  New Posts New Posts RSS Feed - White water filter bowl?
The Dude View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Dude Quote  Post ReplyReply Direct Link To This Post Topic: White water filter bowl?
    Posted: October-01-2006 at 11:08pm
Check it out. This guy thinks that antifreeze can turn the strainer white. Interesting...
Mullet Free since 93
95 Sport
skyhawkflyer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skyhawkflyer Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2006 at 12:13pm
If you use antifreeze to winterize your boat it's the antifreeze that fogged your plastic strainer bowl. Buy a new one. Get an o-ring too because it doesn't come with one.
I use my fogged bowl while the boat is winterized with antifreeze, then after running in the spring to get the antifreeze out I switch to the newer clear one that I have. I've been doing this for several years now.
todicus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote todicus Quote  Post ReplyReply Direct Link To This Post Posted: August-14-2006 at 3:16pm
I have a 95 Gt-40 with the white strainer. my 1988 SN 2001 was clear. It bugs me as well that I cannot see if it is clogged.
Living outside the wake
95GT-40SNOB
Darrel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrel Quote  Post ReplyReply Direct Link To This Post Posted: August-14-2006 at 2:19pm
My strainer is also white.
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: August-14-2006 at 10:08am
It is probably just the clear plastic having turned cloudy due to age. Might be a good idea to replace the bowl before it breaks. But, I have no idea if the cloudy apperance is an indication that the plastic has become brittle. Anyone?
77stang View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 77stang Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2006 at 9:09pm
ive always liked that color combination. very sharp
BrentAL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrentAL Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2006 at 4:11pm
It is this boat. I built a step to replace the center seat in the back.
http://correctcraftfan.com/diaries/details.asp?ID=1400&sort=&pagenum=1&yrstart=1996&yrend=1996
96 sn 196
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Dude Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2006 at 3:08pm
you can replace it pretty cheaply if you don't like it (skidim.com). Or perhaps you can just rub the paint off with acetone.
Welcome to the forum. It's an awesome site. Watch out or you'll become addicted fast.
Post pictures of your boat in the diaries section. We'd all love to see it.
95 Sport
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrentAL Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2006 at 2:58pm
It is the water strainer. My parents 88 2001 is clear thats why I thought it was weird.
96 sn 196
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Dude Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2006 at 2:33pm
Is it the sea strainer:
or the fuel/water separator:
I guess the strainer could have been painted white, but that would be weird... Many of the separators have white filter elements like the one in the pic.
95 Sport
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrentAL Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2006 at 1:31pm
I bought at 96 SN that has a white water filter bowl. It lookes like is had been painted. Does anyone else have a white bowl?
Brent
96 sn 196
