1972 SN Promo Project |
Post Reply | Page <1 23456 13> |
75 Tique
Grand Poobah Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6104 |
One word:
Wet Lyfe |
Frankenotter
Platinum Member Joined: August-26-2012 Location: Milwaukee Status: Offline Points: 1072 |
Well I got some time with the boat again.
Got some parts pulled off the engine. I found the source of the odd noise......It's a cliff hanger, but Zach was right. Vid 5 Water pumps, transmissions, and pylons Oh my........... 1. How do you get the pylon out? Vid 6 A look into the doghouse gel. Vid 7 Bonus.......losing the valve cover bolt down the exhaust tube. Vid 8 |
1999 Ski Nautique 196
Chevy350
Gold Member Joined: June-24-2013 Location: Illinois Status: Offline Points: 721 |
Might want to check the videos. Might be just me though.
1972 Mustang
Frankenotter
Fixed the last 2. YouTube has gotten very user unfriendly.
I put hyperlinks at the bottom of the videos for those that can't see them. |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Online Points: 21120 |
That carter afb is original and appropriate. I'd soak it a bit to see if it comes back. Otherwise note the model number and start searching for another. Modern edelbrocks still use the AFB castings, a 600cfm would likely drop right in place if the budget allows. Alt looks like a newer replacement.
Pushrods, not lifters (those ride right on the cam. A little corrosion on these doesn't mean much. You'll need to spin the engine over twice to see all of the valves move once (it's a 4-stroke engine after all). The lifters are hydraulic and may have bled down from sitting. Priming the oil system would allow you to better assess. I still don't see any imminent signs of needing an engine rebuild. I've seen several engines from that era with the corrugated radiator hose on the front. Not sure if original but wouldn't surprise me. It probably handled tight bends better than the hardwall stuff from 40+ years ago. Trans likely has oil in it (as opposed to dirty ATF). Normal, and you can convert over to ATF when you're ready. Tap that bolt holding the pylon in the cup glassed to the hull (the hole in the pylon pin is not threaded). Doesn't look like the flange at the floor will hold you up, lol. Then the only thing holding the pylon in the boat is corrosion between the pin and cup. Soak with penetrating oil then use a large breaker through the ring/finger to twist free if necessary. I see several pieces of '73 hardware, ring/finger style and rear rope clearance bar are 2 obvious ones. |
bkhallpass
Ha. I don't know much about these things, and Tim knocked out 5 or 6 things that I actually do know in one post. BKH
Livin' the Dream
63 Skier
I had the same reaction. I think there's sometimes a tendency to assume an engine is bad, needs rebuild, just because it hasn't run in a long time. Short of being left out in the rain for years or frozen solid an engine is a closed machine bathed in oil. Yes, the oil runs off with time, and a bit of rust comes along with condensation from hot/cold weather cycles, but I've seen some pretty rusty looking heaps get cleaned up and run smooth and well with no internal work done. The key is these steps you are taking to find out what is good and what isn't, prime it to get the internals well oiled before putting stress on them. Then a compression test will tell more of the story, but won't surprise me if you run this engine as is. I know many here rebuild their own carbs, I've chosen not to, have had great luck using a carb rebuilder. It's expensive, but much less than buying a new carb. Just a thought. |
Frankenotter
1. Ok I put the carb on a tray and blasted it with Kroil on Friday. I'll get back to it sometime next week at try to get it moving. 2.i knew I was going to get called out on the pushrod/lifter jumble. Lol. I realized that I said it in the video and forgot to make an amendment. I see what you're saying Tim, my concern is that I don't think I have the components to get it running right now. The sides of the heads where the manifolds bolt on are very rusty and pitted. So is the area around the valve cover. I'm pretty sure the heads need to go to a machine shop regardless. So are you saying just prime the oil and check compression or try to get it started? 3. The hose makes sense and I guess I'll hang onto it for now. 4. I did give the bolt several good sacks with the hammer with no luck. I soaked it in oil before I left on Friday so I'll get at it again this week and try the breaker bar method if I can get it out. 5. Yea I noticed the pylon and the clearance bar as well. Interesting. A 73 promo? |
Frankenotter
I don't know what's wrong with you guys, tryin to save me money? Ha ha. OK I'll try to get the oil primed this week |
67nautique312
Gold Member Joined: June-23-2004 Location: United States Status: Offline Points: 883 |
Nice project!! would love to have an Orange Promo someday!! keep the vid's coming!
Paul, |
67 Riviera 68 barracuda 1971 Ski Nautique Promo 86 Silver Nautique 1995 Ski Nautique |
Frankenotter
Today I got some time with the boat and attempted the oil priming technique that Zach mentioned on page 3 of this post.
