  New Posts New Posts RSS Feed - New project 1965 mustang
 Post Reply Post Reply Page    <1 34567 9>
Bilkolayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bilkolayne Quote  Post ReplyReply Direct Link To This Post Posted: October-03-2016 at 3:58pm
DrCC thanks for all the info..... it's a bit discouraging just looking at the mess that was under the dash..... I have wired other small block chevys in the past so it's not that bad I started by unworeing the starter and the plastic on the bendix broke so I went to the store and got a new one. The alternator does have a regulator externally. So I may be swapping that out for a one wire alternator I like them better. The ignition system that I picked up the other day is a thunderbolt MerCruiser ignition system so it's all electronic advanced. I will be changing some stuff up so I will be makeing my own harness. I'm going to start with the basic like starter and ingnition then I will wire in all the gauges lights and alternator. I at least want to get it turning over and possibly hear it run for a few seconds.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: October-03-2016 at 4:09pm
Ive been assuming this was a repower and the engine was LH or automotive rotation, do you know that is the case? The boat would have originally had a reverse rotation. Is the prop RH or LH? some of the electrical parts like starter and alternator should be marine rated to prevent fire and may be different depending on rotation of the engine..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bilkolayne Quote  Post ReplyReply Direct Link To This Post Posted: October-03-2016 at 4:33pm
The engine was definitely a repower as for the rotation I'll let you know. The engine cover has been been modified to fit the small block chevy in it tho.
Duane in Indy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: October-03-2016 at 4:35pm
Going off of the dist cap what is the firing order??
        1978 Mustang (modified)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bilkolayne Quote  Post ReplyReply Direct Link To This Post Posted: October-03-2016 at 4:39pm
It's a right hand rotation engine I just got it turning over with the starter. And the prop is a right head prop also
swilliams View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote swilliams Quote  Post ReplyReply Direct Link To This Post Posted: October-03-2016 at 7:06pm
Have you considered using a fuse block as part of your re-wire? I used the Blue Sea brand of components. Although it was a Carlson outboard, the fuse block kept things neat and organized. Nice job by the way!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bilkolayne Quote  Post ReplyReply Direct Link To This Post Posted: October-03-2016 at 8:33pm
I bought a 6 fuse fuse block that gone under the dash.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bilkolayne Quote  Post ReplyReply Direct Link To This Post Posted: October-03-2016 at 9:50pm
Got got to pickup a spredbore to norm bore carb adaptor because the old Rochester carb and the new one I bought are different. I'm wondering if I can slap a merkcruser intake on there for a 350
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bilkolayne Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2016 at 10:14am
I order a square bore to spredbore adaptor for the carb but that won't be inn until next week
backfoot100 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote backfoot100 Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2016 at 11:06am
Jon,
Let me play devils advocate for for a little bit here. I just can't help but think this is a huge accident just waiting to happen....for the second time.
While everybody (myself included) is going gaga over your most excellent work in super human time frames, there's this little guy in my head telling me we're missing something here.
1) You got a burned out boat because the PO had a fire WHILE TUNING THE CARB.
2) You've done all this work to bring it back to life when the vast majority of us would have most certainly just turned it into a bar. You obviously have some knowledge, skills and can turn wrenches......Bravo and well done my friend!!!!!
3) Many like Joe assumed this would be a repower but it looks like you're planning on using the same engine after replacing a few parts ruined in the fire.
4) You've confirmed that the engine is obviously not the same one that originally came with the boat due to the fact that the engine cover has been modified so the SBC fits under it.
5) Have I mentioned that you have taken on this project because the PO had an ENGINE FIRE FROM A BACKFIRE WHILE TUNING THE CARB. That would be the exact same engine that caused the fire in the first place!!!! Also the exact same engine that you're planning on using again!!!!!!
6) You've also confirmed that the prop and engine rotation is RH like it would've been originally.
See where this going? Under the circumstances I think you need to know the answer to some questions.
Why was the PO tuning the carb in the first place? A fresh rebuild? New carb? Maybe a whole new engine??????
Did the engine ever actually run before the fire or was he just trying to start it up for the first time?
Where did this engine actually come from?
Was it truly built with the proper RH parts and the proper RH direction or was it a LH engine that the PO put the wrong rotation starter on?? Believe me when I tell you this one is far more common than you would think.
What was the original engine?
There's probably even a few more questions that I'm missing here. My fear is that the PO had no clue what he was doing with the engine swap and that ultimately was the cause of the fire. That old "cause and effect" thing if you know what I mean.
If the engine ran perfectly fine and it was a freak accident..OK. I'll gladly crawl back into into my corner with a dunce cap and my tail between my legs..
If the engine was a fresh repower and he was trying to start it for the first time, that's a huge red flag that you need to investigate before mixing fuel, compression and spark or you could very well end up with the same results as he did.
Just my .02.
