1985 |
Author | ||||
Red
Newbie Joined: March-06-2018 Location: North Carolina Status: Offline Points: 4 |
Posted: March-06-2018 at 5:12am |
Ski pylon previous owner cut the ring off to install wake board pole.
NCH20SKIER
Clown
'88 BFN |
Wil
Newbie Joined: February-04-2018 Location: LKN Status: Offline Points: 16 |
There is one on ebay
Pylon with a ring and finger? How about a link? |
NCH20SKIER
I have a pylon and am less than 90 minutes from Lake Norman. Not perfect but has the ring and finger attached.
'88 BFN |
Donald78
Newbie Joined: November-06-2017 Location: Napoleon, Ohio Status: Offline Points: 25 |
I have a pylon chrome off of 86 ski nautiquie 2001
LDH
Newbie Joined: March-31-2018 Location: NC Status: Offline Points: 3 |
I am interested in getting this. I need it for my boat. How can I get in contact with you?
LDH
I am interested in this. I need it for my boat. How can I get in contact with you? This is for Red.
Donald78
I am sorry it to so long to get back did you a ply on thanks Donald 78 419 788 0523
LDH
I have not found one yet but I want it......
repifanio2
Groupie Joined: June-25-2017 Location: 53121 Status: Offline Points: 53 |
How do you take the ring off the pylon?
RKE
Wil
should be allen set screws to remove
No. Roll pins. |
Lynn, What kind of boat do you have? |
repifanio2
86 2001 I got one pin our but probably bent the other
RKE
Ralph,
Pin punches are sized to be slightly smaller than the pin you are removing. If you use too small a punch, you can "mushroom" the pin end and locking it in the hole. Did you use the proper size? My suggestion now is to remove the pylon and get it into an arbor press to see if the pin will come out. You may have to resort to drilling it out but that can be tricky since the pin is hard. A carbide drill in a drill press would be needed. |
repifanio2
thanks for your help
RKE
