Damper Plate |
schultz227
Groupie Joined: August-20-2019 Location: Indiana Status: Offline Points: 49 |
Posted: September-07-2019 at 3:51pm |
Replaced the damper plate now it revs up very rough not under load , any thoughts on alignment? 1,000 in on this project and the boat runs rough Needed a new flywheel because of starter problem . Replaced the damper and the rear main seal too . Any help appreciated so frustrating
What engine, where did you get the flywheel? What was so wrong that it needed to be replaced?
How about some details. What engine are you working on? Ford, Chevy?
Some flywheels are for an internally balanced engine, some are for external balance. You need to know more to get good answers. |
And the firing order you are using?
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10665 |
And while you're at it...........your favorite color, the name of your first pet and the street you lived on as a kid
It looks like you have a 92 SNOB with a 351W.
Does it have the ProTec ignition system or a regular distributor. And there's a reason for asking that |
schultz227
351 with the 123:1 tranny Mallory ignition . Parts came from oreilly and are supposed to be marine specific .
schultz227
Firing order wasn’t messed with , it ran smooth as silk before the work . Shifts in and out of gear like butter . When you rev the engine in comes the vibration
Do you have the O'Reilly's part number for the flywheel?
Would you know the brand and part number of the flywheel?
So when you rev it up in neutral (no load) you get the vibration? |
slipping....
We're just thinking alike, I'm not as speedy as you today though I was distracted looking at some Monty Python stuff |
schultz227
Correct , no load
schultz227
Also there under load obviously
schultz227
Shifts like butter no rattles
Brand, part number of flywheel ?
schultz227
Don’t have it , mechanic has it and not responding tonight
Kyle, What's he saying about the problem? |
schultz227
He’s telling me it can’t be the damper plate because it all was installed as it came off in the same bolt pattern or whatever as the old one . He did put a carb kit on it as I had a major leak at the accelerator pump
schultz227
Friend of mine did the damper plate on his 88 and says it was the same thing with the bad vibration and he got what he called a Sachs plate and it was better ..
schultz227
So in review he put a carb kit on , new flywheel not just ring gear , rear main seal, damper plate .. and starter ... ran beautifully before all this except for the starting issue and carb leak but it ran smooth
What I'm thinking and I suspect Ken too is that the wrong flywheel may have been used. Fords are externally balanced- there are two different imbalances 28 oz and a 50 oz,so a flywheel part number if/when you can get it would help.
schultz227
Does it take the 28oz ? Or 50 ?
28 oz. |
So now you get around to mentioning something else that was done at the same time like a carburetor kit that maybe should have been mentioned in the first post Easy enough to have a rough running engine due to some carburetor issues. Not knowing what this "roughness " is like without being there, I think I'd be looking at the rebuild job on the carburetor if the flywheel is the correct 28 oz imbalance |
nitro scott
Newbie Joined: September-02-2019 Location: crosby Status: Offline Points: 8 |
Is there an automotive application for a damper? Are they easy to get. Mine is looking a little worn.
1973 Ski Nautique Tow boat
schultz227
Wrong flywheel, he tells me the counterweight on the new one was twice the size of the original , thank you very much for the advice . Asking him to double check the flywheel saved us lots of headaches. Thank you again
If you want the right flywheel from an automotive application ask the parts guy for a flywheel for a 67 Ford Mustang with a 289 and a 4 speed.and you'll have the right 28 oz. imbalance
Here's a link showing a few part numbers from aftermarket suppliers link |
I get the feeling that you could use the old flywheel with a new ring gear based on your description of having "starter problems"
If just the teeth are chewed up, get a 157 tooth ring gear and replace the old gear. It's a lot cheaper too Here'a a link to a thread with some ring gear part numbers in a post by GaryS link Or if you're asking at the parts store, use the same 67 Mustang with a 289 |
