Fumes! |
Atomic Dam
Groupie Joined: May-20-2020 Location: Texas Status: Offline Points: 89 |
Posted: June-08-2020 at 1:14pm |
1975 Southwind 20 closed bow / escort 351W. I am having a real problem with gas fumes in the boat. Does anyone else have a similar issue or HAD a similar issue. I can't seem to find the culprit. There are no gas leaks anywhere that I have been able to find. Turning the blower on doesn't seem to make any significant difference. Can someone offer me some insight? I'd surely appreciate it.
OEF/OIF US Army Combat Veteran '75 Southwind 20 Escort 351W |
Orlando76
Fumes as in burnt gas or Unburnt gas?
Atomic Dam
These are raw gas fumes. |
John,
At the engine or aft by the tank? Does the bilge blower pull air out of the bilge and then out the vent? |
Atomic Dam
To be honest, it's hard to say exactly where it's coming from. It's really strong all over the boat, at the helm, underfoot near the bow, at the stern seat and everywhere in between. My eyes were watering when I took her out on Saturday, and one passenger had to be taken back to shore due to a bad headache. I believe the blower pulls draws from stern blower (fan), and pulls air from the bow vents, into the bilge or engine compartment and out the rear vent. |
John,
I'd suggest a bilge flush first. Get the garden hose out and start adding water all over in the bilge. while running the bilge pump. (get the battery charger connected so you don't run the battery down). Let the bilge dry out and then start the "hunt". |
Atomic Dam
Okay, I will do that right away. Is there any kind of spray cleaner that would be safe for that area that I could add to the hose? Simple green or anything to cut through any old engine fluids that water may not get loose? |
Orlando76
Hold off on the battery charger part if fumes are as bad as you say. Why not pull the plug to get majority of water out. I’d be hesitant to introduce a spark at that rate. I’d pull the bulkhead out and inspect around tank and fill hose. I’ve known 2 intelligent people who at one point or another filled their CC up with gas bc filler hose was not properly installed. If not at tank check at the intake manifold and carb where the fuel line comes in, seems like people have troubl snugging that up as well as at the fuel pump.
Orlando76
As for cleaning bulge I always used hot water and Tide laundry detergent. More intelligent people might say Tide is hard on hoses and wires but we’ve been doing it for over 40 years now.
Grand Poobah Joined: April-21-2005 Location: NE CT Status: Online Points: 3333 |
IME there is raw gas coming from somewhere, but its going to be hard to tell where when it is blowing around
Bilge airflow often reverses, blower or not, when underway due to the low pressure area created by the cockpit and windshield. |
Todd, Good thinking. Thanks. |
Dawn is my choice. |
Atomic Dam
Okay, So based on this information, the steps to take:
1) Don't Blow up 2) Dawn and hose to clean and spray out bilge area 3) Pull stern seat and bulkhead to inspect filler tube and gas tank connections 4) inspect direct fuel lines and connections Does that bulkhead head easily remove? |
I would remove the engine cover, rear floor panel, rear panel covering fuel tank.
Use paper towels or newspaper to find wet spots. You may have a leaking fuel tank. Do not turn on any electrical circuit until this is resolved. |
Orlando76
Just to be clear, fumes are there with boat off correct? Bulkhead should be a dozen screws, I never pulled one on a SW. I wouldn’t pull floor just yet.
Atomic Dam
Fumes are there all the time. Running or not. Seems heavier at the helm when in motion, but I believe that is only because of the negative pressure behind the windshield.
Atomic Dam
So update. I cleaned the bilge out. pulled the back seat. There is no bulkhead. Once the back-pad of the rear seat comes off, the fuel tank was exposed. I took the filler tube off and I believe that I found the problem. The P.O. had taken quite a large piece of what looked like braided stainless steel cable an ran it from end to end of the filler tube on the outside and attaching it with hose clamps. at each end though he tucked the remaining steel cable into the filler tube and pressed it on to the fuel tank neck, up over the fuel fill point neck. so essentially there was the filler tube with a fat piece of steel between it and making a tight seal on the tank. So when I was fueling up, I had raw fuel leaking out into the bilge area, and if I filled it all the way up, then any fuel that was in the fuel hose just ran down the side of the gas tank. I replaced the fuel tubing between the tank and the external fuel point and hope that will fix my fumes issue. I will be taking it out this weekend to see if that solves my issue.
Once question though. I can only deduce that the P.O. had put that cable there as a ground to the tank. Was that a necessary precaution? |
Yes, I'd say grounding was the idea. Just making sure the tank and deck fill are grounded (all to the engine block) is the norm. Some will go to the extent of grounding all the metal aft deck hardware. If the hardware is just screwed on, longer machine screws are used to go through the deck so wire terminals can be attached below deck. |
John,
One more thought. Heavy cable is not needed. Your normal 16-18 gauge wire is good. |
Atomic Dam
Roger that. I will make sure that it's replaced before I go out, and I'll update upon my return. Thanks |
Orlando76
How big was the SS braided cable? I’m kinda thinking anything less than a 14ga and good hose and clamp would conform around it, No?
Atomic Dam
It was 8awg braided. he tried to fan it out, but the bulk of the wire was impossible to conform to. I'm thinking that just one of the braided filaments would have been plenty. |
Orlando76
Oh, well yeah 8 would create a gap.
Sounds like the PO was thinking more for lightning protection than static electricity protection. |
Atomic Dam
Hmm.. didn't think about lightning... maybe I should put it back...
Fabcon
Gold Member Joined: August-27-2012 Location: Buffalo. Mn Status: Offline Points: 552 |
Never be afraid to over build.
1984 Barefoot Nautique (Parting Out) |
Atomic Dam
Problem solved. Took her out this weekend, and there were no fumes, even after filling the tank at the marina. So problem solved. Thanks for everyone's help.
I did have another question though, I don't know if I should start another thread. How much water is normal in the bilge of a Southwind 20? |
As a rule I prefer to hunt down and address all sources of bilge water.
Then if i see water, i'm certain something is amiss. |
Atomic Dam
So no bilge water is the appropriate amount of bilge water. Okay. I have search then. For a boat that apparently had no issues when I purchased it, it has a new one every time I take it out. This last outing to check my repair on the fuel tank I noticed a pretty heavy amount of bilge water, I pumped it out, thinking nothing of it. When I pulled the boat out of the water, I popped the engine cover to remove the drain plug, and it was pretty full again, so I am taking on water from someplace. |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10662 |
Your shaft packing will always drip a little bit if it adjusted right, so there's always a small amount of leakage into the boat.
Look at the shaft and the rudder as 2 obvious choices. Make sure the bilge drain plug is tight too. Then it's a matter of seeing what else you might find leaking. See if the leak only happens when the boat is running or if it leaks while parked with the engine off to help you narrow things down. There are lots of other penetrations through the hull like the strut bolts, rudder port bolts, anything attached to the transom like a swim platform that might have been added, exhaust hoses and their clamps and the exhaust outlets in the transom. Cooling system hoses, raw water pump seal, freeze plugs, drain plugs on the engine. maybe speedometer tubing leaking and a few other things I'm sure I missed I'd vacuum it out on shore so it's good and dry, then launch and look. It might be like watching paint dry ..........or may be easy to find |
