  New Posts New Posts RSS Feed - Battery not charging on 78 Tique
Swingmatt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Swingmatt Quote  Post ReplyReply Direct Link To This Post Topic: Battery not charging on 78 Tique
    Posted: May-27-2018 at 5:07pm
Battery not charging on Tique, pulled alternator off and had bench tested at parts store; it passed with flying colors I was told. On a new battery I could barley start boat after 5 starts in 7 hours on water not running any electronics. On volt meter while running, testing battery terminals it reads around 12.2 which is also same charge on battery not running. I tested back of alternator and was getting close to 40 volts at 1000 rpm connected to battery lead and ground to block. Is there some kind of external regulator? Why would I be getting that high of reading off of alternator and nothing at battery? Thanks for help
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: May-27-2018 at 6:11pm
My crystal ball says you have a 302 commander so if you have the original alternator, you should have an external voltage regulator mounted on the back of the engine
In the picture below it's the silver box behind the carburetor and next to the starter solenoid.
It would fit in the palm of your hand.
It's probably bad so your battery isn't charging.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Swingmatt Quote  Post ReplyReply Direct Link To This Post Posted: May-27-2018 at 6:26pm
Yes, same motor that’s in pic. Would a bad voltage regulator have any adverse effects on anything else? Everything seems to function as it should, at least I think it does. I know in the past I’ve had a difficult time with parts for this motor, any suggestions for the voltage regulator? Thanks for the advice
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-27-2018 at 6:35pm
Everything is currently running on the battery.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-27-2018 at 6:38pm
Matt,
Get the model of your alternator and do a search for a voltage regulator for the model. It's ether that or convert to an internally regulated alternator.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-27-2018 at 7:01pm
Matt,
I just did a very broad search for "alternator voltage regulator" and they even come up on Amazon. This one happens to be listed for a Ford.
You mention having a problem finding parts for the 78. Any examples? Don't forget if you ever have a problem finding parts, always post the issue. BTW, do not go to your local marina or automotive parts store before asking us.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-27-2018 at 7:45pm
Matt,
For piece of mind, call them up and see if they will test the alternator along with your voltage regulator. Did they even ask you about the regulator or even mention it? They should have since it's an integral part of the charging system.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Swingmatt Quote  Post ReplyReply Direct Link To This Post Posted: May-27-2018 at 8:45pm
Ran out of time today, Gonna get back to this tomorrow.. thanks again for the guidance
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: May-27-2018 at 10:21pm
Depending on the alternator your regulator may even look like this
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2018 at 9:24am
Matt
If you pull the regulator off and take a picture of it with the connector, that would help as far as finding a replacement. There might even be a mfgr's name and part number on it.
Or tell how many wires and what color they are
Post Options Post Options   Thanks (0) Thanks(0)   Quote Swingmatt Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2018 at 11:48am
my regulator looks like the one in previous reply picture, not this one
Post Options Post Options   Thanks (0) Thanks(0)   Quote Swingmatt Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2018 at 12:11pm
for an update, i had a difficult time getting advanced auto parts to bench test alternator they didn't want to do it with out a part number, but after we determined my boat wasn't four wheel drive, JK. he was able to find that alternator under a 1978 f-350 with 7.5 motor. with that info they got me a voltage regulator that pairs with it,. it also crossed referenced with the original part mnf number on part. i installed it with no success. charging system still not charging. the red wire from regulator to battery side of starting solenoid was a little corroded so i also replaced it that didn't help either. only three wire in the 4 pin plug to regulator, no wire in the I spot red in A, purple in S and green in F spot, this motor was converted from points prior to my owner ship, the charging system has never functioned since ive owned it, wonder if that has anything to do with it? maybe not converted correctly? would changing over to alternator with built in regulator be the way to go?
Duane in Indy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2018 at 12:37pm
Beginning to sound more like a poor connection somewhere. Start at the battery and work backwards. Both positive and negative terms. If a connector is not making a good solid contact then the alternator sees the wrong picture and won't charge correctly. It will still operate the starter because of high amp draw, but then will not charge with a lower amp draw. That would also account for the ultra high voltage. And if that is the case no amount of new alternators will fix it. Just a thought.
        1978 Mustang (modified)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Swingmatt Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2018 at 12:47pm
Sounds like a good thought, that outta keep me busy for a while, lol. Lots of old wires, may be a good time to start replacing some of them anyways.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2018 at 7:02pm
matt,
Here's a older wiring diagram that does show an external voltage regulator. It may help in your wiring quest!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Swingmatt Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2018 at 8:04pm
That will definitely help! Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2018 at 8:40pm
matt,
Matt
I'll throw this out there for ya.
This diagram is for an early PCM with a Prestolite alternator and a Prestolite external regulator.
You haven't exactly answered the question of what kind of alternator and regulator you have so be careful using the diagram. It may or may not help.
If your alternator and regulator cross referenced to a 78 F-350 with a 460 in it, you don't have much chance at all of having them be from Prestolite
And.........if it came in a vehicle it probably isn't a marine alternator either. Maybe they found something similar but not exact.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Swingmatt Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2018 at 9:51pm
Thank you, my motor is a 302 commander, the alternator is the original alternator but was reconditioned just before me acquiring boat. And the regulator looks to be original, it’s motorcraft marine part # D4FF-10316-AA. Either way the wireing diagram should be a decent guideline for me to start with. Not sure how to post any pics on here. I Can only access forum from my smart phone or I’d post some.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: May-29-2018 at 12:19am
Do you have an ammeter or a voltmeter in the dash ?
