  New Posts New Posts RSS Feed - Prop key way is sheered
 Post Reply Post Reply Page    <1 34567>
BaccoBouncer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BaccoBouncer Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2016 at 12:10am
When you say "straighten the strut" what are we talking about here?
Ratcheting straps tied to a truck next to the boat?
Taking it off and putting it on a vise on a bench and pulling on it?
'97 21' Sport Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote BaccoBouncer Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2016 at 12:07am
Adam,
A new cutlass should have close to zero play depending on both the shaft OD and the cutlass ID tolerances.
Are you watching the alignment 101 video I linked? I only ask since you may be confused on who did the video.,
Oh that is you in the video. Fantastic instructional. I have to say usually people that are so good technically aren't so good looking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: May-22-2016 at 11:24pm
Unless your log is rubbing on the shaft you can pretty much ignore the log alignment the flexible hose hook up will adjust for that. The important alignment is the strut facing the engine and tranny, that needs to be perfect. Watch the video's they will give you to tools you need to get this right the first time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: May-22-2016 at 11:14pm
Mine was bent by the owner I bought the boat from. The prop had been repaired but the boat had a strong vibration. This is two years ago and memory is not perfect but I will try and share. That was my first issue with a bent strut and this forum helped get it perfect again.
They had run mine enough while vibrating to ruin the coupler at the tranny.
I took my rudder out, this gave me extra room and I wanted to make sure the packing was good.
I made a small tower out of a 2x4 about 6" tall and cut a v shape in the top. I used this to keep the prop shaft from sagging from its own weight and supported the front of the shaft a few inches back from the tranny with this block while I played with the strut alignment.
The shaft will sag a little when sitting loose in your strut and log.   Find the spot where your prop shaft spins with zero drag or the very least amount of drag while in the strut.
This is the happy spot. Hopefully your shaft while in this happy spot is very close to perfect alignment with your tranny. Again I only used the 2x4 to keep the front of the shaft on the engine side from sagging. If you slide it too far to the log and lift the shaft is will add drag, Too far to the front by the tranny and it allows sag and adds drag.
My installed shaft was not pointing at my tranny so I had to bend the strut a little and then had to work on the vertical alignment to get it right.   I was adjusting the verticle alignment when I added shims and sanded the strut. I hope yours is very close and you don't need to do any of this.
Slip your shaft into the strut and log, move it forward till it is close to your tranny. Spin it by hand. There should be nearly zero drag. I did use the newer plastic cutlass bearings which offer very low drag.   Lubricate your strut before install to make sure you have low drag. It will help find the happy spot.
While it is spinning freely and in the happy spot slip it to the tranny and see if it aligns so you can slip it right up and connect it. If you need to move it right or left or up or down you are not aligned.
Your picture shows bolt D and mount E. Loosen D and you can move C in and out of E.
If you need this adjustment you need to loosen both sides of the engine. Doing one side will not. I use a large pry bar and a couple short 2x4 blocks to pry against so I don't damage the fiberglass. Lubricate your adjusting mounts to ease the work.
Before you start adjusting think about what needs to happen to move your engine to perfect alignment for your happy shaft. Then start adjusting the 4 mounts to get there.
If your engine mounts can't get you in alignment you will need to adjust the strut.
Take your time and get this adjustment as close to perfect as you can.
After install mine would turn freely with one finger pushing the prop while fully bolted to the tranny. It has been vibration free since.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-22-2016 at 10:53pm
Adam,
Post Options Post Options   Thanks (0) Thanks(0)   Quote BaccoBouncer Quote  Post ReplyReply Direct Link To This Post Posted: May-22-2016 at 10:48pm
oh ok. I thought you were saying I have to do something else if it is bent vs just misaligned. If I'm not centered on the log then start aligning the strut. Is it true what he said in the video that the cutlass bearing should have zero play?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-22-2016 at 10:46pm
Originally posted by BaccoBouncer BaccoBouncer wrote:
How do I determine the strut is bent from the prop strike? What do I do it if it is?
Adam,
A bent or twister strut will show up if the shaft doesn't center in the log and binds in the cutlass bearing..
Post Options Post Options   Thanks (0) Thanks(0)   Quote BaccoBouncer Quote  Post ReplyReply Direct Link To This Post Posted: May-22-2016 at 10:37pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-22-2016 at 9:59pm
From MrmCD's post I see that I may have an issue if the shaft isn't center with the log. ( Is the log the hole in the bottom of the hull for the shaft to enter. it was clearly to one side. So this with the fact that the couplings did not line up probably means I need to align the strut. looks like from his post I should be able to shim with SS washers but keep it under 0.100".
Adam,
I suggest you watch shaft alignment 101 again keeping in mind alignment starts at the strut. The shaft should go through the log (yes, the hole in the bottom) centered when the shaft turns freely (is "happy") in the cutlass bearing in the strut. Don't loosen the strut until you determine it's not aligned. It also may be bent from the prop strike.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BaccoBouncer Quote  Post ReplyReply Direct Link To This Post Posted: May-22-2016 at 9:27pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote BaccoBouncer Quote  Post ReplyReply Direct Link To This Post Posted: May-22-2016 at 9:21pm
Ok Status Update and question.
