  New Posts New Posts RSS Feed - 1998 GT-40 and 1.23:1 For Sale
wtrskir1964 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wtrskir1964 Quote  Post ReplyReply Direct Link To This Post Topic: 1998 GT-40 and 1.23:1 For Sale
    Posted: October-18-2017 at 12:33am
1998 Ford 351 GT-40 Multiport Fuel Injection engine for sale with 40A 1.23:1 transmission. 100 amp alternator.
1425 hours on engine,. 300 on transmission. Engine is in a 1998 Ski Nautique. Runs perfect.
Asking $4500.00 for the package, or $4000.00 for the engine and $1000.00 for the transmission separately.
Serious inquires, please.
Thank you!
Jim
stepper459 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stepper459 Quote  Post ReplyReply Direct Link To This Post Posted: October-19-2017 at 11:36am
I just sent this to a friend with a tired old carbuteted engine. I did a GT-40 swap on my old Supra, it was easy and well worth the time. Mine had 1,600 hours on it when I sold it and it ran like new.
Good luck with the sale, Maybe you'll hear from my friend.
What are you putting in its place?
Orlando76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: October-19-2017 at 12:18pm
Must run real good.
1976 Ski Nautique 351 Escort
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-19-2017 at 12:37pm
Morgan,
Did the opposite prop rotation do anything to the Supra handling?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75 Tique Quote  Post ReplyReply Direct Link To This Post Posted: October-19-2017 at 12:53pm
Morgan,
Pete, maybe you know, but it isnt stated here what year the supra was. My 89 had the same drive train as an 89 Nautique. Left turning engine, 1.23:1 reversing transmission. I can only assume supra had the rr rotation and 1:1 before that, hence, same set up as Nautique and no handling issues.
I think most of if not at least some of the other inboard ski boats have Left turning props. Not an issue, is it?
Not sure I understand your question.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-19-2017 at 1:12pm
Larry,
I assumed that the Supra had a LH prop so I was curious what happened if anything with the RH. Maybe Morgan will be back and comment?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: October-19-2017 at 1:17pm
I believe the 1:1 supras turned LH props. I am guessing that they did not compensate for prop rotation in the hull shape since they switched prop direction in the middle of the TS6M production run.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: October-20-2017 at 11:01am
Why are you pulling it???
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-20-2017 at 4:18pm
Larry,
My crystal ball and a look at the Supra website tells me that Morgan had an 89 with a 1.23 to 1 transmission so he swapped a normal rotation engine for a normal rotation engine and saw no handling differences.
On the other hand, one of the boats in our family is an 88 Supra Mariah that was born a lefty, died we bought it and it was reincarnated as a righty since I had a righty engine hanging around.
Later after rebuilding the original engine it became a lefty again
Since I figure you're fishing around for handling differences Pete, it handled different in reverse and it turned easier in one direction than the other going forward depending on which engine was in it as you would expect in both cases.
Being a big, wide boat there were no noticeable listing issues with either rotation engine. Mostly because it's not a skinny short 70's CC.
The wake was slightly more symmetrical as a lefty (kinda' a subjective opinion, there wasn't much difference at all)
It accelerated better and was faster as a lefty but that might have been due to an extra 50 or so HP after the rebuild
By the way, Supra's started out with LH props, went to RH props for a short time with the 1.23 to 1 transmission, then back to LH props and 1 to 1 transmissions when they switched to Indmar power after a change in ownership
Maybe some Supra guy from the right years will be interested
Post Options Post Options   Thanks (0) Thanks(0)   Quote wtrskir1964 Quote  Post ReplyReply Direct Link To This Post Posted: October-20-2017 at 4:54pm
Going to a GM with fly by wire and Zero Off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wtrskir1964 Quote  Post ReplyReply Direct Link To This Post Posted: October-20-2017 at 4:56pm
Folks, Please.....I am trying to sell an engine, not host a discussion on Supra and prop rotation.
Thanks for your understanding.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wtrskir1964 Quote  Post ReplyReply Direct Link To This Post Posted: October-20-2017 at 4:57pm
GM with Fly By wire and Zero Off.
*mtrbtr* View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote *mtrbtr* Quote  Post ReplyReply Direct Link To This Post Posted: October-20-2017 at 5:03pm
The more people post, the higher your ad stays on the page.
2006 SV 211 (sold) went to the dark side
97 Sport Nautique (sold)
89 PS 190 (sold)
05 Four Winns H180 (sold)
89 Four Winns 180 Freedom (sold)
75 MFG (sold)
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-20-2017 at 5:32pm
Correct plus Jim, it may be better for you to post in the for sale forum section and not the forum general section.