Eddie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2016 at 11:31am
That crossed my mind too Eddie. Do make sure the flame arrestor is on once fuel starts flowing. Don't assume the old starter was the proper one, make sure the rotor is turning counter-clockwise.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bilkolayne Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2016 at 11:52am
backfoot100
I understand your concerns I do believe this to be a true marine engine and I think it was out of a Chris craft at some time in its life I will check the rotation of the distributor and also get back with you guys with block numbers...... I believe it was a fresh repower with 0 hours the oil is brand new in the eingine and supper clean on the nice paint parts and the hour gauge read something like 12 and the belts never even wore threw the paint on the pullies..... the couse of the backfire is most likely pre detonation caused by the timing being Advanced too far. Once I get cylinder 1 to top dead center I will check the timing I have not gotten the chance yet to do so. That's my next step.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2016 at 11:58am
It's a Chevy.
The rotor is gonna turn clockwise.
If it's going counter clockwise...................you have problems, like the engine is turning the wrong way and it ain;t ever gonna start
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bilkolayne Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2016 at 12:15pm
It's a Chevy.
That's was my thoughts also the the distributer always spins clockwise regardless of the rotation just the wires are back words but yes the cam itself is different. Lobe wise and it should have timeing gears and not a chain so if I turn the crank righthand aka clockwise looking from the flywheel and the rotor buttens turns clockwise then it is a true right hand engine meaning crank and all
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2016 at 12:26pm
You state that it has 12 hours on it. The wires should tell you what way it ran before. Obviously other more positive ways also, like pulling valve covers and checking valve openings.
As far as the previous fire issue, it was said to be a carb issue which you have replaced. Not quite sure why you picked the present carb other than $$. It won't fit without an adapter. I personally would put it back together with the proper parts.
I seems that now is the time to slow down a bit regroup before attempting to restart the engine. There just appears to be too many unanswered questions. Take your time and do it safely and right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bilkolayne Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2016 at 12:34pm
The plug wires are in Reverse rotation I check that all yesterday. I went with a Quadrajet because I have had very little problems in the past with them and have a good bit of experience with them as well. The adapter is already on its way. And the Rochester that was on there is upwards of $400 to replace.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bilkolayne Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2016 at 12:37pm
The distributor spinning clockwise has a firing order of 1- 2-7-5-6-3-4-8
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2016 at 12:42pm
I was hesitant to post that, but glad it got the smart guys posting anyway...
While on the subject, is this correct?
LH Ford has a "normal" cut cam gear, resulting in CCW rotor
RH Ford has a reverse cut dist/cam gear, resulting in CCW rotor
LH Chevy has a timing chain, resulting in normal rotation cam and CW rotor
RH Chevy has gear driven distributor, resulting in normal rotation cam and CW rotor
^there is only 1 cam/dist gear for Chevies
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2016 at 12:57pm
I've wondered how a back fire lit the boat up. Were they pouring a cup of gas down the carb when it went off?
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2016 at 1:10pm
Good up to the last line, Not sure what you mean by "there is only 1 cam/dist gear for Chevies"
I think you want it to say "just for clarity" that.................RH Chevy has gear driven cam, resulting in normal rotation of the cam and CW rotor but the cam is cut differently for the reverse rotation firing order.
There are some RR Chevy's out there with reverse (CCW) rotation distributors but typically not on an engine you'd be talking about on this site.
I think Air 206 has some experience with ordering one of those distributors from DUI, not necessarily a good experience, since he had to return it to get one with the right gear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2016 at 1:12pm
RR GM 454's use a cam gear and not a chain, but do the RR SBC's as well?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75 Tique Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2016 at 1:14pm
yup.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bilkolayne Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2016 at 1:16pm
I was just told thay where tuning it. And Hollywood the cam on the chevys spin the same way left or right hand it's the timeing gear to gear on right hand or the timeing chan on left hand that depends on which way the crank spins
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2016 at 1:17pm
Yes, the cam itself is different because of the firing order but the distributor [including gear] is the same for either rotation engine. Thanks for clarifying all that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2016 at 1:19pm
Small and big block chevies also use the same distributor.
Pretty sure Kevin meant, "there is only one cam gear / distributor gear for chevies."
^^ that would be correct, at least as far as typical reverse rotation marine chevies go. Of course, different gears are available (material) but cut/rotation is the same.
There are reverse rotation gears out there like Ken mentioned... Not sure what they were originally used on but I believe Joe has a RH small block Chevy Stroker built up with a gear/chain timing set and a reverse cut gear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2016 at 1:28pm
A friend of mine saved a customer some money by buying a new LH crate engine and changed the rotation himself. I think all he did was reverse the pistons and rods, and the firing order. I don't think he had to even change the cam shaft. There must be different methods to the SBC as they're so versatile.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2016 at 1:30pm
I'm not sure that sounds proper Bruce, doesn't mean you couldn't make it run like that though...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bilkolayne Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2016 at 1:32pm
So all and all if my rotor button spins clockwise while the flywheel spins clockwise then it is a true right hand rotation as for if it's the right cam I will need to check the valves for the right fireing order which is no problem because I have the exhaust and valve covers off now. I will start with cylinder one at top dead center then the next to move will be cylinder 2 then 7 then 5 and so on
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2016 at 1:57pm
That may have worked great right up until they tried to start it! Cam is (engine) rotation specific... Even though they spin the same way. Small blocks are set up just like big blocks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2016 at 2:00pm
I don't think it is possible for the wrong rotation cam to spin the distributor clockwise. You should be good.