The A.R.E. shaft/coupling are in. I'm running about .007" of misalignment so I have to do some adjustments. But first this question. As I brought the shaft coupling up to the gear box coupling they didn't line up. I had to pull the shaft a bit to one side to get the two to come together. is this normal? ok?
ok alignment. As you can see I put a picture below. So I can clearly see how to adjust up down I imagine it is break nut "B" so "C" can move freely then turn "A" to raise it up and down then lock in place with "B". But how does starboard/port? It looks lik emaybe you loosen the nut "D" and maybe the shaft coming off of "C" will then slide in and out of block "E".   ????
Post Options Post Options   Thanks (0) Thanks(0)   Quote BaccoBouncer Quote  Post ReplyReply Direct Link To This Post Posted: May-22-2016 at 11:08am
Perfect thanks! It has the torque for the nut which was the main thing I was looking for.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: May-21-2016 at 10:49pm
Hi Adam
Go to .elberts.com They're the ones who made your shaft.
Cllick on the "product instructions" section on their homepage
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-21-2016 at 8:48pm
Anyone know where I can find the A.R.E. install manual online? I didn't see a link through DIM or in a google search. Too much comes up for ARE
Adam,
There should have been some basic instructions with the shaft system. Not much in them since the install is like other shaft installs with the exception on tightening down the forward coupling on the taper.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BaccoBouncer Quote  Post ReplyReply Direct Link To This Post Posted: May-21-2016 at 7:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: May-19-2016 at 4:01pm
Prop Shaft video good Basics for set up
https://www.youtube.com/watch?v=3_w0LvD6gEc
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: May-19-2016 at 3:59pm
Mine was a little more involved as my strut got bent and needed to be fixed plus I replaced strut cutlass bushings at the same time. I included the link to my prop shaft replacement. There should be tips in this that will help. There is a very good video on aligning the prop shaft that should be watched also.
The very good advisors here helped get mine in correctly.
Not that hard to do right but critical to avoid vibrations in your boat and short life on the parts you are putting in.
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=32813&title=prop-strut-installation
Post Options Post Options   Thanks (0) Thanks(0)   Quote BaccoBouncer Quote  Post ReplyReply Direct Link To This Post Posted: May-19-2016 at 11:55am
So I have my ARE shaft and will be installing it soon. What's my best resource for motor alignment procedure and any other steps to ensure a good install of the shaft? Even thoguh I may have some local help I would like to read up on it as much as possible in advance.
Thanks Again, Adam
Post Options Post Options   Thanks (0) Thanks(0)   Quote BaccoBouncer Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2016 at 1:00am
Tony, The A.R.E. shaft is on it's way. Thanks for the offer to help. I purchased the boat with the bent prop. It came from Lee Mass and was used on some of the small lakes out there.
DayTony View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DayTony Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2016 at 2:14am
Congrats.
Spray down your motor mount adjusters with penetrating oil, try not to overspray everywhere. and order up a fresh shaft and wheel. If you need a hand with setup some afternoon I'm sure I can donate a little time.
So, Did you sheer the pin on chebacco or was it somewhere else? there are some real shallow areas in that lake you have to be careful of. I have hit bottom in that lake more times than i like to admit in the BFN but i draw at least a foot more than you do in the sport.
1988 Barefoot nautique-454
Post Options Post Options   Thanks (0) Thanks(0)   Quote BaccoBouncer Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2016 at 11:45pm
I wanted to share this moment of victory with you guys. Prop in one hand, drive shaft in the other.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DayTony Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2016 at 6:19pm
oh my bad, my trailer that frame is removable, i suspect just for that reason.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2016 at 5:18pm
All good, lift away!
Post Options Post Options   Thanks (0) Thanks(0)   Quote BaccoBouncer Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2016 at 5:15pm
The protective plate is a welded part of the trailer. How wise/unwise is it to lift at this point on the hull with a hydraulic jack and a piece of wood as a pad? Will I crack the gel coat?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DayTony Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2016 at 4:47pm
nows a good time to asses condition of your cutlass and replace if needed.
Not sure if your a brand new boat owner but you'll quickly find out. Once you own a boat everything else starts seeming more and more rea$onable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DayTony Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2016 at 4:41pm
that protective plate should unbolt pretty easily. if i remember i only unbolted one side of mine and it gave me enough clearance but you might have to unbolt both sides. they are like 5/8 bolts.
lower the tongue and should slip out easily.
as for shaft length i don't know but a good number to write down is if you take a tape and go through the hole to the mounting flange surface on the gear(transmission) and to the aft end of the strut. you want it to be a hair longer than that, maybe 1/2" between prop fitment and strut.
Some of the guys who have done this i'm sure will pipe in about best shaft size for your application. since its not a cut to length deal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BaccoBouncer Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2016 at 4:38pm
Update:
Ready to order the ARE system but wanted to confirm shaft length first. Can't drop rudder because of protective plate on trailer. I don't have a way to slide the boat back on the trailer. Is there a safe way to lift the boat to get enough clearance? Can you jack under the back of the hull dead center safely?
Thanks,
Adam
Post Options Post Options   Thanks (0) Thanks(0)   Quote BaccoBouncer Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2016 at 11:08am
Originally posted by DrCC DrCC wrote:
So, how did you attach the lamp to the lamp base ?
You must be asking DayTony. Mine is a clamp light and it's sitting on a wood box that was kicking around.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2016 at 9:47am
Originally posted by SNobsessed SNobsessed wrote:
Thanks Pete for the correction. It's been almost 10 yrs since I did this, thanks to the gore-tex packing!
Chris,
No problem! There are many times when I need help too especially when my ADD kicks in! A good example is Larry having to correct me this morning. Hopefully the Alzheimer's holds off for a few more years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2016 at 9:38am