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: October-20-2017 at 5:48pm
Correct Pete. Back when stuff used to get removed from the general forum if it was a for sale listing posted.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: October-20-2017 at 6:24pm
Please people he's trying to sell an engine not discuss proper post locations.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-20-2017 at 6:39pm
This is CCF
When's the last time a thread actually stayed on track and didn't stray off to wherever?
Besides, the Supra discussion might sell your engine a little easier
Is that a new transmission or a rebuilt original that you're selling?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-20-2017 at 6:42pm
Zach,
Are you saying there's a moderator that's not doing his job?
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-20-2017 at 7:27pm
Where are you located?
Chapin SC or some other state?
Fl Inboards View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fl Inboards Quote  Post ReplyReply Direct Link To This Post Posted: October-22-2017 at 2:38pm
Hi Jim,
Jody Here,
You might make more off the engine parting it out. The ECM is NLA and really a pricey bugger to replace if one needs one!
Glad to see you are moving over to a Re-power Excalibur. We are doing one in the shop now on a 99 Bubble back.
Cheers buddy!
Post Options Post Options   Thanks (0) Thanks(0)   Quote wtrskir1964 Quote  Post ReplyReply Direct Link To This Post Posted: October-24-2017 at 12:00am
Hey Jody,
Would like to sell complete or may just keep to put in a Shamrock. The 1.23: 40 A is mint. Keep it in mind if needing a 40. I also have the original 40 A out of my 97 ski that is perfect other than the whine experienced in gears of it's vintage. Will let that one go really reasonable.
As far as parting out the engine I'm not really interested in doing that. I will entertain an offer on the whole engine.
Thanks,
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote wtrskir1964 Quote  Post ReplyReply Direct Link To This Post Posted: October-24-2017 at 12:03am
I'm located in Chapin, SC...just like my profile says....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: October-24-2017 at 12:28am
Guess Jody didn't get the memo on the bottom falling out of the gt40 ecm market.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-24-2017 at 2:40am
Username:     wtrskir1964
Group:     Newbie Newbie
Ladder Group:     Primary Ladder Group
Account Status:     Active
Last Visit:     Yesterday at 10:33pm
Posts:     6 [1.00 posts per day]
Find Posts:     Search for posts by wtrskir1964 Find Members Posts
Answer:     0
Thanked:     0
Status:     Offline Offline
Information     Communicate
Real Name:     Jim Miller
Gender:     Male
Date of Birth:     October-20-1964
Homepage:     Homepage Not Given
Occupation:     Sales
Interests:     Slalom / Barefoot
Private Message:     Send Private Message Send Private Message
Buddy List:     Add to Buddy List Add to Buddy List
Email Address:     Send Email Send Email
Facebook:     Facebook Not Given
Twitter:     Twitter Not Given
LinkedIn:     LinkedIn Not Given
Windows Live Messenger:     Windows Live Messenger Not Given
Skype Name:     Skype Name Not Given
Yahoo Messenger:     Yahoo Messenger Not Given
AIM Address:     AIM Address Not Given
ICQ Number:     ICQ Number Not Given
Signature
Jim Miller
That would be like you think your profile says. It only says Chapin
If it said Chapin SC I wouldn't have needed to ask, but you can update it if you want to
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-24-2017 at 7:22am
And I thought Jim lived in Chapin Il.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: October-24-2017 at 5:44pm
I was thinking Chapin Kuwait by the price.
tryathlete View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tryathlete Quote  Post ReplyReply Direct Link To This Post Posted: October-24-2017 at 6:48pm
Yeah—1650 hour motor for nearly 5 grand? To quote Mike Ditka,
“Who you crappin?”
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: October-24-2017 at 8:06pm
There was one on ski it again at the end of March. Complete and running but had a cracked block for 1K at a Nautique dealer. If I'd had been home I would have called. Should have anyway and seen if they would have held it til I got there. Skidim last had brand new ones in '04 for 6500. One of those and a closed cooling system would had tripled my Shamrock's value
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: October-24-2017 at 9:06pm
Will that fit in my 89 Bayliner Capri? How much will it cost to ship to 96795?
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: October-26-2017 at 12:12pm
Man you guys are brutal.
Cut the guy some slack, it's over priced but he'll find that out when he doesn't get any bite's.
Can't crush the guy for trying to make up some of the money for his upgrade by listing it to high, after all it's up to the buyer and what they are willing to pay.
