CCF FAQ |
Post Reply | Page 123> |
KRoundy
Posted: August-07-2012 at 4:16am |
A few months back I suggested that this site needed a FAQ. SO... rather than whine and not do anything about it I decided to try to start a Correct Craft Fan Frequently Asked Questions thread. There are so many worthy candidates for FAQ's. Please post links here or email me with FAQ suggestions.
I'll start with the infamous "Pete's alignment video". Alignment Video How-to video of shaft alignment - note: align shaft in strut first! Checklist(s) for buyers of wood era (before 1993) Correct Craft boats: Buying a used CC what to look for Pre-purchase checklist Advice for post-1992 Nautiques (no wood from 1993 on...) Looking at 1999 |
KRoundy
How to post a photo on CCF:
Posting a photo Use the CCfan search engine to search for previous discussions on topics. You can also use Advanced Google search and limit the Domain (Site) to www.correctcraftfan.com for faster and more accurate subject searches. Google Advanced Search One of the best stories you will ever read: Leo Bentz, Ski Nautique and Boat #1 FAQ Items Shift Cable adjustment Shifter Safety Collar Adjustment - Newer SN's Which Transmission Fluid? Winterization Checklist |
KRoundy
Buffing / Sanding gel coat
Adding better grounding for dashboard A discussion about teak swim decks More on teak products and proper care More on teak swim platform maintenance Repacking a rudder Super Sport - Air shaft repair cutlass bearing Trailer restoration Trailer steps and carpet - including a template for side steps Trailer bearings, with NAPA part numbers |
KRoundy
Notes on installing a rub rail
Stringer Job Lessons Learned Great Restoration Thread on 1980 2001 SN Removing seat backs in Sports The right way to restore a trailer MV-1: Step-by-step tear-down, clean and assemble flipflop's DIY Upholstery Threads: One - My Recent DIY Project Info Two - General Install Info Help With Sewing Curves Three - Another Project Four - 89 Nautique Project Info Five - General DIY Project Info Six - Another Install Info Seven - Materials And a quote from James (flipflop): "Is it worth it? I will say, after doing just a little bit of this type of work, I can see why skins are so expensive. I spent over 10 hours on the sundeck alone. Removing hardware, old staples, cutting patterns, sewing, stretching, stapling again, etc. Factoring in my time, even at $15.00 an hour, plus materials I was in close to $200.00. In comparison, it costs about $400 for a professional sundeck skin, plus you get foam backed vinyl and fabric sealed seams* from a professional and they eat the costs if there is an error. Good luck and let me know if you have any questions. |
kytom2
Gold Member Joined: July-25-2007 Location: Maysville Ky Status: Offline Points: 698 |
How about something about upgrading the Ford heads? I've seen that come up way too many times.
KRoundy
KRoundy
Upgrading Ford heads
Differences between various GT-40 heads Pete's $10 Prop Puller Carb repair and float angles How to replace a steering cable (with many helpful photos) GT40 Diagnosis - Or "Poor Man's GT40 Diagnosis Thread" Replacing Pro-Tec ignition with DUI system - step-by-step instructions with photos Carb bowl removal, replacement step-by-step with photos Holley carb rebuild |
KRoundy
Wiring diagrams (check the reference section!):
Wiring Diagrams Stringer Inspection Video Pressure testing manifolds Fuel tank fittings for EFI boats |
Nice work so far... just a suggestion - if you want it to remain very useful self moderate your own thread. We (people like me) tend to ugly up these threads very quickly - but you now own the first 5 posts or so. So if something else good is suggested and you agree with it, go back and edit one of the first posts to include it. In that way you could keep a good up to date list right at the front.
KRoundy
Joe - That is a VERY good suggestion. I will do that.
Big Pappa
Senior Member Joined: March-08-2006 Location: United States Status: Offline Points: 322 |
Here is a post I started on Stringer Job Lessons Learned
KRoundy
Thanks! Added it above.
dochockey
1989 Teal Ski Nautique
HatterBee
How about some teak links?
KRoundy
Added some info about teak.
KRoundy
TTT - A few link updates.
KRoundy
TTT - and any other suggestions for additions to the FAQ?
75 Tique
KRoundy
Larry, good one! A video is worth 10,000 words. Very well done, and I added it above.
I love that sound. I played the video twice to just listen and enjoy. Also added another link for teak swim deck maintenance. Kevin |
oldslalomskier
Newbie Joined: November-23-2012 Location: Madison, MS Status: Offline Points: 32 |
I have encountered a problem that I have never heard of! I need to replace the rear main seal in the PCM 1.23:1 trans in my 2002 Ski Nautique. I have removed the retaining nut and washer that holds the output flange to the tailshaft, but the flange will not budge. I have destroyed a harmonic balancer puller trying to remove the flange. I rigged up a heavier puller using 1/4 inch steel bar stock, but all I succeeded in doing was bending the steel around the flange. I am assuming that this is the result of overheating due to lost fluid. With this in mind, I am going to pull the trans and probably go ahead and replace clutches and seals. However, I am wondering if the shaft bearing is damaged, although the boat was still pulling strong with no telltale noises. I might want to replace the output flange too, after all the force I have subjected it to trying to remove it. Has anyone else experienced a stuck output flange?
Dreaming
You'll get more response on this question if you start a new thread... There are some good trans guys on this site. You might be money ahead to send it out if you are unfamiliar with the process. |
oldslalomskier
Thanks--now if only I can figure out how to start a new thread..
Looks like no skiing for me this weekend anyway:( |
Will, Just under the section heading, you will see the "new topic" icon to click on. When you get the coupling half off the trans, make sure you check to make sure the face isn't bent from your pulling it. I suggest chucking it up in the lathe and taking the dial indicator to it. Personally, I'd ship the trans up to Fantastic Finish Marine. They aren't as simple as just throwing a clutch pack and seal kit in for a rebuild. One of our top members here Eric used to own FFM. He's gone onto other things and has sold FFM to his right hand man Vince. Eric taught Vince everything he knows about marine trans's. Eric has rebuilt/fixed them when other "pros" have failed. I remember one thread where the "pro" tried twice!!! |
oldslalomskier
Thanks! I can't believe I didn't see that icon earlier (although my wife would not be surprised)!
I didn't know Eric was gone--I guess he won't be replying to the message I left for him yesterday! Yes, it has been a while since I have done any trans work, unless you count rebuilding the hydrostatic transaxle on my old John Deere lawn tractor a couple of years ago.. Thanks so much for the tips! |
KRoundy
Added info on Pete's $10 prop puller above.
KRoundy
To the top (TTT)
KRoundy
Added link on float repairs from Daniel in Austria.
mrfreeze001001
Newbie Joined: December-25-2012 Location: ohio Status: Offline Points: 20 |
Very nice good idea realy helpful
We have got to convince Keith to put a sticky on this thread!! Keith, how about it? Every time I need to go looking for it, it's always 2 or 3 pages back!
KRoundy
That would be very helpful.
