Chucky’s 1966 Mustang rebuild |
Post Reply | Page <1 34567 11> |
Duane in Indy
Pete, I am not sure anyone knows what we are talking about anymore. The seal post has sure taken up some ink. Going to be a long winter by the looks of it. Enjoy your Holiday.
Duane |
1978 Mustang (modified) |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10652 |
I have to admit Duane, I read it and thought the same thing Pete did I think Chucky should post a picture of either his carburetor or his distributor or both next, for some what should we call it? CCF scrutiny For some reason I'm sensing a Holley that looks a little different than the typical marine Holley for a 302. But it could be marine |
Chucky
Senior Member Joined: September-24-2019 Location: Minnesota Status: Offline Points: 153 |
Thanks for setting me straight, but... here’s a page out of a genuine marine maintenance manual. Must be some special? pan that holds...wait a minute...only 4 quarts? That can’t be right.
Chucky
Maybe the Chevy guys had a special ($$$$) pan...? Or, maybe not.
So...........why not just tilt your oil pan at a 15 degree angle with it off the engine and pour in some oil and see how much it takes to get the level where you want it?
Then you can redo the dipstick marks if you need to |
Chucky
Trailer mods mostly complete / painting it black by the end of the year. |
Chucky
Winch / roller modification done (moved winch location) and in primer, along with a couple other tidbits. Paint coming soon, then it’s back to the boat. It was -8 degrees here this morning. The lake I plan to initially test the boat on, McMahon, is frozen enough to drive a pickup truck across.
63 Skier
So here's the flaw in your plan ..... you could be initially testing the trailer on the lake, not the boat! |
Chucky
About...1/2 way there...
Chucky
I “serviced” the axle bearings and replaced the leaf spring attaching hardware. The trailer came with bearing buddies. Having never owned them in the past, I went through my own process of deciding if they are a good product. Long story short - I tossed them in the garbage can.
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Online Points: 2843 |
Bearing Buddies...
IMO, the Bearing Buddies work OK if you do the following: - Quality grease seal - Use cover (Bearing Buddy Bra or something similar) - Don't pump too much grease into the axle and blow-out the grease seal - Check regularly to ensure that grease level is appropriate - Use quality marine grease They are not a "set-it-and-forget-it" item, but I've put many, many miles on my trailers without a bearing failure to date. JQ |
Why?? What's you "own process"? Here's what happens: After a trailers been on the road the bearing area heats up. Then when the trailer goes into the cooler water a vacuum is formed sucking water into the bearings. The spring loaded bearing buddy prevents this from happening. I'd suggest getting them out of the garbage before your next garbage pickup. |
Chucky,
It's Mom,...........you've been a baaad boy It's not nice to get old Mr Brainard all worked up on Christmas Eve, so nothing will be in your stocking Then again, it's your trailer and you should be able to do whatever you want whether it bothers him or not |
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3592 |
The lake we frequent has about a 3 mile steep downhill on a one lane road to reach the launch. The brakes are hot at the bottom of that hill. I have bearing buddies on all 4 axles and I have water in the brake hubs every year when I take them apart. I have started using Low Range in the truck with my boat brakes disconnected while I go down this hill. The Low Range keeps my speed down below 15 MPH and works well. Truck and boat brakes stay cool, I don't get water in my hubs anymore. I like bearing buddies but in my application the heat was pulling in water.
I see you plan to paint the trailer black, Black does look very good when clean. I went back to a White Trailer. Our summer heat can be 100* often and the black trailer would be so hot I could not touch it with bare hands or feet. White stays nice and cool so for me it was good change. Merry Christmas. |
Chucky
Fenders and wheels not done, but I’m getting real close now.
Chucky
Mini-bunks are canted at 10 degrees to match the boat. They’re also adjustable (in and out). The main bunks are also able to change angle front to back, after I modified the rear mounts. They should contour to the bottom of the boat, once the boat is back on it.
Chucky
So close to switching back to the boat. Trailer is about 98% new. Wheels / tires yet to be determined.
Chucky
Chucky
Boat officially sitting on trailer now. Although it’s not the factory trailer, I’m liking it.
Kristof
81nautique
Grand Poobah Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5767 |
Not factory but it does have a good look. As long as the boat sits down between the fenders it works for me. Great job.
Chucky
Although the fluid was clean, I simply don’t know the history. Might as well start at zero.
67 ski nat
Platinum Member Joined: July-19-2018 Location: Santa rosa Status: Offline Points: 1181 |
Yep. That is same kit I was going to get, thanks for confirming
Chucky
Preparing for kit to arrive...
63 Skier
Your shop is way too clean. I don't trust you ......
67 ski nat
Please let me know if all parts are used in kit , number plates and stuff
Looks like a tv sit com garage All props |
The kit has enough parts like clutch plates to do a 72C/10-18 transmission so you (and Chucky) will have parts left over. You can try to cram them all in, but you won't succeed even with a big hammer If you post a picture of your ID tag on the transmission, that'll be a good start to figuring out what's inside it before you start tearing into it |
67 ski nat
My tag is hard to read but I believe it says 10-17. 71c
I remember talk about extra plates so curious what chunky finds |
I believe that what you believe needs to get looked at again In 1967 the terminology As 10-17 hadn't come about yet. It'll probably say AS1-71C unless a much newer transmission was put in at some time |
67 ski nat
Yes good idea,
