New Airguide speedometers or GPS |
redritereturn
Newbie Joined: July-21-2011 Location: Delafield, WI Status: Offline Points: 19 |
Posted: July-04-2018 at 2:43am |
I have a pair of new Airguide speedometers as well as new 'ballast tubes'...I'm debating on going with either the perfect pass GPS speedometer, the whole perfect pass system or try to keep it as original as possible. I've been using the tach for way too many years and it never seems to be correct in relation to mph
Air206
PM sent
Grand Poobah Joined: July-18-2008 Location: Pittsburgh, Pa Status: Online Points: 4117 |
And another
Jeff, I think they're after those new speedos! |
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2870 |
Why not both options? One Airguide and one Precision Star GPS speedo. That's what I have in my 1994 SNOB. Redundancy -- belt & suspenders.
[If somebody wants my old and still working Aurguide, send me a PM] JQ |
sent
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Online Points: 21136 |
Why not convert the original airguide(s) to gps? Best of both worlds- precise and original (appearance).
That’s an option for sure
Got it. Back at you. |
redritereturn
PM's sent.
I'm still debating what to do...I definitely prefer the original appearance vs some of the GPS ones I've looked at. Does the poster from 2013 or so still do the speedometer conversion to GPS with the original ones? |
http://www.nauticlaugic.com/airglide.html
JQ does yours say Airguide or Nautiques above the pointer.
Fabcon
Gold Member Joined: August-27-2012 Location: Buffalo. Mn Status: Offline Points: 552 |
Go with your new Airguides with the GPS installed, Keeps the look original
1976 Ski Nautique 351 Escort
1984 Barefoot Nautique (Parting Out) |
redritereturn
I'm thinking that's probably the route I'm going to go....I still need to check out the link.
I wouldn’t gut those brand new ones if you’re going GPS.
If the ones you have are faded I’d get new faces from here http://www.classicboatwork.com/classicparts/gauges/airguide/agr/agr.html and gut the old ones |
JQ |
Air206
rosconole
I like the precision star I run both and I like the clock and the handy dandy compass.(you know when driving in the pouring rain and you can't see a thing) Oh not to mention trip meter is easy to figure the fuel burn later...
redritereturn
My immediate plan is to just retrofit my existing gauges with the nauticlaugic GPS system and the new faces this fall or spring. The existing ones must have known something was up since one worked all weekend and the other one mustered it's way up to 15-20 most of the time. As far as low speed accuracy where does the GPS retrofit struggle with accuracy, is it decent around 20mph?
Under 5mph and over 45mph.
If your gauges sometimes work, then the issue you’re having isn’t with the gauges. Consider not scrapping/cannibalizing the internals when you convert. Send me a PM for details. |
Mille1sj
Senior Member Joined: October-01-2007 Location: United States Status: Offline Points: 276 |
Do you know if the conversions will work for an older airguide? I have a 77 Ski Tique, the website didn’t list these. Curious if anyone has tried it. My airguide hasn’t worked in a few years, I would love to fill the holes in and remove the pitot
Donald80SN
Yes, they can do the conversion to the older Air Guides, but I have not done it myself. |
Mille1sj
Thanks Donald, I watched the video on how to convert it to GPS. Seems pretty straight forward. |
Over 45? I thought they read accurately up to 85 with the correct graphics? |
man0seven
Senior Member Joined: September-16-2018 Location: Utah Status: Offline Points: 122 |
Are you saying they are not accurate between 5 and 45? |
2005 Ski Nautique
(On a standard 50mph face). |
Donald80SN
The old water pressure driven Air Guides are very accurate. As accurate as you will need. They are so accurate I would not consider going GPS driven in an older boat. GPS comes into play if you are looking for speed control for skiing or other bells and whistles like clocks and compasses. JMO, |
Reasonably accurate (when properly adjusted), yes. Reliable? That will depend on your water conditions. Weedy or debris filled waterways will cause issues with pitot systems. They also cannot compensate for current if you care about speed over land (slalom course in a river, for instance).
There is certainly a place for a $200 gps conversion in an older boat. Originality (appearance), reliability and accuracy are among the benefits, as is simplicity (removing the pitot, tubing, etc) if you so desire. Not all disciplines require speed control, and a converted analog gauge compliments those that do... at a much lower price point. |
redritereturn
I saw this topic was active again...I did get one of them to work fairly accurately this summer, at least 90% of the time. I am planning repairing my dash pod this winter and am going to look into fixing the originals and see how that goes before going the GPS route.