"To remove the Dizzy drive gear use a big screwdriver. I think you need to rotate it Counter Clockwise if memory serves me and it will come up out of the cam gear. It is sort of a PITA to get out without the intake off so pick up a 90 degree pick tool that is long enough to get under the gear to help you lift it out." Vid 9 Now for the $10,000 question, why is the oil not making it up to the rocker arms? 1. Oil clog? 2. Oil pump broken? 3. Oil quantity too low? (I don't think this is the case since the dipstick is at a good level and oil came out of the sender like a geiser). 4. The drill is not reaching a speed high enough to get oil to the rockers. (see vid 11) Vid 10 This is the primer shaft spinning the oil pump for speed reference. Vid 11 |
Frankenotter
I also got a chance to get a dial indicator on the prop shaft. Since the rudder is bent, one prop fin destroyed, and one tracking fin is bent, I have the theory that the boat was dropped at some point in its life. The standard to check the prop shaft "straightness" is to put a dial indicator on the shaft and spin it from the flange. We are looking for a runout less or equal to .003".
Here we can see the deviation is .005 " forward of the strut. Vid 12 |
How long did you spin it for? It may take several minutes for oil to reach the top of the engine.
63 Skier
Does your dash oil pressure gauge work? Might be interesting to see if you are building pressure when you spin the pump. Or even better put a mechanical gauge right on the engine to see.
Often you'll see pressure build on the gauge well before oil reaches the top of the engine... The sender is down low close to the pump, after all.
Old, thick, cold oil will also move much more slowly than a fresh 30w... Might be worth changing the oil if you really want to see it up at the valve train. I can't imagine it has oiling system issues of things look generally positive under the valve covers though. We're also assuming that you're spinning the pump in the proper direction... |
Frankenotter
We spun the pump cumulatively for 30+ min. It DEFINATELY needs to spin clockwise to prime. If you spin it counterclockwise it blows air bubbles, the likes of which sound like a baby demon blowing into a milkshake in the middle of the engine. When we took the oil pressure sender off and spun it clockwise oil came spraying out very quickly. I did not think to move the crankshaft at all and I can give that a try but the oil is very old. I haven't been able to find signs of clogging anywhere else but that doesn't mean it's not happening. I guess I can give it an oil change but do I have to use expensive oil? I'd rather not dump $45 of racing oil into an engine that's going to get dumped anyways. |
Remind us why you're priming the oil system.
Frankenotter
I'm hoping that's a joke. |
skutsch
Are you going to run the engine on this oil? If not then why not dump the cheapest lightest weight oil you can in (as it will flow better at the extremely cold temperatures you are currently working in). I don't think you are going to have issues protecting your flat tappets if all you plan to do is spin it by hand... |
67nautique312
I think what Timmy is trying to say is pull that thing and rebuild it from top to bottom. or maybe that's what I'm trying to say.....hope everything on the motor is ok...if not let me know and i'll take it off your hands...
Paul, |
Frankenotter
This all started as a suggestion by some of the members, not to mention any names (Tim) to see the general health of the engine before taking it out of the boat. The goal has been to get the engine oil primed and at least Spin it with the starter to check compression before pulling. I think that will be the next item in the agenda after a light weight oil change. Where is the drain hose on a 340?
There might not be one. I could loan you my TopSider extractor. I'd say put some light oil in there. Something is better than nothing for now!
No, seriously. I am failing to grasp what the concern is about the lack of oil up at the rockers would be. Reminding us what the goal of priming the system is may help us focus on the real concern? Not advocating for an engine rebuild... I am thinking the opposite. With all of the hull, structure, interior and trailer work in front of him, it would be nice to save some time and money on the engine (at least in the short term). Save the engine rebuild for a 1-winter project sometime after the boat splashes. Then it can be a a primary focus rather than another item on a very long list, competing with other (time, money) resources. |
Hes priming the oil system so he can crank it over without banging things around that haven't seen oil I in years-- jeesh
Could you also take off the valve covers and drizzle oil on the rockers like salad dressing? For some reason this would be my first move.
Well I know that... Just making sure he does! Would have been better if it was new clean oil but you've confirmed the pump is pumping and oil has been pushed around a bit. I'd pour some in from the top (spread it around) when you change it (light and cheap oil is fine). I've never seen oil get all the way to the rockers when priming... Haven't given it much thought or concern. Id also throw a bit down each cylinder. Then spin it over and see if you've got decent compression. |
63 Skier
I'd definitely change the oil. You are trying to oil all engine components before going to further steps to see if the condition is good enough to run as is, or with minor work. So, distributing old murky oil throughout isn't a good plan, do the change and distribute clean fresh oil on all surfaces. If you want to use cheaper oil you can, for this purpose, assuming another oil change is in the plan even if the engine checks out ok.
A few of us have a suspicion that engine might run well and strong without a rebuild, seems worth pursuing even if we end up wrong and costs a wasted oil change. |
We started a Ford this year that hadn't been run for about 7 years. We changed the oil and cranked it over for a few minutes without any spark plugs in it to get the oil circulating before we tried to fire it. On our Interceptors, I've followed instructions in the manual which say to take a wrench and compress each valve to make sure the valves and push rods are not stuck.
I definitely have enough fresh "variety pack" oil you can have too.
