  New Posts New Posts RSS Feed - Stripped / Rusted drain plug hole
KRoundy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Topic: Stripped / Rusted drain plug hole
    Posted: October-30-2018 at 9:38pm
I need some engine expert help. I was winterizing my boat and have a problem. The aft / left side drain plug hole has rusted to the point there there are no more threads. I purchased a new drain plug and I can't get it started at all. So I am now stuck in my winterizing process since I can't pour the antifreeze in until I can put back in my drain plug.
The plugs appear to be 1/4" pipe thread. What do I do? I need to tap the block drain spot. Can I buy a tap somewhere and do this? What size? What thread? Please be specific. Do I need to take it to an engine shop?
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-30-2018 at 9:49pm
They are 1/4 inch pipe threads
If you get a 1/4-18 NPT tap you should be able to use it to make some new threads good enough to put a new plug in there.
It's not the best place to be working but you can do it
MACS81SN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACS81SN Quote  Post ReplyReply Direct Link To This Post Posted: October-30-2018 at 9:49pm
Been there.    Just need a 1/4” NPT pipe tap.   Some hardware stores carry, maybe HD or Lowe’s. McMaster- Carr for sure.   Just don’t tap in too deep as it will make the hole bigger and tough to seal because of the taper.
1999 -SN - 502 Python
1981 - SN Owned 33 years - Sold
1968 - Mustang - Sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-30-2018 at 9:54pm
Here's an old thread in the link saying all the same stuff that me and Mark mentioned
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: October-30-2018 at 10:08pm
Awesome. Will stop by ACE on my way home tomorrow. Thanks for the link too. 2010! That a good deep track there. :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: October-30-2018 at 10:19pm
Solid brass pipe plugs tend to run fatter than hollow
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: October-30-2018 at 10:54pm
Agree on that. But, if the threads are not too far gone, meaning you have some decent resistance right away when you start the tap, I'd try putting in a petcock so you don't have to use the threads any more once you have it in. I've also used 3-4 wraps of teflon tape to add some sealing bulk on the new threads.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2018 at 1:15am
The problem is that the threads are really gone. There's nothing to "start" to grab. The part where the threads would start to engage looks like a smooth tube. The other drain plug area is fine with lots of thread. This one on the left for some reason is dealing with more rust problems. I'll tap and report back. Thanks, everyone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2018 at 1:20am
How about careful drilling to 3/8" and tapping new NPT threads? Is there enough metal to do that?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2018 at 7:48am
Certainly an option I'd suggest. Going to 3/8 pipe means only enlarging the hole .0937" (3/32") in diameter which is only .0468" (3/64") per side.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2018 at 10:02am
Here comes the "backyard hack" in me
I'd try the 1/4 inch pipe tap whether you think it'll work or not and see what you get for results. It'll cost you less than 10 bucks or so to try it.
If that doesn't work and you want to get antifreeze into it for the winter, I'd get an expandable rubber plug of the appropriate size and put that in.
Here's an example in the link and they do make them small enough. A good hardware store should have what you'd need.
As far as laying on the floor with a 1/2 inch drill with a big bit (37/64), getting a straight shot at the hole with any kind of precision and then getting the 3/8 npt tap started/ finished with any kind of leverage/force................it ain't gonna be easy.
The rubber plug would give you all winter to decide what to do if the 1/4 inch tap doesn't work.
Disclaimer..................A really accomplished, full fledged "backyard hack" might use that as a permanent solution
You could also do the drain and pour some antifreeze in and drain that out and leave it dry method for the winter.
I can see Pete clutching his chest as I type this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2018 at 10:32am
Darn good points and advice, Ken. I once used a whittled stick to plug a hole for the winter so the engine could be pickled. It didn't become a hack job until the boat owner thought it held up so well over the winter that he could run it like that all summer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2018 at 10:34am
Let's not forget you don't need to plug that hole for winter...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2018 at 10:36am
No, but if you do that, pour some antifreeze through the engine to flush the water out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2018 at 10:39am
Good suggestions above. Have encountered this several times. Running the 1/4” tap deeper and then taping the heck out of the new fitting will almost always solve it. If clearance allows (fords aren’t usually problematic), the McMaster quick drains are nice and will prevent you from putting additional cycles on marginal threads.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2018 at 10:42am
Does leaving the plugs out cause the threads to corrode?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2018 at 10:58am
Yes
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2018 at 11:30am
That's not the cause of corrosion.
Mille1sj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mille1sj Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2018 at 11:52am
I don’t know what everyone else does, but I usually put a small amount of grease on the threads, marine grease, bearing grease, etc. it can help to act as a rust preventative if you are going to leave your plug out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2018 at 12:06pm
The water and air interacting in the exposed threads would be the direct cause... seems that leaving the plugs out would be a strong contributor to that.
I’ve only lost the threads on one engine that I had maintained for a long period of time, and it occurred in the spring following the single winter where I drained only and left the plugs out. Maybe it was a long time coming but that sure seemed to speed the process. Plugs get reinserted now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2018 at 12:11pm
I use Teflon tape and snug them up, not crank them down.
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2018 at 3:11pm
Same here. Forgot they were out. Lucky enough thread deep in the hole cleaned up with a tap worked.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2018 at 4:23pm
Seachoice wood emergency plugs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2018 at 6:28pm
Purchased a 1/4-18 tap at NAPA on my lunch break. Will report again soon. I’m hopeful that it will be really dry so I can get a good look. Going to look at McMaster quick drains right now...
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2018 at 6:48pm
The McMaster part is 4921K2. It's a 1/4 with the removable stem/T handle so you can still probe the drain with some wire checking for sediment/blockage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2018 at 7:39pm
Purchased a 1/4-18 tap at NAPA on my lunch break. Will report again soon. I’m hopeful that it will be really dry so I can get a good look. .
Kevin,
One thing you should be aware of when running the tap in deep is how deep the water cavity is behind the hole. If there's not enough room, then the tap can bottom out before you get some decent threads cut. There are taps that are called "bottoming" or "short projection" where the taper is larger in diameter at the bottom of the tap. Think about trying to tap a pipe cap. In a pinch, I've cut taps shorter to get the same results. Check how deep the hole in the block is.
Faceplant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Faceplant Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2018 at 9:33pm
I thought that when you did the " drain only method " you didn't need to add any anti freeze at all ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2018 at 10:05pm
Jeff,
Correct. If you drain only, no antifreeze is needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2018 at 11:26pm
Jeff,
I've always squirted a bit of antifreeze in each engine drain, manifold drain, raw water hose, top engine hose. Likely not needed, just an old habit. When I say squirt, I'm using a syringe so barely a few ounces total.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: November-01-2018 at 8:53am
I always put the plugs back in and pour 1/2 half gallon of anti freeze into engine, then pull the plugs again. Water always proceeds the antifreeze draining out, so if you just pull the plugs, some water remains in the engine.
