  New Posts New Posts RSS Feed - Custom 1965 Correct Craft Mustang build
 Post Reply Post Reply Page    <1 29303132>
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-18-2016 at 6:32am
Originally posted by Hussler Hussler wrote:
I know it's bad enough where I have to snug down the packing quite a bit over the last two years
The rudder port packing can be tightened lots more that what you would do on the prop shaft packing and is typical. The rudder shaft isn't constantly rotating like the prop shaft is.
Hussler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hussler Quote  Post ReplyReply Direct Link To This Post Posted: April-18-2016 at 5:42pm
Good news, shaft had only about 1/4 play all directions. Bad news, rudder has a small crack right where the rudder casting meets the shaft casting. Not sure if it's been there this whole time or if it's been developing, definitely has something to do with the bend. I don't know where I could find somebody to take a look at welding it but don't feel too comfortable about using it now. Camera couldn't pick it up, it's about 1/8 deep, looks like it's tearing
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-18-2016 at 6:34pm
Jim,
Have a prop shop look at it.
peter1234 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter1234 Quote  Post ReplyReply Direct Link To This Post Posted: April-18-2016 at 7:07pm
I had a prop shop look at mine they thought they could straighten it. they gave it bck to me in 2 pieces
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hussler Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2016 at 8:33pm
I actually lol'd at that (sorry for your loss)
So because summers coming up on me quick I saw a Correct Craft rudder on ebay and just snatched in up. Says it's for a full size tournament ski nautique, it's definitely a little larger I'll post up pics when it arrives. It was only $70 shipped so if it doesn't look like it will work out no great loss
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2016 at 8:51pm
Jim,
Did you check the size of the port needed?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hussler Quote  Post ReplyReply Direct Link To This Post Posted: April-21-2016 at 9:56pm
Welp, the rudder I bought was a bust, bent to the left. Doesn't have any real mares on it so I can understand it being a honest mistake. Back to square one I guess
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-21-2016 at 10:07pm
Jim,
I gather the prop shop you took your existing rudder to said they couldn't fix it. If so, I'd suggest trying another shop.
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter1234 Quote  Post ReplyReply Direct Link To This Post Posted: April-22-2016 at 9:13am
doesnt Glen-L have an assortment of rudders?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-22-2016 at 9:30am
They do but wow, $$$ and some are chrome platted steel!
Buck Algonquin has more
I'd sure look into the repair first.
Jim,
Do you have a picture of the rudder you can post so we can take a look at how bad it is?
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: April-22-2016 at 12:17pm
Jim,
I would be leaning heavily towards a “speed rudder” in that boat.   The stock rudders work well for lower speed maneuverability but they have a tendency to suck air and stall, that coupled with a low nose and hard chines likes to flip the boat around as previously discussed. One remedy employed successfully on several fast 16 foot boats around these parts is a speed rudder or a hybrid design rudder. They are less available than they used to be but if you keep your eyes out you will find one.   A plate behind the rudder to prevent sucking air might help as well.
Duane in Indy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: April-22-2016 at 12:27pm
Joe, I am interested in the speed rudder also. Saw some listed and I don't see why a stock one could not be reshaped into a speed type. Looked as though it is a case of removing stock and re-contouring as opposed to adding material. Explain the plate behind the rudder also. PM me if you don't want to go into all the details on this site. I can give you my cell # if needed. Also have thought about "softening" my chines. Thoughts??
        1978 Mustang (modified)
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: April-22-2016 at 12:48pm
Duane I wouldn't mind talking it over sometime but a lot has already been covered here in various threads like this one
Old thread with a talk on skiing vs speed needs
I would be careful on modifying a rudder that you are going to run fast.. they do break and some act crazy when even a little off in my experience... you would be better off welding one up in steel and shaping if that was the route you wanted to go
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: April-22-2016 at 1:16pm
Good reading material Joe. Thanks,
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter1234 Quote  Post ReplyReply Direct Link To This Post Posted: April-22-2016 at 2:44pm
That's it Buck algonquin.. I remember the race rudders but also that when i wanted one every design i looked at was backordered for what seemed forever
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hussler Quote  Post ReplyReply Direct Link To This Post Posted: April-25-2016 at 1:14am
Hm, interesting. As far as driveability at high speed it steers quite nicely, but the thought of rudder stall is always at the back of my mind.
I'll run my rudder by my prop guy, but the thought of fixing the crack doesn't really make my socks go up and down.
I could make a rudder plate pretty easily, so I might just do that for kicks.
I have a buddy that has a rudder from a '85 tique I was going to check out.
I was also thinking about the rudder that century put on the small v drive Arabians and Marks, those are about 17ft boats capable of 50Mph+, seems like it would be pretty close in specs to what I'm looking for
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hussler Quote  Post ReplyReply Direct Link To This Post Posted: April-30-2016 at 1:26am
Good news, got the rudder off a Ski Tique for $50 that is mint, should be here in a couple days. And I'm also now in this I guess, boat owners encyclopedia, and I got a FREE STICKER!
As soon as the sign up is open I'll be going to the Old Forge Rendezvous which should be a good time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: April-30-2016 at 1:34am
I think that's the same rudder I posted in my pic. Did you get the port too?
74Wind View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 74Wind Quote  Post ReplyReply Direct Link To This Post Posted: April-30-2016 at 2:02am
Here's the rudder on my Mark II
1974 Southwind 18
1975 Century Mark II
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hussler Quote  Post ReplyReply Direct Link To This Post Posted: April-30-2016 at 3:56am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hussler Quote  Post ReplyReply Direct Link To This Post Posted: April-30-2016 at 4:09am
Hmm after staring at quite a few pics I don't think it's from a Correct Craft at all, measures out to almost identical measurements as a 80's cc rudder but this rudder comes to a point, interesting I guess?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hussler Quote  Post ReplyReply Direct Link To This Post Posted: May-01-2016 at 4:37am
I have terrible news, the rudder is off a... Mastercraft haha.
I'll now have parts off a Century (ladder, exhaust outlets) Chris craft (step pad frames) and Mastercraft
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hussler Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2016 at 11:45am
Just finished testing the trim tabs, writing this from my hospital bed...
Just kidding
This upgrade couldn't of been more of a success, I went on the first run with my boss, got it up to about 42mph when it started porpoiseing, lowered the tabs a little and boom gone! We both looked at each other like F#ck yeah, fixed! Trimmed it out a little more and brought it up to 53mph. It felt more stable than it ever had.
Only 2 cons I can think of, there's a huge jet boat like ploom that pops up when you start trimming and I'm not a big fan of how they look. Might paint the actuators white. I'll take a video today
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hussler Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2016 at 11:46am
Just kidding
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hussler Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2016 at 11:50am
Post Options Post Options   Thanks (0) Thanks(0)   Quote fanofccfan Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2016 at 11:51am
Patiently waiting for the video! Good to hear they worked and here is to hoping they continue to do so safely!
DVskier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DVskier Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2016 at 3:37pm
Someone check on Pete. I think he might have passed out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2016 at 8:03pm
No, I'm still here! I just got home from wearing the orange apron all day. The DIY'rs were nuts today!!!
I'm waiting on the video as well and certainly hope the tabs work out especially from the aspect of safety.
Kristof View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kristof Quote  Post ReplyReply Direct Link To This Post Posted: June-01-2016 at 6:58pm
Anxious to see that video posted here...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hussler Quote  Post ReplyReply Direct Link To This Post Posted: June-05-2016 at 8:46pm
Sorry it's been pouring here most days, might clear up Tuesday. Had 5 people in the boat and it felt great at 52mph
