  New Posts New Posts RSS Feed - Here's a crazy  idea
Here's a crazy idea
Jllogan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jllogan Quote  Post ReplyReply Direct Link To This Post Topic: Here's a crazy idea
    Posted: November-18-2011 at 2:26pm
So after reading some old threads about carburetors and angled spacers I was just thinking. What if I took my currect carb spacer with the pcv inlet on it to a machine shop and had it planed on an angle so my carb would sit more level? Thoughts? This would also drop the front of the flame arrestor down a bit allowing for slightly more room if I added a high rise manifold.
Anyone ever done this?
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: November-18-2011 at 2:41pm
Just buy one to make it sit level, probably a lot less money than machine work.
Tim D
JoeinNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: November-18-2011 at 2:57pm
I would first make sure that your current spacer is actually solid, most I have seen with the fitting are only flat on the top and open to a great extent on the bottom which would make it a pia to machine. Last I knew Billy at correctcraft parts was selling angled spacers as were others if they dont have pvc fittings it would probably not be too hard to add one.. or as I have done in a couple builds use a plug on the intake manifold for your PCV.
1983 Ski Nautique 2001
1967 Mustang 302 "Decoy"
Holeshot Video
kapla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: November-18-2011 at 3:22pm
joe is right...they are hollow, not solid, thats why when used on performer or like manifolds you need a square to spread bore adapter plate...or you´ll have a major vacuum leak!
<a href="">1992 ski nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jllogan Quote  Post ReplyReply Direct Link To This Post Posted: November-18-2011 at 4:54pm
Well that's a good point it could very well be hollow inside. I guess it probably would be easier to add a PCV inlet to a wedge than machine that one down. That's why I asked. Thanks!!
Fl Inboards View Drop Down
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fl Inboards Quote  Post ReplyReply Direct Link To This Post Posted: November-18-2011 at 5:39pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jllogan Quote  Post ReplyReply Direct Link To This Post Posted: November-18-2011 at 6:09pm
OHHHH that is cool.
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: November-18-2011 at 6:13pm
I have an older Offy aluminum wedge that I wanted to use atop the Edelbrock Perf.
Won't fit under the motor box useing the additional PCV adapt. spacer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jllogan Quote  Post ReplyReply Direct Link To This Post Posted: November-18-2011 at 6:15pm
are you interested in parting with it?
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: November-18-2011 at 7:07pm
Not really.
I still might use it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jllogan Quote  Post ReplyReply Direct Link To This Post Posted: November-18-2011 at 7:15pm
OH you were just dangling me with it huh. JK, thats cool. Let me know if you want to clean house and part with it.
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: November-18-2011 at 7:16pm
Do they make performance, square bore intake manifolds? I've read that you lose some horsepower with adapter plates.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jllogan Quote  Post ReplyReply Direct Link To This Post Posted: November-18-2011 at 7:34pm
Some spacers claim they boost performance. Who knows.
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: November-18-2011 at 7:49pm
I just did a quick web search and came up with several.
5 degree to 12 degree. 60.00 to 250.00
Aluminum or plastic.
Sorry, didn't mean to dangle.
Just measure carefully so it will fit under the motor box.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: November-18-2011 at 7:52pm
Brian, what sort of adapter plate are you envisioning?
Most single carb V8 manifolds (performance or not) are square bore. I dont think Ive ever seen a spread bore Ford Windsor manifold.
The adapter plate referred to above simply seals off the bottom side of the PCM 1" spacer. When installing an Edelbrock manifold, the edges of the carb baseplate are pretty thin, so the hollow underside of the PCM spacer creates a vacuum leak without the plate.
Summit has a 5 degree wedge for $35, and a 8 degree wedge for $65.
Still, while some marinizers used wedges (like OMC and H-M), you shouldnt need one to get your boat to run right if it wasnt originally so equipped.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: November-18-2011 at 8:11pm
Hmmm, the source that mentioned that was strictly a Holley publication and not necessarily Ford or marine specifically, so I may be a little confused there. When Kap mentioned spread bore, that kind of threw me off.
Does anyone ever use Weiland stuff with Correct Crafts? Being that its Holley's own brand, do they fit any better?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: November-18-2011 at 8:19pm
Theres no L in Weiand. Several of us have run them- I have a Stealth on my '90 and a Skier that hasnt hit the water yet. The BFN and my sister's Stang both have Eddy Performer RPM's. Both are good intakes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: November-18-2011 at 8:29pm
My HM was originally a 2bbl with a cast wedge spacer w/ a pcv port.When I changed to a 4bbl I got the phenolic wedge above.It had no port so I drilled a hole in it and epoxied a pipe in it for the hose.On the bottom side I took a dremel and cut in the vacuum passages.I am using a Holley Contender manifold that was produced before Holley owned Weiland
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jllogan Quote  Post ReplyReply Direct Link To This Post Posted: November-19-2011 at 12:17am
Ya, thats exactly what I was thinking just retrofit a wedge to accept the pcv
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: November-19-2011 at 3:06pm
There are some plastic wedges with the PCV nipple or hose barb built right in.
Shop around a little before you purchase.
But, If I do decide to part with the Offenhauser, you'll get 1st dibbs.
And hopefully we'll have some CC gift wrap paper by then. jajaja
EDIT: 6/16/2015     I'm ready to let loose of the 12 degree Offenhauser wedge
It's listed in CCF's - Boat Parts For Sale.
