1955 CC Hurricane Restoration |
Post Reply | Page <1 3334353637 50> |
81nautique
Grand Poobah Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5767 |
Yep I have trim rings Bruce, I couldn't put them on because the boot stripe was still a little tacky but I didn't want to keep you guys waiting for pictures. |
I am thinking maybe you should go with a more rat-rod look on the trailer. Stick weld on the new supports, some strategic abrasive blasting, followed by liberal application of a high molarity salt solution and let her sit out for the next couple of months to develop the appropriate patina. I think it would provide a real nice contrast to the level of detail on the boat.
81nautique
Well in that case Joe the trailer's ready to roll now. LOL |
Moderator Group Joined: February-04-2004 Location: Twin Lakes, WI Status: Online Points: 13510 |
Could even put some faux rollers outboard of the bunks to really freak some people out.
Some house paint put on with a broom over some of that rust and 4 different tires could do wonders too.
How about Gary's supposedly optional guide on's for the trailer. Damn, his avitar picture still shows the stupid things!!
Those Cypress Gardens guides are now in North Carolina Pete. The reason my avatar has not been changed is that I was having trouble with my password,and talked to HW about the other night. Kurt has given me permission to used a great pic he took last year at GL.
Donald80SN
Grand Poobah Joined: January-12-2009 Location: Denver, NC Status: Offline Points: 3888 |
Actually, they were prototype Cypress Gardens guides. I hear that Gary funded his retirement by selling those.
Alright so my april fools day joke wasn't my best effort.. Boat is looking unbelieveable!
81nautique
Need some help on placing the clamshell fuel vent cover.
This was already removed when I got the boat but the screw holes in the old side planks show that it was placed so the opening was facing forward. That doesn't seem correct to me but I can't find any photos anywhere to indicate how it should be installed. I would think facing forward could catch some side spray and possibly force water into the fuel system. |
turningpoint84
Platinum Member Joined: September-11-2008 Location: Cincinnati, OH Status: Offline Points: 1467 |
Just going off pure common sense, i'd say i'm 90% sure it would face backwards. All the fuel vent for is allowing Vapors out, there's no need to have any kind of wind forced into the tank.
I'm sure others will have a better response. |
1970 Mustang |
quinner
Do the holes line up facing down and rearward??
81nautique
The holes on the old planks line up so the opening is facing forward. |
baitkiller
Turn the plank over. Your holding it backwards.
quinner
Got that, what I meant was if you rotated the vent from forward facing to 1 screwhole counter-clockwise, which would leave it facing down-aft.
81nautique
hard to make out in this picture but I have the plank and the hole is facing forward, I believe that is wrong just looking for proof before I drill new holes. |
juniorwoody
Gold Member Joined: August-09-2011 Location: Oak Hill, Fl Status: Offline Points: 937 |
Just my two cents, I would think there a possibility of pulling a vacume if facing aft.
81nautique
That is my thinking too, I would just like to see a few other boats with this installed for proof. Does your boat use the same piece Jack? |
baitkiller
I was teasing about the plank. I would ask if the clam-shell is original at all? If so it (the opening) should point down or at a downward aft angle. The angled position is what I see most in older boats. Maybe some previous owner buggered it up some how. Hard telling-not knowing.
81nautique
Oh I know but I still I had to find the picture to make sure I wasn't seeing things. I do think it's original to the boat but who knows. I'm sure Pete or Billy will jump in later with the answer. |
Waterdog
If the vent faces aft it will have a low pressure area at the vent. Not sure I would call it a vacuum. Maybe perfect, may draw fuel out of the tank. Maybe mount the vent out of the air-stream??? |
juniorwoody
Mine is on the transome Allen so no help. It has been moved at some point from starboard to the port side and can only guess why. Some of these things are a real mystery to solve. |
juniorwoody
75 Tique
Grand Poobah Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6100 |
Definiely the original spot. Not a great pic, put I dont see any shadow to suggest its facing back.
Morfoot
Grand Poobah Joined: February-06-2004 Location: South Lanier Status: Offline Points: 5311 |
Good points but will there be enough forward speed to generate enough of a low pressure to draw fuel up the vent line? The vent line is connected to the top of the tank, not with a pick up so I'm thinking you won't siphon gas. If anything you suck out vapors. If the scoop was facing forward you're definately putting a postive head pressure on the tank but is it that much? If the vent line is/was routed upward on the inside of the gunwhale/stern then anywater entered in from spray would have to travel upward and into the tank. That's allot of force which equals allot of speed and we are talking about "The Hurricane" not Alans former suped up 81. |
I am thinking perhaps if the opening were at an angle downward and to aft it would give the same hole pattern (close anyway) as opening forward?
Downward and to aft makes the most sense in terms of function to me. |
MI-nick
Gold Member Joined: January-12-2009 Location: Ypsilanti, MI Status: Offline Points: 809 |
my '99 SAN tank vent faces down...i know this may not help, but I just wanted to contribute to this thread because your work is AMAZING
juniorwoody
I do have these vents on the fins of my Atom however they just vent the compartment aft not the tank. In my case they do pull from aft. One on each side.
uk1979
Platinum Member Joined: June-13-2007 Location: United Kingdom Status: Offline Points: 1410 |
This may be of help...but my vent comes out under the rear rub rail...just a pipe that's been peen'd over to stop it pulling back through.
Lets have a go
turningpoint84
I could be totally incorrect on this, but I think the drag of the ID of the piping wouldn't allow for anything to really happen. I just don't think and type of vaccuum can be created. This is once again being over thought. |
1970 Mustang |