If it's an ammeter, does it work?
If it's a voltmeter, does it look like the rest of the gauges or maybe something that was added over the years?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Swingmatt Quote  Post ReplyReply Direct Link To This Post Posted: May-29-2018 at 9:36am
Yes, there is an ampmeter gauge in dash. Looks like the rest of gauges so I’m assuming it’s original with vessel. Boas never had a functioning charging system since in my possession so can’t say if gauge works or ever worked. Needle does flicker when ignition is turned or any other power is used, such as blower or bilge.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: May-29-2018 at 10:30am
With an ammeter, all of the alternator output goes through the ammeter on it's way to the battery. It's a long and winding road from the alternator output connection up to the ammeter, thru the ammeter to the ignition switch, then back to the battery side of the starter solenoid, then to the battery.
You can see most of this on the PCM diagram earlier in the thread (which could be drawn a little better) but for wiring setup with an ammeter, all of the alternator output goes through it no matter what brand we're talking about In other words a dead (open circuit) ammeter will prevent the alternator from charging the battery
The flicker might mean it's working but I'd temporarily jumper around the ammeter with some 10 gauge wire and see if you're getting a charge to the battery.
Also, with the new regulator installed what is your voltage on the Battery terminal on the alternator when the engine is running?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Swingmatt Quote  Post ReplyReply Direct Link To This Post Posted: May-29-2018 at 2:27pm
Voltage from battery terminal on back of alternator at 600 rpm is 26-30 volts, and at 1200 rpm is around 60 volts. What exactly would I jumping to and from to get around ampmeter?
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: May-29-2018 at 2:57pm
Well with 60 volts coming out of it, I wouldn't do anything that could supply the electrical system. Edit keep reading through the thread and you'll see that 60 volts is what will happen when the alternator is not supplying the electrical system (oerating with no load on it)
If you do you'll cook every 12v electrical piece of equipment on the boat.
You really need to figure out your voltage regulation issue before doing anything
You mentioned the regulator being a Motorcraft, what's the alternator?
Since you can't put pictures here, what do you have for wiring connections on the alternator?
So just to make sure you understand 60 volts will kill everything electrical on the boat so don't bypass the ammeter or really do anything till you get the voltage straightened out and it around 14 to 15 volts coming from the alternator
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-29-2018 at 3:10pm
Matt,
I feel it's time to take both the alternator and the voltage regulator to a reputable store. Ideally it would be a "auto electric" shop. I'm getting the feeling that Advanced Auto didn't do the job! Remember, both the alternator and the regulator work together. I'll ask again, did Advanced even ask you about the regulator when you first took the alternator in?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Swingmatt Quote  Post ReplyReply Direct Link To This Post Posted: May-29-2018 at 3:35pm
They did not ask about regulator. I agree, stopped my marine shop today, they had no advise other than a referral to a shop that may be able to help. Gonna follow up on that in next day or two.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Swingmatt Quote  Post ReplyReply Direct Link To This Post Posted: May-29-2018 at 3:40pm
Motorcraft alternator as well. Red BAT, orange FLD, Black STA, and two ground post.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: May-29-2018 at 5:52pm
Matt
There aren't many things that me and Pete agree about but this is turning into one of them.
Your description of what wires go where and the colors associated with them really make no sense. It's not your fault, you got the boat this way
Without help from an auto electric shop or having a Commander wiring diagram in front of you it's just guesswork and with electricity that usually doesn't turn out good.
You did mention a while back thinking about a 1 wire alternator.
Something like a 1 wire Delco marine alternator would probably bolt in pretty easily and it's hard to screw up the wiring with just one cable attached to the alternator.
Pete would probably agree with me about that too.
You would eliminate the external regulator, the old alternator and be cutting or taping off a few wires.
Unless you're running lots of stereo stuff etc. the one wire would do just fine in your boat and it would be pretty easy to help with the wiring hookup.
They're pretty cheap from places like DB electrical (around 60 dollars)
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-29-2018 at 5:53pm
Matt,
Here's some auto electric shops in Atlanta Ga.
Tucker Auto Electric & Accessories
2016 Metropolitan Pkwy SW, Atlanta · (404) 766-3242
Directions
Nelson's Auto Electric
226 Flat Shoals Ave SE, Atlanta · (404) 523-4212
Directions
Mike's Auto Electric
1 Yelp review
118 Walton St NW, Atlanta · (770) 463-5050
Directions
A BC Electric Automotive
3365 W Hospital Ave Ste A, Atlanta · (678) 502-7014
Directions
Fleet Auto Electric Inc
624 Cordell Dr Ste B, College Park · (404) 766-6112
Also, is this how the regulator is wired to the alternator?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-29-2018 at 6:06pm
Matt,
Your problem is taking my memory wayyyyy back to my high school shop classes. We had a combined project between auto shop and electronics shop. We were making switch/outlet boxes that we wired into externally regulated car alternators. The switching basically bypassed the regulator feeding I believe the alternator field. Then by regulating engine RPM, the alternator would produce 120 volts for power tools.
You ether have bad wiring between the regulator and alternator or the regulator is bad or the wrong one. Double check the wiring or get both the alternator and regulator to one of those shops I posted.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: May-29-2018 at 6:34pm
Evidently your memory is sketchy on geography class too.
