Custom 1965 Correct Craft Mustang build |
Post Reply | Page <1 1516171819 32> |
Well done Jim looking good. Did you drive it yet or were you just floating it?
Hussler
Gold Member Joined: February-04-2012 Location: - Status: Offline Points: 895 |
Oh I sure did drive it! Thats how I found out the motor was blown It drives just how I hoped it would, no pouposing and it goes very very fast havent gpsd the top speed yet, and i probably wont get to until next year :/ |
63 Skier
That boat with a warmed up 351 will be scary fast.
Hussler
Without the interior and whatnot it is already scary fast, you can just crank the wheel and blow out a nice rooster through the turn. Love it. Even got a couple cheers from different docks because of my antics, many people came by the marina to ask about it. Feeling pretty proud of how its turning out so far |
john b
Grand Poobah Joined: July-06-2011 Location: lake Sweeny Status: Offline Points: 3238 |
Has anyone successfully fitted a 351 in an old Mustang? I couldn't find a thread on a swap when I searched, just a lot of discussion and what ifs. Unless it would fit under the stock doghouse I would have to get skinnier feet to get to the back seat. It's silly narrow as it is.
Hussler
Mine fits just fine under the doghouse, just needed a 3 inch booster, theres more space on the sides than 50's v8 centurys, if you consider those spacious |
john b
I win idiot of the month for forgetting that you Installed that 351 in it. I have followed the thread since the beginning and should be spanked for that question.
Is it the center riser exhaust or a taller intake that requires the 3" bump? It looks really nice. |
John- Peter 1234 has despite what the ad says a Skylark with 350 Chevy,which I might add anyone can make go fast and I think there was one at GL a couple of years ago that had been regeled orange with a 351. Link
peter1234
Gary . I sold mine in the spring.
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21120 |
Gary, are you thinking of that dark orange (tangerine?) Mustang that had been repowered with a newer 350 (~260hp)? I think it GPS'd right around 50.x. There was talk of a 351w powered Mustang that showed up one of the years I couldnt make GL- but it had a modified motorbox. Width has always been the issue, and I thought the consensus was that a 351w would have a really hard time fitting under that older (pre-70) glass box, and PCM style manifolds on a 351w were definitely a no-go. Some people have put those on 302's and reported that they rub the sides. I need to go measure my intakes... I want to say the 351w is about 2" wider than a 302.
Bakchose
Gold Member Joined: November-04-2004 Location: Boston, MA Status: Offline Points: 554 |
Great work. I remember the color combination debate. I think you nailed it. Can't wait to see pictures of interior when it is installed. What a great resurrection of an old and tried CC.
Oops,I thought you had changed your mind Peter and tried to pull that ad. ---
That's the one Tim, time has dimmed my memory,I thought it was a Ford. is a Chevy about the same size as a Ford? |
There was a 351 in a mustang that showed up to McCallums for one of the reunions as well.. with a modified box. Adding the riser at the bottom effectively widens the box down at the manifolds and helps with the fit.
Hussler
Its actually not the width interfering its the height, theres a good inch play side to side, the humps are catching at the top |
Hussler
Just a collection of random pics, marina FINALLY closed so I'll have some time to finally finish some things on the cc.
Bought meself a new tent. Dash turned out really well, happy with how the look flows. Accessory gauges are stewart warners, tach is a Sunpro, all new. Refurbed gas tank, cleaned out, cut off old fill tube to relocated fill, welded up that plate on top, new sender, new fittings and painted because why not. |
Hussler
Smithfamily
Wow. Looking great!
Js
Kristof
It is custom, but still looking great.
Keep paying attention to details as you do... |
Hussler
Thanks guys, I plan to start making the seats tomorrow. The front one is going to be interesting
dwcar
Platinum Member Joined: February-11-2007 Location: Houston Texas Status: Offline Points: 1103 |
nice work Jim!
83Ski
Hussler
Its been very cold and miserable out but I've managed to "finish" the framework for the seats. Really bummed ill have to wait for warmer weather to finish paint and have them covered, probably for the best they are one of the last things done. Im uploading like 60 pics so it will take awhile.
College is also done for the semester so I'll have plenty of time to screw around with the smaller details |
Hussler
Alright so normally I dont explain much in my pics, but this **** is all from scratch so it probably needs some splainin.
A piece of plywood! This is pine, bought it because it was cheap. You will notice though that the color of the wood changes later on ( keep this in mind) Getting the right profile was an extremely daunting task, wasted quite a few pieces figuring out the back angle rise run ect. This is the top of the seat, hopefully the pics make sense. This is after the front cut to match the profile of the seat back Then I attached the rear facia. I got the proper curve by attching the facia, tracing it along the curve of the top board than removing it and cutting it. The face of the seat back is a different angle however due to the change in slope! Rear fascia. Testing fit. |
Hussler
Hussler
This is where things get goofy, notice the tint change? I started over! Using the dimensions I liked and the dimensions that needed some tweaking. Used the good doug fir plywood for this iteration. Major changes were a shortening of the seat by a 1/2, Narrowing of the back by 1/2 and a change in support of the bow using plywood this time. Ski pole still needs to be shortened. Unfortunately didnt take many pics second time around, of course building the second one was much easier than the first. |
Hussler
Hussler
Hussler
Kristof
I like how the seating is working out except the back seats backrest,I'm thinking that it should be the same height or a little lower than the rear deck. I don't believe with that sticking up that you will be able to cover it with vinyl,hide the staples and avoid wrinkles. Hope you don't think I'm criticizing,but it seems when I redid mine this year I had more trouble getting it to look good than the first time I did it and mine is lower. Maybe the vinyl used was thicker this time,I don't know. You might be better than me on vinyl work too,what the heck do I know
Hussler
Its funny you say that gary, It got trimmed down another 1/2 but I didnt bother taking new pics. It was a tough height to mess with because I was following the angle built into the back of the boat. It would definitely look silly with the front backrest lower than the rear. I like your train of thought
