  New Posts New Posts RSS Feed - 1972 SN Promo Project
 Post Reply Post Reply Page    <1 89101112 13>
barefootdan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote barefootdan Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2017 at 2:57am
Great job can't wait to see more
Wisky Badger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wisky Badger Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2017 at 11:19am
Excellent work!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wisky Badger Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2017 at 11:33am
Chris,
I am at about the same stage as you on my project and I have really been enjoying your thread.   I have a few questions. Are you leaving the fiberglass that is attached to the hull in order to help set the stringer and floor height or is there anither reason?   Will you remove it before you glass the floor or will you glass over it?   Have you decided on a fiberglass schedule for your stringers?   Keep up the good work, this boat is going to look great.
fgroce View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fgroce Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2017 at 1:59pm
Question for the ones with experience. Now that the stringers and supports are all removed.   Should he support the boat to keep it from sagging and taking on the wrong shape, while he glasses in the new stringers. Also what is enough support? Lift it up at both ends by the lifting rings and call it good. Just trying to learn some more about these boats and doing fiberglass work.
FGroce
88 Ski Nautique
For 28 years
Now 2002 Ski Nautique
uk1979 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk1979 Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2017 at 6:48am
That’s a fair point… seem to be 2 schools of thought here some change stringers one at a time using the old to keep hull shape (that’s if the old have some strength left/still bonded to hull) this is a much longer way to work and awkward to work.
And this way all out and replace which is quicker and less of a pain to work in… as you point out the hull will flex under foot… my view if you have extra timber say over 200lb then one at a time if the old has some strength left or use a kid to fit them under supervision.
The above applies to the older flat bottom hulls up to gen 2 SN, from then on there not so flat…they may be not as thick hulls as the old but the hull shape looks more stable with stringers removed.
As for supporting… at the back each side and each side at the chine in line with the dash… some leave on the trailer with supporting and some off… as yet both ways have worked well.
Lets have a go
56 Starflite
77 SN
78 SN
80 BFN
Frankenotter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Frankenotter Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2017 at 8:22pm
Originally posted by Wisky Badger Wisky Badger wrote:
Chris,
Thank Jacob! Sorry for the delay, I've been traveling a lot this week. Tim is helping me through the engineering logistics of putting this boat back together. The initial reason for leaving the old floor edge was centered around the idea of using Coosa to re-stringer the boat. The idea was to reenforce the edges with a strip of Coosa and epoxy. Then use the edge lip as a support to hold a "floating floor". What that meant was not installing a subfloor that gets glassed to the sidewalls. Instead, just screw the ply directly to the stringers after coating the ply with CPES. The top side of the ply will be covered in the original Grey vinyl.
After looking into Coosa availability and pricing, I'm afraid it won't be an option. The best price I was able to negotiate for the amount of material needed was $600 vs $60 for Douglas Fir. With the engine and engine accessories in unknown condition, I decided that money would be better used for other items. I would honesty consider the Coosa worth it if this boat was going to be my daily driver.
Going forward, I still like the idea of the floating floor and reenforcing the edges. I'll have to consult my engineer again, but I think the same construction could be used with Doug Fir.
As far as leveling the boat, yes that will be one of the next steps. This thing flexes like an empty beer can right now. I will be researching the best ways to do this in the next few weeks after I get done pressure washing the fiberglass out of the boat. The trailer that came with it (as horrible and unusable as it is) is actually a really good support. It's not an inboard trailer so it has built in rollers along the keel that can be shimmed. Then I plan to level the stern with cinderblocks and shims. Once the stringers get shaped, I'll probably cut a section of cheap plywood to put on the non-working side to distribute the weight while I'm working.
I'm open to ideas and if anyone has a link to a good leveling thread please feel free to share it.
Chris
1999 Ski Nautique 196
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2017 at 8:44pm
The rationale for leaving the lip was for the floating floor... regardless of material choice.
Dreaming View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2017 at 8:54pm
No stones to throw from my direction, but I am curious about the floating floor idea.    Wouldn't the floor attached to the hull sides provide some stability to keep the hull from flexing while sitting on the trailer, or in a bouncing/choppy water situation?    In my thinking, pressure from the weight of the hull on the trailer bunks would want to bow the hull sides out.   The floor seems like it would provide some stability to keep the hull sides from spreading if it were fastened to the sides.    obviously the hull would be compressed by the water around it, when the boat was floating, so I don't see that as much of an issue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Frankenotter Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2017 at 9:07pm
Kris I think that's where the ribs would come into play. I would be adding ribs off the secondary's to the sidewalls. I would also replace the straps of wood connecting the stringers with ribs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2017 at 9:15pm
Ahh... that makes sense...    I do think not adding extra ribs would cause the non-tied surface to be greater (adding the distance from the original floor to the secondary) that could be problematic.   When you add the ribs, the unsupported side area remains the same as the factory design, just a different connection point.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2017 at 9:30pm
No ribs needed. 2nd gen SN and earlier/smaller hulls are rigid enough to not need a structural floor. The fiberglass skin over the foam was very thin from the factory. The wood topper floor was needed for impact resistance.
Ask mars... no foam, ribs or structural floor in his promo. It's solid.
The thinner layups and larger spans on the 2001 and later boats is a different ballgame.
storm34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote storm34 Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2017 at 1:38am
Yep! My Promo is very solid and no issues.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Frankenotter Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2017 at 2:04pm
Summer is just floating along and with it comes a decrease in desire to lay in a hot garage working on a boat. I haven't made much progress since the last post but I thought I'd take a study break and post what's about to happen.
