  New Posts New Posts RSS Feed - ignition re wire ?
ignition re wire ?
dans View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dans Quote  Post ReplyReply Direct Link To This Post Topic: ignition re wire ?
    Posted: May-14-2006 at 1:44pm
I am installing a new key ignition on my 82 2001 sn. What color wire is for the ignition , and what color wire is for the solenoid . I know the battery wire cause it has a red stripe on it . The other wires left are orange & purple . The purple wire could be a bluish color also. PLease help , I had to hot wire on the water and I fogot the wire locations . Thanks , Dan
Atmspltr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Atmspltr Quote  Post ReplyReply Direct Link To This Post Posted: May-14-2006 at 2:21pm
Purple is from the ignition (switched power...also goes to instruments, accessories powered when key is 'ON') purple wire also goes to ECM
Orange is battery (fused power directly from battery )
dans View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dans Quote  Post ReplyReply Direct Link To This Post Posted: May-14-2006 at 2:32pm
Thanks Dan
Post Options Post Options   Thanks (0) Thanks(0)   Quote Atmspltr Quote  Post ReplyReply Direct Link To This Post Posted: May-14-2006 at 5:12pm
there is a website (www.skiboathelp.com...I think)that had a reference document of color codes and a schematic of a typical boat electrical system. I found it helpful when I re-wired mine. I don't recall the solenoid arrangement. It took me a few tries to get it right when replacing my solenoid.
