  New Posts New Posts RSS Feed - PCM Ford electronic distributor installation instr
Cheiz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cheiz Quote  Post ReplyReply Direct Link To This Post Topic: PCM Ford electronic distributor installation instr
    Posted: October-29-2016 at 7:39pm
Newbie question does anyone have a wiring diagram and installation instructions for the PCM Ford electronic distributor retro kit
93 CC Nautique Excel CB 351 GT40
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-29-2016 at 8:47pm
Look at this       old thread
It may help, it may confuse you more
You can also look at the Discount Inboard Marine website and check out item #41015 which is the conversion kit they sell and there is a wiring diagram better than their hand drawn one in the link above.
This all assumes you now have a Mallory electronic distributor like the one in their kit If not, it would be good to know what you have for a distributor and if you have the whole kit
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cheiz Quote  Post ReplyReply Direct Link To This Post Posted: October-29-2016 at 11:31pm
Having trouble getting the distributor in
Nautiqueparts
Engine Parts > Electrical Parts > Electronic Conversion Kits > Electronic conversion kit for PCM FORD Left Hand Rotation Pro-Tec Motors, PCM # RK107025A
ELECTRONIC CONVERSION KIT FOR PCM FORD LEFT HAND ROTATION PRO-TEC MOTORS, PCM # RK107025A
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-30-2016 at 2:23am
Read this old thread about which direction your engine might or might not rotate
old thread
it'll probably confuse you but you have a distributor for a LH rotation engine going by what you posted from White Lake Marine and your engine might be RH rotation as you can see from the link above
The best thing you can do is see if your new distributor gear and old one match or if the teeth are cut in opposite directions.
LH teeth look like ///////    RH teeth are the opposite \\\\\\
If they're different, you'll need a distributor gear for a RH engine, if they're the same it looks like you're just having trouble getting the gears to mesh
Duane in Indy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: October-30-2016 at 7:37am
Like KENO said,   sounds like you need the one on the right
        1978 Mustang (modified)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cheiz Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2016 at 10:15am
Thanks all, looks like you were right, wrong direction distributor. Guess I have to get this one....right?
Electronic distributor kit for REVERSE Rotation (Right Hand) Motors. PCM# RK107026A
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2016 at 10:22am
The distributor is the same. All that's needed is the gear and then a R&R on the gear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cheiz Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2016 at 10:24am
Here is the picture before I took the Protec out, can it be confirm the rotation from here?
Also, does someone have a diagram of which plugs go into the distributor from what cylinders?
FYI, my motor was not starting at all
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2016 at 10:25am
From the other current thread with the same issue:
You could also get a distributor with a normal rotation gear and if you have your RH gear, have a machine shop fit it correctly.
That opens the door to more choices like a Pertronix or MSD marine distributor
You could send a PM to "Duane in Indy" who is a retired machinist and ask if he'd do it for you. It wouldn't be the first time he's done this for somebody on the forum
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2016 at 10:29am
That would be the right one and you wouldn't have to worry about doing gear swaps that can sometimes be not terribly straightforward
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2016 at 10:33am
Just by looking at your old gear, you can confirm it is a reverse rotation engine.
So, yes your engine is reverse rotation.
Do a search here on CCF about distributor installation, do a lot of reading and you'll probably understand how to install it and get the firing order right.
But after the reading, if you have questions, ask away and you'll get help here
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cheiz Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2016 at 11:18am
So just sliding the distributor in by rotating the gears on the oil pump/distributor? Once I get the right kit lol
Saw this thread but am looking for a diagram of the distributor cap top with what plugs go to each cylinder.
DUI Distributor Issue
My other questions (wish I had a picture but don't have access to my boat) but there are (2) yellow/red wires which I assume is going to the neutral safety switch, one is going to the 50 amp break and the other I had to cut off of the old Protec harness. Where do I need to connect this up to? There was also a light blue wire connected to the old Protec harness that unplugged from the harness.
PCM Owner Engine Manual
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2016 at 11:36am
Depending on how well versed you are with engine electrics, think about the basics. Here's Tim's wiring diagram that should help:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2016 at 11:36am
Get some one that knows how to install it to help you. Will need timing light also. Easy once you have done it a few times but very frustrating if you have not.