First off, I got the old trailer out from under the boat and put it up for sale. My intension was to use the Correct Craft trailer (that I acquired from the Benjamins) to support the boat with the aid of some chine and stern supports. I didn't realize how high the boat sits when it's on this type of trailer.
I decided that I didn't want to be climbing that high in and out of the boat during the glassing process. Plus......I wasn't happy with the location of the bunks relative to the hull. They sat in between the keel and the chine which bowed the hull. With this in mind, I decided to use the boat dollies as a safety net and block the hull with cinder blocks and wood.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Frankenotter Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2017 at 2:09pm
Tim had to walk me though the leveling process, but I will post a video of what I did to make sure the hull was straight.
A few weeks ago Mr. Skutch came by to help me acquire some Douglas Fir. The lumberyard was quite mistaken on what they actually had in stock and tried to sell me regular pine. in the end, I ended up getting 2x8x18 for $14.50 per board. Obviously I will end up cutting it all down in the next few weeks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2017 at 2:09pm
Chris,
Do you know that you have the CMU's in the wrong position at least at the stem? The cores need to be positioned vertical for strength. Picture a CMU wall!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2017 at 2:10pm
Good plan. You pick up your pylon and clearance bar yet?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Frankenotter Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2017 at 2:24pm
Hey Pete, I see what you're saying but it took so much work to get this &&?#€¥~* level that I think she's staying right there. The boat is rock solid now.
Tim I have to get down to HWs this week sometime to grab the goods. Thank you again for the amazing find. I will be addressing the cradle/pylon plan very soon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Frankenotter Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2017 at 2:37pm
Which brings us to the part of the story where planning is involved. I have been consulting with Mr. Tim about the rebuild plan for this boat for quite a while now. As mentioned in a previous post, the current plan is to do a simple system of stringers with ribs, a small subfloor in the cockpit to provide an anchor for the seating, and a floating floor (not glassed to the hull) on the entire boat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Frankenotter Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2017 at 2:44pm
There will be several advantages to doing this method.
1. there will be no foam to cause future rot. The ribs will provide support.
2. No straps. Apparently this is a known weak spot in the original design where the glass would fail. Evidenced in my case by the big gaping holes in the stringers when I acquired the boat.
3. With the use of an engine cradle, the floating floor will provide access to the through bolts if I need to remove the eninge down the road. The floor will be covered with the original grey vinyl and the aluminum track to bolt it down.
I think the subfloor in the cockpit and the airbox will be the only areas that get directly glasses to the hull. I will also be glassing a sheet of either biaxial or mat to the sidewalls to "beef up" the areas I removed the gel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2017 at 3:36pm
I think those straps were a production aid more than any kind of structural member- so I wouldn't go crazy adding too many ribs... just a few to support/provide a nailer for the floor. Maybe 2 per side since you'll be doing a sub floor up front? You'll also want to add a little reinforcement under the lip of the original glass floor that you left behind. With the ski pockets installed it will be hard to put much weight on outer floor edge that the lip is supporting, but it'd be nice to hold some weight without deflection.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fanofccfan Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2017 at 3:57pm
Chris,
I have to say I agree with this. Not saying that you will have a problem with them breaking but id be willing to bet if you've ever seen them crumble it would make you set them correctly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2017 at 4:58pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2017 at 5:06pm
If he got the blocks at Home Depot I hear there is a guy there that would have instructed him on proper block orientation.
Unless Chris has 4 buddies in the boat working with him I think it will be OK.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2017 at 5:15pm
He's been taking too much or Mr. Tim's advice
https://encrypted-tbn0.gstatic.com/images?q=tbn:ANd9GcRrfUSsh47ryL63PM7NNenGRLnRrjhsjU95_Vg_KLgU6sU5kpFAAA
They may be stronger stacked vertically as intended but they're plenty strong sideways (and the risk is quite low when the trailer remains underneath).
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2017 at 5:36pm
I feel we need to steer Chris away from Tim's advice. It's obvious Tim isn't familiar with the ASTM C90 standards!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Frankenotter Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2017 at 5:56pm
Here is my layup schedule.
I plan to make my own CPES to coat the doug fir.
The stringers will be bedded with epoxy mixed with cabosill and 1/32' milled fiber.
Glassing the stringers will consist of 2 layers of 2" tape (offsetting), 2 layers of 4" tape, 2 layers of 8" tape, 1 layer of biaxial 12" thick, and one layer of biaxial to cover the top of the stringer.
Secondary's will get one layer of 2', 4', and 8' tape with a biaxial cover.
Here is my component list so far from US Composites. Please feel free to suggest anything I missed or shouldn't purchase.
The 2 questions I have yet to answer before the materials are ordered, are;
1. what type of mat should I use for the sidewalls of the boat? (under the gunnel)
2. what type of dye should I use for the bilge (assuming I epoxy the bilge).
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75 Tique Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2017 at 5:58pm
I confess. I had to look up CMU. Concrete Masonary Unit. Oh, OK, Cinder block.
Well I better grab my ink filled writing implement and get back to work. (impressed now?)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Frankenotter Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2017 at 6:02pm
I did the same. Sometimes I don't know about these guys.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2017 at 6:10pm
Chris,
I feel your layup schedule is excessive. Maybe half of what you have drawn? Let's see what the expert on CMU's has to say.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2017 at 6:29pm
Chris,
I feel your layup schedule is excessive. Maybe have of what you have drawn?
Its a pretty reasonable schedule, although with actual wood the biaxial might be a bit overkill - you could probably save some resin by using a mat instead - but people are all about the biaxial these days.
