Project 67 Mustang |
Post Reply | Page <1234> |
So Kirk did you end up going to Sterling to pick the trailer up? Looks like your the rebuild thread to get us thru the winter!
dochockey
Yes Gary I did, I just squeaked by that snow storm. The trailer is awesome.
1989 Teal Ski Nautique
I have just seen in your first pic,your boot stripe is the same as mine. I have never noticed any others that are the same, most seem to continue all the way to the front. Did Steve meet you in town and blindfold you for the ride out to the ranch? If you ever decide you need a new axle check with TimB he has a source and might have one for the springs too. I had trouble with the seal area on mine so I bought one and it fit fine. As you will find out when you eventually work on yours running gear parts are odd sizes compared to others.
dochockey
I had some time today to tinker and this is what I found ! |
dochockey
Sorry forgot to rotate the photo
dochockey
M 2198 is what the tag says. Is this what art needs to look up the invoice ? I found some old registrations it says she is a 69 . |
That's the hull number you're looking for. It's definitely not a '69 though. The number would seem to reinforce my previous guess.
I have a number of 68-70 mustang id numbers collected, the earliest verified is in the late 2200's and was a '68 built in sept of 67. I'd say yours is a late 67 or very early 68 based on the id and other trim details I see. What's in the battery box? |
dochockey
It's a frozen mouse nest.
It's funny you say it's older cuz there were about 6 or so old registrations in the side panel and all saying 69. How does one decipher the serial #s Did the fiber glass floor go all the way back ? |
Looks like someone made the battery box hole bigger too, the edges are cut at 90 compaired to a radius. I have some floor pictures Kirk but will get them later,I can't get into photobucket for some reason and yes it goes quite a way back. Do you have the toe board? I have a decent one if you need it.
dochockey
Gary is the toe piece fiberglass ? I removed a piece of wood that was carpet wrapped |
Yes it is Kirk it matches the floor and has ply glassed in on the back side to give it strength
dochockey
I don't have the piece that is behind the motor. Don't know it thereever was one.
The carpet was tacked with staples, I'm hoping it will clean up |
In the end I used the same 3m compounds and pads that we use on the hull. Cleaned up really well.
There is no "decoding" the serial number, they were just sequential (with some exceptions). Art should be able to pull the build sheet on it and confirm the date.
It's pretty common for registrations to list the year incorrectly, you see it all the time. Apparently the DMV is not the authority on year to year changes at Correct Craft. A '69 would have had different seats, light, dash, scoops (style, placement, number), etc, as noted earlier in the thread. |
dochockey
dochockey
Took the windshield off today and one side was plastic and the other glass?
Is the white molding still available somewhere? How would one fix this? |
dochockey
Tim looks like these are original |
john b
Grand Poobah Joined: July-06-2011 Location: lake Sweeny Status: Offline Points: 3238 |
The 69 SS Mustang I sacrificed had one glass pane and one plastic too The vinyl windshield deck channel is available Let me know if you can't read the numbers. Love your project!
Yes, scoops are original, since I posted last year about not recognizing those rounded scoops, I've encountered a few 67 and early 68 boats with them.
Not sure what we're looking at in the "how do I fix this" pic? Motorbox looks good! |
Kind of weird why the windshield frame broke where it attaches to the deck. We have a plastic panel in our Classic windshield. It was a challenge to put it together due to the plastic being slightly thicker than the glass. The color of the motor box is nice!
john b
Which side of your windshield is plastic, port or starboard? I believe the mounting tab on the windshield could be welded back on.
It's sure worth a try but, some alloys can't be welded. You won't know until the welder tries to develop the weld puddle. |
dochockey
Oh boy now your putting me to the test Uh the plastic was on the port side, the glass was on the starboard side I hope your going to Tell me you have the one I need ? And your willing to part with it. |
john b
I can set you up with another plastic port side pane. Sorry. See if they can weld up your frame. If all else fails get back to me sometime. I will know a lot more when I get mine assembled.
Ken Meloon at the Taveres show was telling me how many halfs they used to go thru,I'm guessing the passenger is using it for a handle,while the driver used the wheel?
john b
The wheel doesn't work either Gary.
I didn't ask how many wheels they had John
Another reason to turn that observer seat around the way it's supposed to be! The pylon is a sturdier grab handle too. |