Firing order looking down on dist. cap. CCW rotation 1 8 4 5 6 2 7 3
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2016 at 11:37am
ProTec Ignition Swap
There is no wiring diagram for your spark plug wires. The rotor points at the post of the cylinder on the compression stroke and you follow the wires along with the order.
You should be able to definitively trace those wires to the NSS (by the color you sound correct) and then use the typical 70s/80s wiring diagram TRBenj drew up.
Why are you getting a new carburetor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cheiz Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2016 at 1:20pm
So confirmation that this is a right hand rotation and I need the following parts (fyi took out the starter and it was filled of gunk/water)?
I have to return the wrong rotation ones to Nautique.
http://www.nautiqueparts.com/electronicconversionkitforpro-tecmotors-1.aspx
http://www.nautiqueparts.com/starterkitrhreverserotation-permanentmagnetforoldercorrectcraftboatspriorto1989.aspx
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cheiz Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2016 at 1:26pm
Thanks all, so when I get the distributor in, plug wires go to it like in the picture below
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2016 at 1:32pm
What does your engine tag say? It should have a model number listed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cheiz Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2016 at 1:49pm
In the engine compartment above, where is it located?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2016 at 1:59pm
It should be bolted to the intake manifold. I'm not a v-drive protec expert. TRBenj, Air206 or velde99 would know for sure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cheiz Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2016 at 2:14pm
Any other way to tell? I would assume that the distributor teeth tell the tale?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cheiz Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2016 at 2:50pm
Looks like I am missing this tag but the manifold reads this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2016 at 2:50pm
Chris,
Several have mentioned getting help. Being honest here, it's starting to sound like having someone with a better understanding of engine ignition systems would be great. Do you have any friends that could come over and help out? We certainly will continue with any information we can give.
desertskier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertskier Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2016 at 3:04pm
The wiring diagram for your engine is on page 51 of the manual. In order to remove the Pro-tec you should have only needed to disconnect the trigger plug and the EMS connection. The neutral safety switch is wired to the wire harness plug but does not go to either of the Pro-tec parts. I would print out the wiring diagram and then use it to verify what wires you are cutting/disconnecting. It's pretty easy to follow. We can also use the same terminology from the diagram to walk you through it.
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2016 at 3:15pm
The teeth on your old shaft tell everything you need to know. It's reverse rotation
You bought the correct starter and the wrong distributor.
You have a Reverse rotation engine, you bought a reverse rotation starter.if it's what your link shows...............KEEP IT, it's the right one. If that's not what you bought and you are going to buy that one, then yes buy the one in the link since it's for a reverse rotation engine
You bought a normal rotation distributor.................exchange it for the reverse rotation version you mentioned earlier.
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2016 at 3:37pm
Chris,
I'm tending to agree with Pete on getting some help BUT make sure it's someone who understands that a 351 like the one in your boat can and does rotate backwards from a normal 351 in an automotive application.
The little diagram you have is good for cylinder locations and firing order, but you need to have #1 at Top Dead Center on the compression stroke and the rotor can be pointed at any tower on the cap. That tower is where #1 is,(you can aim it wherever you want) That's the hard part to understand and try to explain to someone. Then you work counterclockwise around the cap following the reverse rotation firing order. And you'll need a timing light because the initial installation will get you close enough to run it and then use the light to set the timing right.
It's harder to try to explain it, than to actually do it like Duane in Indy mentioned previously
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2016 at 3:38pm
So is the gear on the left on a distributor you purchased and the gear on the right out of your protec? The link above says RH but the picture of the distributor has a LH gear on it. I'm assuming they do have a RH gear distributor like the product info says. The fun never ends!
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2016 at 3:41pm
Hollywood, go to post #3 in this thread and you'll see the web address for the distributor he bought. Not a link there but the web address is right there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2016 at 3:47pm
So that's what is pictured on the left I assume. The URL says LH. Like you said, the RH item he found should have a RH gear on it (despite the picture) and will drop right in. I think we confirmed a while back all the engines in the v-drive Barefoot & Excels were RH.
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertskier Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2016 at 3:52pm
Not that it shouldn't eliminate your problem but it sounds like you are just shotgunning parts. Was your engine cranking over? Although, I guess it doesn't really matter at this point.
