Running boat on land |
Post Reply | Page <12 |
oledb4
Senior Member Joined: December-06-2011 Location: Orlando, FL Status: Offline Points: 122 |
Also, is it a good idea to convert to electronic ignition? And how expensive is this? I'm thinking if it is not too expensive to just have the Nautique shop do it when they are doing a tune up on it. Any thoughts??
Bri892001
Probaby one of your best best for this test drive, and not bad to have in general is one of those rechargeable jumper backs. Good to have for boat, car or whatever. Traditional jumping is a PITA if not impossible, because you can't line up your truck battery with the boat battery very easily with the boat in the water.
If you buy the boat, and need to replace the battery, you want a starting battery. The only way you'd get into deep cycele for a boat like that is if you had some kind of monster stereo setup and were running dual batteries like Jllogan mentions above. |
Jllogan
yes a regular battery is fine, no you dont ever want a deep cycle in these boats unless you are running a trolling motor. Or you want to run 2 batters and run the deep cycle for accesories while the boat isnt running. |
oledb4
Also, I should be taking and posting pictures tomorrow to get some feedback. Thanks guys.
oledb4
So I talked to the guy selling the boat, and we are going to drop it in the water tomorrow just for a quick test run. Do I just need a regular battery for this? And am I going to eventually want a deep cell if I purchase the boat??
Jllogan
This guy tried to run his boat on land
This lady tried to run her car on the water |
peter1234
did marine batteries just recently stop making the stud wing nut combination for some reason?
Bri892001
Or Pete himself will explain
Bri892001
Good we caught you in time on the battery thing. Check out this thread:
What size/type battery for a 95 SN? I'll paraphrase Pete's most noteworthy quote from the thread:
A deep cycle is made for low amp draws over long times (like a trolling motor). The starting load is the exact opposite being a very high amp draw for a short time. It will kill a deep cycle. As HW mentioned, the "marine" has studs - you don't need them. Did someone actually tell you you needed a marine deep cycle? |
quinner
Don't buy any hose as Bri linked as it would be a total waste of money and totally overkill, also not sure I would run out and spend $70-$100 on a battery you may not even need plus do you even know what kind of battery connections the boat has, Top, Side, Rings??
If the boat is not to far away go inspect it, take some pics, and report back. If there is a battery in the boat try a charger or jumping it, another option you might just be able to use one of your vehicles battery to start it or borrow one if possible. |
I haven't done any battery shopping in a while, but sometimes "marine" simply means you get 5/16" studs next to the regular old top posts. Read the label, you do want a starting battery.
batteries explained at boatsafe |
oledb4
Interesting, we were planning on buying a deep cell marine battery. Why do I want a regular automotive battery in this case?
Bri892001
Bri892001
It should. Another option would be to get some 1" (correct me if i'm wrong on size Larry) cooling hose. Undue the intake side of the strainer and extend that to your bucket. The hose can be pricey though.
I saw you mentioned replacing the battery. Remember, you want a regular automotive starting battery in this case. Group 65N. This is one instance were you don't want "Marine" and you especially don't want a marine deep cycle. Just an automotive battery, and they don't all fit in the battery box, that why you need the 65. If it's sat for some time, expect possible carburetor issues. This is not an automatic deal breaker though, if the boat is otherwise good shape. |
high rpm = 1,500
quinner
For what you are trying to accomplish option 1 is fine, bring duct tape and a 5 gal bucket also, if there is enough pickup hose to put it directly in the bucket, as Larry mentioned, a better option, if not however just run it directly connected to the hose.
If doing option 1, Turn the water and boat on together, same with off, avoid sustained high RPM's as the draw "should" exceed the hose output and could literally outdraw the supply and possibly run "dry". You should also bring your camera and take and post lot's of pic's here were you will undoubtedly get some great feedback on what you are looking at. |
oledb4
Gotcha. So for the sake of just firing it up, connecting the water hose directly into the intake hose should suffice??
75 Tique
Grand Poobah Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6108 |
Exactly, in fact I went to find that picture, but couldnt come up with it right away. No need to valve off between the fitting and the thru hull either. Water will run out the thru hull till you start the boat and the the pump will pull the water to the engine.
oledb4
Is this what you mean by option #3?? |
75 Tique
That thing is probably fine, but a little complex.
There are a few simple ways to go. 1. Undo your water intake hose at the thru hull. stick a garden hose in it and clamp it down, should be the right size. Turn on the water, start it up. 2. Come up with a little plumbing and a little bit of hose and extend your water intake hose (again removed at the thru hull) so it is long enough to reach into a 5 gallon bucket. Fill the bucket with a garden hose and keep the garden hose running. Start the boat and it will draw from the bucket. The advantage of this method is it will demonstrate your water pump is working. If you use method 1, the hose pressure will fill the motor and you dont know if the pump is actually working. bucket method link 3. Some people plumb a T with a valve into the water intake hose. This is good because it makes running on the hose quick and easy. 4 and 5. There are store bought alternatives. Search fake-a-lake or perko flush pro, but both of those are unnecessry expenses and work no better than 1,2, and 3 |
oledb4
I am looking into buying a 1986 Ski Nautique 2001 for my first boat. I want to get it in the water, or at least crank it up and see how it runs. To my understanding, it is bad to have a boat running on land without a water source??? A guy suggested this to me: Flushing adapter
Does this seem pretty legit? The boat has also been sitting for close to a year and needs a battery. I'm going to get a new battery obviously, and then some clean gas. Should this be sufficient to get it running? I'm just worried with it sitting for so long I might not get a true representation of the engine you know? I would definitely get a tune up done if I bought the boat just FYI, but I don't want to spend $$ on that unless I am for sure going to buy it. Any advice/thoughts are helpful. Thx guys!! |
