able to run a bilge pump and blowers so thats why I'm thinking 12v. The 6v stuff is out there but very expensive. I think it will easier finding a 12v voltage regulator than a 6v also. The other thing is that I will not be sending the original gauges out for quite a while. Cocian wants $1200 to restore them and thats not happening anytime soon. I'm going to pick up a set of SW 12v wings for the time being. I'm not thrilled with them but they will do the job and I can swap them out later if I want. Started tearing down the motor today so I can paint and detail. Ps. You'll be happy to know the Chrome valve covers I picked up on ebay won't fit as I learned I have adjustable rocker arms and the covers I picked up don't have the bumps to allow for them. Darn |
Bilge blower and pump?? WTH!! First, it won't leak and second, all you do is flip the engine hatch open and smell. They didn't have blowers on them!!! My 64 doesn't even have one!!
BTW, all that needed to paint over chrome is a quick acid etch! |
Morfoot
That was Awesome.....totally AWESOME! Only thing sweeter to my ears is a BIG radial firing up on an old Warbird or hearing one fly over. |
PLBC
Gold Member Joined: January-25-2006 Location: United States Status: Offline Points: 568 |
Absolutely b*tchin.
Randy_in_Ohio
effin awsome!!!
jbear
what else can be said....the sound of the Hemi says it all.
john |
uk1979
What a great way to start the week thanks Alan.
Lets have a go
there is always a spot in the heart for Hemi power
are you running the gearbox?
Eric, Do you know if that box would have had Paragon guts in it? It is a Chrysler box. Lot's of marine specific castings on that thing!!! That's when the built a true marine engine!! |
i would say about 95% sure it has Paragon guts, i was shelf cleaning on Friday and found a bunch of old Paragon mechanicals and my guys were saying throw that sht out, im like FU, one of these days someone is going to need this stuff.
Paragon had close ties with Chrysler marine in the day |
81nautique
Good eye Eric, yes the gearbox is running. I couldn't seem to get it out of gear without having the lever attached to shift it. Without knowing much about the trans I decided to just run it in gear than screw with it and mess something up. There are some adjustments that I haven't read up on yet so better left alone for now. Pete, I stripped off intake and exhaust manifolds and all accessories yesterday. This thing is a monster size wise but is so simple it's amazing. These hemis went into a lot of industrial and military equipment and they are built tough. You can see why they are a hot rodders dream, intake and exhaust ports you can almost fit your hand in. There is so much potential for HP it's very tempting!!!Very very interesting piece of machinery to work on. ps. I need to talk to you today about where to get those motor mounts rebuilt. |
241 redram?? dont criticize, thats from memory, they used those alot in stationary power units, pumps, generators and to the likes.
241,331,392,426???am i missing any? |
67nautique312
Gold Member Joined: June-23-2004 Location: United States Status: Offline Points: 883 |
Hell Yea!!!!!!!!!
AWESOME Alan!!!!! |
67 Riviera 68 barracuda 1971 Ski Nautique Promo 86 Silver Nautique 1995 Ski Nautique |
Eric,
The marinized version is the 331. What about the gearbox guts question? |
RainDog
One more hurdle cleared, one more question answered, one more step taken towards completion. A good weekend for sure.
I say instead of music at the Green Lake reunion, we put the 331 on the band shell and just let purr for the evening. I'm sure half of those in attendance wouldn't mind... |
